Sharp TV LC-40LE600E
  • nomoresonys
    • 12276
    • U.S.
    That's not much of a response, the question WAS, CAN you prove the eeprom is the issue?? Good troubleshooters like Diah, don't guess or jump to conclusions, CAN NOT say the same for you tho.
    • nomoresonys
      • 12276
      • U.S.
      Sure I can try to help the op if they want OR they can run out and get a programmer and reprogram the eeprom AND HOPE that was the issue.
      • nomoresonys
        • 12276
        • U.S.
        Go ahead and try post #9 three more times, wait a minute or two between tries.
        • nomoresonys
          • 12276
          • U.S.
          So lets troubleshoot, looks like lotus just wants to criticize and not really be helpful, that's my opinion.
          • nomoresonys
            • 12276
            • U.S.
            I'm done, looks like Diah was right, lets see if lotus is able/willing to help this op.
            • nomoresonys
              • 12276
              • U.S.
              #26
              HEY mod, I consider post #18 to be rude, just because this guy is more subtle/sneaky with his RUDENESS doesn't mean it isn't there.
              • nomoresonys
                • 12276
                • U.S.
                #27
                He may be better off/more suited to one of those debate/fight chat rooms, lol.
                • nomoresonys
                  • 12276
                  • U.S.
                  #28
                  Well at least now you know, ask Diah and some others what they think or just read some threads, the truth will win out.
                  • Diah
                    • Feb 2013
                    • 6438
                    Originally posted by Kerden
                    Hi everyone?!
                    The LED stay red and fixed (no flashing)
                    What could I test please?
                    in you case when there are no action at front indicator,,, we will first disconnect the MB from PSU.. and test the PSU as stand alone to be sure the SMPS working and it will provide all needed Voltage... when the result good.. then we will move to MB to check why it didn't send Power_ON to PSU to turn on the SMPS... so the steps should be ..
                    • nomoresonys
                      • 12276
                      • U.S.
                      #30
                      +100, Now that's logical.
                      • Kerden
                        • Aug 2024
                        • 19
                        • France
                        #31
                        Here are some measurements from the PSU disconnected from the MB
                        MotherBoard disconnected from PSU
                        Fused F7002 ok
                        Fused F7001 ok
                        C 7144 ….. 395v and keep on going down
                        VA 7002 …..
                        D7105….. 101v
                        D7106….. 101v
                        C7124….. 0,125v
                        D7113….. 0,073v
                        D7114….. 2,7v
                        JP7130…. 0,3v
                        D7112….. 0,16v
                        R7141….. 0,0v 7ohms
                        R7143….. 0,0v 7ohms
                        D7115….. 0,0v
                        D7203 …. 0,002v
                        L7111….. 0,0v
                        D7204…..0,0v
                        R7159 ….0,0v 7ohms
                        R7192 ….0,0v 7ohms
                        D7150 ….5,0v
                        D7123 …..0,0v
                        D7149 …..4,2v
                        D7134 …..0,06v
                        D7126 …..0,06v
                        D7122….. 0,0v
                        D7128 …..4,2v
                        D7127 …..4,4v
                        C7518 …..0,0v
                        C7505…...0,0v
                        C7506….. 0,0v
                        C7531 …..0,0v
                        R7599 …..OL
                        R7589 …..OL
                        • nomoresonys
                          • 12276
                          • U.S.
                          #32
                          You want to test correctly, for testing the diodes, UNPLUG tv from power, meter in diode mode, for resistors same, tv unplugged, test in ohm mode, that's your first test to see if they are functional. You need to be careful while testing when tv is powered, you have to use the correct grounds, be VERY careful what you touch with your hands you don't want that 395 volts zapping you, it can be deadly, youtube is full of videos on testing.
                          • nomoresonys
                            • 12276
                            • U.S.
                            #33
                            So when you tested like that, did you see where the voltage settled at on C 7144? Something seems strange about it.
                            • Kerden
                              • Aug 2024
                              • 19
                              • France
                              #34
                              I already have tested the C 7144 at 395 v
                              I've pluged the MB and I mesured 350v before it begins to do down.
                              • nomoresonys
                                • 12276
                                • U.S.
                                #35
                                Need to be clear on statements, so you're saying that with MB unhooked you get 395 steady volts?
                                • Kerden
                                  • Aug 2024
                                  • 19
                                  • France
                                  #36
                                  The C7144 gives 395v when plugged to the moterboard
                                  When unplugged, tio the motherboard it gives 280v and keep on going down
                                  • nomoresonys
                                    • 12276
                                    • U.S.
                                    #37
                                    Well 395 when hooked up as it should be is normal, when unhooked from mainboard there's no signal from mainboard telling the powerboard to turn on fully so that's to be expected, usually on boards with pfc, you will get about 165 volts at the big filter caps when testing with that cable unhooked.
                                    • Kerden
                                      • Aug 2024
                                      • 19
                                      • France
                                      #38
                                      Thank you very much for the explanations, I will look after the C7144
                                      With the motherboard plugged in:
                                      The C7510 gives 5.11v
                                      The C7505 gives 0.0v
                                      Only, if I press the On button on the TV, the speakers start to crackle
                                      And the voltage goes to 3.2v
                                      I wanted to repeat the same operation and it didn't work:
                                      The C7510 still stays at 5.11v
                                      But the C7505 stays at 0.0v
                                      So sometimes this C7505 is powered, sometimes it is not.
                                      • Diah
                                        • Feb 2013
                                        • 6438
                                        hey people what are you talking and testing C ... LOL C will be stay in charge 100 years if it get V and no way to discharged if there open circuit that it couldn't discharge.... so any C on PSU most discharge first within the main caps on PSU
                                        • lotas
                                          • Jan 2016
                                          • 4753
                                          • Russia
                                          #40
                                          You get 165v when the network is 120v, and when the network is 220v (France), then 165v will not be there, but 310v-320v
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • dmcabs
                                            SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
                                            by dmcabs
                                            Hey guys,
                                            I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
                                            This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
                                            FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
                                            I'm a bit rusty but still have ability to dig right down.
                                            I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
                                            09-21-2024, 11:09 AM
                                          • JunkmanJimbo
                                            sharp lc-65ub30u plays but screen is flashing on and off
                                            by JunkmanJimbo
                                            Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
                                            09-07-2024, 09:45 AM
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • DrvLikHell
                                            Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                                            by DrvLikHell
                                            Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                                            The...
                                            02-05-2025, 01:44 AM
