lcd19-229 stand by light on and off
Re: lcd19-229 stand by light on and off
OK please check voltages on: pin 2, pin 5, and pin 7
Pins are counted as such, starting from dot:
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
hi tom that parts is burnt would that be all that the problerm is ? if so do you have link for that as cant find a match
pin 2 = 12.83 pin 5 =000 pin 7= 5. my dot is where pin 1 isAttached Filesif you find these attachements useful please consider making a small donation to the site
It's actually AIC2857F. Is it physically burnt? Your results indicate it is not functioning, in the very least.
One on eBay, they're about £5 each
http://www.ebay.co.uk/itm/1PCS-Brand...item3cc84b952e
but plan on about 2 weeks to get it from China.
See diagram here:
http://www.analog.com.tw/p2_6_detail...idTableName=05
Pin 2: input voltage, this is OK (12V from PSU)
Pin 5: output feedback, should be 1.25V - not OK indicating the output voltage is not present
Pin 7: on/off command, it is >2V indicating the main board processor says "I want power" but converter does not function. (Like a light switch which is on but with a blown light bulb.)Last edited by tom66; 03-04-2014, 04:20 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
does look burnt when zoom in is that the only place i can get one lolIt's actually AIC2857F. Is it physically burnt? Your results indicate it is not functioning, in the very least.
but plan on about 2 weeks to get it from China.Comment
From the pictures, it looks OK to me.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Other places to buy
http://www.ebay.co.uk/itm/ic-sop-8-A...-/400538572096
http://www.aliexpress.com/item/AIC28...449252694.html
BTW, dot always marks pin 1.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
ok thanks tom i will get there in the end but reading not my strong pointOther places to buy
hence why i fit kitchens and build cars lolComment
by judamexMacBook Air turns on without battery connected, no green or orange light comes on, I connect the battery and it shows battery with lightning and it restarts constantly.
by MOSSEPHi
Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
I have already tried replacing all of the...-
by MOSSEPHi
I have already tried replacing all of the... -
by lcdcaps1Hi
I have an 820-2610-A motherboard that has no green light.
I have noticed is when I do a SMC reset the light on the Magsafe blinks.
From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
The sys onewire circuit on this model and others is more involved
I was hoping if anyone knows about this and how it works, can reply and let me know
I know this is an old model but I am sure there are people who still works on these or knows about them
I get 1.1v on the C7771 capacitor and will replace... -
by blazzeliaHi guys,
I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating... - Loading...
