Repair nightmare with Samsung LCD/LED experts pls help!
  • fabes253
    • Nov 2013
    • 5
    I have a Samsung UN55C7100 and I am in a repair nightmare. Please if anyone has knowledge I would greatly appreciate help.
    1st - One day the Panel went out, it had vertical lines through it. Samsung agreed to replace the panel so a technician came out and replaced the panel and F-Con board.
    2nd - A week later the TV died, apparently it was a power supply board. I ordered a new power supply board (refurbished) and replaced it myself, The TV worked for a week and then it seems like the power supply board went out again!
    Is this just my bad luck? Or is there something with the new panel that is blowing the power supply boards? Currently it makes a click sound like it does when it will come on, then you can hear a power sound like its trying to power up, and nothing happens. It repeats the click and power sound over and over.
    Re: Repair nightmare with Samsung LCD/LED experts pls help!
    Do you not have a lemon law in the states? Samsung should come out and replace that board, or offer you a refund / discount on a new TV.
    It's more likely you have a main board fault than a power board fault, IMO.
    • fabes253
      • Nov 2013
      • 5
      Well the TV is out of warranty by a year. Through my many complaints they finally agreed to replace the panel. They said they would not do anything else for me considering. Would a bad main board cause a power supply board to fail?
      • mmartell
        • Oct 2013
        • 3189
        Not sure on this model you would have to find the service manual or the field guide...
        Unplug cable from power supply to main board. Plug set in. Do the backlights come on ? If so suspect main board. If not suspect power supply or backlight system (leds).
        • Nicktronic
          Samsung Power Supply Board BN44-00874F
          by Nicktronic
          Hey everyone,
          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
          Anybody...
          03-17-2025, 06:20 AM
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
        • repair-it
          Need advice testing a samsung power supply board with scope
          by repair-it
          I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
          07-12-2025, 11:00 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
