Samsung LE40R87BD
  • ronhayes
    TV Engineer
    • Mar 2014
    • 458
    Samsung LE40R87BD
    Hi all
    Can any one help with this set?
    This Samsung lcd came in as a dead set I have changed all the usual cap in the power supply and upgraded them to 25v when changed set would still not power up, so carried out eprom reset by shorting pins 5/6 and eventually got set to power up.
    It came on with no picture although the back lights are working as screen lights up grey and you can see them on at the back of TV through various holes in metal covering.
    It has sound but no picture I have it connected to sky box via a scart lead you can hear the sound on all channels but no picture.
    I then sent for a replacement Tcon board but still no picture also when set is on after about 5mins it starts to switch its self off and on several times don't know if the switching it self off/on has any bearing to the no picture problem ?
    Any help would be much appreciated.
    Regards Ron
    Re: Samsung LE40R87BD
    Can you supply a picture of the T-con board?
    It is possible you got a defective board.
    • ronhayes
      TV Engineer
      • Mar 2014
      • 458
      Hi tom66
      Thank you for answering me hoping I can attach the pictures, here goes.
      Hope you can open these tom66 the one with orange label is replacement one without is the that was in set.
      Regards Ron
      • ronhayes
        TV Engineer
        • Mar 2014
        • 458
        Hi Tom66
        And anyone else who can help.
        Any more feedback on this set ?
        Regards Ron
          Sorry missed your post - have you checked the voltage each end of the fuse?
          • ronhayes
            TV Engineer
            • Mar 2014
            • 458
            That's ok tom.
            Not checked voltage but tested fuse while board was out and it reads fine not o/c .
              Check the voltage on each end relative to chassis, with TV powered, will tell you if main board is switching 12V/13V on (it is switched separate to the main rails.)
              • ronhayes
                TV Engineer
                • Mar 2014
                • 458
                I have 13v both sides.
                • ronhayes
                  TV Engineer
                  • Mar 2014
                  • 458
                  So main board is switching 13v ok ?
                  But still no picture.
                  • Kilroys
                    • Feb 2014
                    • 70
                    • Sweden
                    Eeprom IC 1803 is corrupt. Change it to a blank 24C256.
                    When you start the tv after you changed the ic it will
                    turn on and off two times. On the third you will get the picture.
                    You had to check the options in the service menu.
                    Inch Option and Panel Type.
                    • ronhayes
                      TV Engineer
                      • Mar 2014
                      • 458
                      Thanks Kilroys
                      I will source a Eeprom and install.
                      (can you just clarify your last sentence for me)
                      Do you mean when I have installed new eprom I need to enter setup mode by pressing info/menu/power then in setup pick option for 40" and lcd panel type.
                      Regards Ron
                      • Kilroys
                        • Feb 2014
                        • 70
                        • Sweden
                        Yes if it says 40", and 40AMLCD you need not do anything.
                        • ronhayes
                          TV Engineer
                          • Mar 2014
                          • 458
                          Hi tom66
                          You did not come back on the 13v findings ?
                            Your readings are indicating the main board is working, sending 13V to T-con. You can try checking AVDD on T-con next.
                            • paulnetv
                              • Mar 2014
                              • 22
                              • United Kingdom
                              Hello all. new here but looking for places to help others
                              Just a note on the 24C256 that needs replaced. I was once in this situation and replacing the Eeprom worked, but my 'customer' was in a desperate hurry and wouldn't wait for the postman, The world had ended since the TV was dead!
                              I took a risk, I 'stole' a 24C256 from a completely different set (Scrap board) on the off chance that it might work and sure enough it did! The Samsung fired up, found the chip, clearly it wasn't happy with the contents of the chip so it cleared whatever was originally on it then reprogrammed it right back up and the set worked absolutely fine!
                              This might just have been a lucky shot in the dark for me, but, if all else fails and you're in a desperate hurry and you just happen to have a spare used Eeprom handy, it might just be worth a try.
                              • ronhayes
                                TV Engineer
                                • Mar 2014
                                • 458
                                I am getting 14.7v there
                                • ronhayes
                                  TV Engineer
                                  • Mar 2014
                                  • 458
                                  Thanks Paul
                                  unfortunately don't have any used ones so have sent for some.
                                  But thank you for your input all helps.
                                  • ronhayes
                                    TV Engineer
                                    • Mar 2014
                                    • 458
                                    Tom66
                                    Is this voltage 14.7v at AVDD correct ?
                                      Yes.
                                      • ronhayes
                                        TV Engineer
                                        • Mar 2014
                                        • 458
                                        looks like T-con board working ok?
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
