Sharp Aquos LC-40UG7252E LCD TV burn in?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4330
    • Italy - Milan
    #41
    yes jona, since one of the pmic (the RT chips) shuts down then the rest is shut down also and no heat, i send you a pm..
    • jonah1024
      • Jul 2024
      • 44
      • Romania
      #42
      Originally posted by Diah
      then take the screen apart to check downside if there any leak of liquid... its just 40 no risk at all.
      This TV was never wet and stayed always inside. I really don’t know why there is corrosion on that inductor and only there 😵
      • jonah1024
        • Jul 2024
        • 44
        • Romania
        #43
        So the shut down happens on the ext PSU because there is no current limiting, and the tv PSU is limited so the pmic don’t shut down?
        • lotas
          • Jan 2016
          • 4602
          • Russia
          #44
          You have a bunch of test points with voltages on your t-con, and that’s where you need to look for faults (resistance and voltage relative to ground...).
          • Diah
            • Feb 2013
            • 6374
            Originally posted by jonah1024
            This TV was never wet and stayed always inside. I really don't know why there is corrosion on that inductor and only there 😵
            Man, i faced same issue on Hisense 40 panel with integrated T-con like yours... if you search here you will find the threat.. little old... first things i did inspect the screen downside.. when i was sure no issue it had... i fixed it with panel firmware.. this issue happened when the panel driver didn't order LCD cells to discharge.. .
            • jonah1024
              • Jul 2024
              • 44
              • Romania
              #46
              Originally posted by lotas
              You have a bunch of test points with voltages on your t-con, and that's where you need to look for faults (resistance and voltage relative to ground...).
              Here is an update with the voltages of the circles test points.
              VOFF_-11 -13.5 V
              VONE 30.15 V
              CPV1-6 3.17 V
              STV 0.0078V
              SEO_OUT 4.96 V
              VCC_3.3V 3.3 V
              VCC_F_3.3V 3.3V
              VCC_A_1.8V 1.8 V
              VCC_B_1.8V 1.767 V
              HAVDD 7.00 V
              HVIN_12V 12.02 V
              AVDD 13.98 V
              VCC_1.05V 1.014 V
              UH 13.5 V
              UL 7.8 V
              • jonah1024
                • Jul 2024
                • 44
                • Romania
                #47
                [CONT]
                Here are the voltage values:
                VOFF_-11 -13.5 V
                VONE 30.15 V
                CPV1-6 3.17 V
                STV 0.0078V
                SEO_OUT 4.96 V
                VCC_3.3V 3.3 V
                VCC_F_3.3V 3.3V
                VCC_A_1.8V 1.8 V
                VCC_B_1.8V 1.767 V
                HAVDD 7.00 V
                HVIN_12V 12.02 V
                AVDD 13.98 V
                VCC_1.05V 1.014 V
                UH 13.5 V
                UL 7.8 V
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4330
                  • Italy - Milan
                  #48
                  answer to post 38: yes
                  Avdd voltage is quite low, it's always on the 15-17v range, as i had already suspected
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4330
                    • Italy - Milan
                    #49
                    on the left of the.corroded coil you have 4 caps, what voltage there is on those?
                    • lotas
                      • Jan 2016
                      • 4602
                      • Russia
                      #50
                      VDA = Avdd = Vdda = Vsource = 13 to 20 V
                      VDA is around 14V~20V and this will depend on the design of the T-con board. The VDA voltage is generated by the DC/DC converter circuits. It is used to power the GAMMA circuits and reach the source driver board.​
                      • jonah1024
                        • Jul 2024
                        • 44
                        • Romania
                        #51
                        Will measure those caps as soon as I get back home from work.
                        what about HAVDD, is that ok?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4330
                          • Italy - Milan
                          #52
                          havdd is avdd / 2.. anyway let tv to cool down, turn on and fast measure avdd, if it lowers with the heat, that coil or the 4 caps has a problem..
                          • jonah1024
                            • Jul 2024
                            • 44
                            • Romania
                            #53
                            The caps measure 1.5V and dropping to 1.16V gradually and stays there .
                            The upper side of the inductor is wired on one side to this side of the capacitors. The other side measures 1.8V and dropping to 1.48V
                            The other rightmost identical inductor measures 12V on both sides and the capacitor row below it measures 14V (AVDD) and are stable
                            PS. I’ve sketched the connection on the picture attatched.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4330
                              • Italy - Milan
                              #54
                              Yes, i fogot that corroded L is for a buck regulator, so not for Avdd, the strangeness is that it seem more correct 1,2v than 1,5, that is probably the vcc for main chip
                              • jonah1024
                                • Jul 2024
                                • 44
                                • Romania
                                #55
                                what now? 🥹
                                Sharp replied today and sent me the latest mainboard firmware. I will attempt firmware upgrade again although I doubt that will fix anything.
                                [EDIT] Yup, nothing changed. I'm on v4.87 from v4.86
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4330
                                  • Italy - Milan
                                  #56
                                  The logic says the good is at 1,5v, then with the heat resistance rises and voltage drops to a bad value, try unsolder, remove and resolder that coil..
                                  • Diah
                                    • Feb 2013
                                    • 6374
                                    what now? 🥹
                                    what kind of theater of repairing panel LOL..
                                    please upload the complete firmware which sharp send you all files include the .txt one
                                    • jonah1024
                                      • Jul 2024
                                      • 44
                                      • Romania
                                      #58
                                      I doubt this is a firmware issue.
                                      But this is what they've sent me (it’s v4.87): https://we.tl/t-i9nIJ30OSb
                                      I also asked them what could case that color aberration and they said most likely it’s the LCD glass substrate. But why would it randomly return to normal after 2week of not being used?
                                      It’s frustrating cause I can’t find any similar symptom anywhere online.
                                      You Diah said that your Hisense had a similar problem, can you share how the panel looked in your case?
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4330
                                        • Italy - Milan
                                        #59
                                        Jona, i think you are a little smart enough to understand this is not a mainboard / software issue,
                                        1) panel stand alone = same fault
                                        2) heat related fault
                                        i'm very sad to read almost every day in this , FOR ME, good site with good technicians these fool ideas...
                                        so please ignore those advices.. i think we are close, i suggested recover oxydated components from the beginning, not much been done until now, only the eprom, it's not so risky task if you have hot air, c'mon let's pass to the action.. maybe i go to vacancy next week, i cannot be always online.. bye.. and good luck..
                                        • jonah1024
                                          • Jul 2024
                                          • 44
                                          • Romania
                                          #60
                                          I really appreciate your help and encouragement. 🙂
                                          I will proceed with unsoldering tonight when I get back home from work. Hopefully with a steady hand 😅
                                          Thanks!
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
                                          • thesharpfella
                                            Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                            by thesharpfella
                                            Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                            07-23-2024, 10:37 AM
