lcd19-229 stand by light on and off
  • tonyuk
    • Feb 2014
    • 238
    Re: lcd19-229 stand by light on and off
    Originally posted by tom66
    Part # printed on device U7 please?
    the 8 leg ? number looks like ai A1C2857F GR8 09319 not sure if A1 OF IF ITS Ai
      OK please check voltages on: pin 2, pin 5, and pin 7
      Pins are counted as such, starting from dot:
      • tonyuk
        • Feb 2014
        • 238
        hi tom that parts is burnt would that be all that the problerm is ? if so do you have link for that as cant find a match
        pin 2 = 12.83 pin 5 =000 pin 7= 5. my dot is where pin 1 is
          It's actually AIC2857F. Is it physically burnt? Your results indicate it is not functioning, in the very least.
          One on eBay, they're about £5 each
          http://www.ebay.co.uk/itm/1PCS-Brand...item3cc84b952e
          but plan on about 2 weeks to get it from China.
          See diagram here:
          http://www.analog.com.tw/p2_6_detail...idTableName=05
          Pin 2: input voltage, this is OK (12V from PSU)
          Pin 5: output feedback, should be 1.25V - not OK indicating the output voltage is not present
          Pin 7: on/off command, it is >2V indicating the main board processor says "I want power" but converter does not function. (Like a light switch which is on but with a blown light bulb.)
          • tonyuk
            • Feb 2014
            • 238
            does look burnt when zoom in is that the only place i can get one lol
              From the pictures, it looks OK to me.
                Other places to buy
                http://www.ebay.co.uk/itm/ic-sop-8-A...-/400538572096
                http://www.aliexpress.com/item/AIC28...449252694.html
                BTW, dot always marks pin 1.
                • tonyuk
                  • Feb 2014
                  • 238
                  #28
                  ok thanks tom i will get there in the end but reading not my strong point
                  hence why i fit kitchens and build cars lol
                  • judamex
                    MacBook Air 820-00165 turns on But no green and orange light, not charge
                    by judamex
                    MacBook Air turns on without battery connected, no green or orange light comes on, I connect the battery and it shows battery with lightning and it restarts constantly.
                    03-06-2025, 03:55 PM
                  • MOSSEP
                    Monitor Audio RSW12 - Green light, but no sound
                    by MOSSEP
                    Hi
                    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                    I have already tried replacing all of the...
                    01-26-2025, 08:33 AM
                  • MOSSEP
                    Monitor Audio RSW12 - Green light but no audio
                    by MOSSEP
                    Hi
                    01-26-2025, 08:18 AM
                  • lcdcaps1
                    820-2610-A Sys onewire help, no green light. Please help from the gurus
                    by lcdcaps1
                    Hi
                    I have an 820-2610-A motherboard that has no green light.
                    I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                    From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                    The sys onewire circuit on this model and others is more involved
                    I was hoping if anyone knows about this and how it works, can reply and let me know
                    I know this is an old model but I am sure there are people who still works on these or knows about them
                    I get 1.1v on the C7771 capacitor and will replace...
                    11-06-2023, 01:28 PM
                  • blazzelia
                    MBP A1286 820-2915 green light only, no start
                    by blazzelia
                    Hi guys,
                    I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
                    09-30-2024, 07:20 AM
