Sharp Aquos LC-40UG7252E LCD TV burn in?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4520
    • Italy - Milan
    yeah, i supposed this is a difficult case, not sure of any thing, but what about the others IC?
    correct myself: sure about this is a tcon/panel issue.. 80% sure this isa bad soldering issue.. continue diving into trouble and you'll get success.. turn on tv, wait fault to happen, take freezing can with little hose, spray very few on components one at a time starting with bga or qfn IC
    • jonah1024
      • Jul 2024
      • 44
      • Romania
      The two DC-DC chips I suppose? cause the main SAMSUNG chip on the Tcon board is protected by some kind of resin.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4520
        • Italy - Milan
        1) first photo i see spi rom quite distant from Samsung main.chip, appears not to be controlled by him, maybe Samsung is a CPLD and has its own internal memory, but since it is protected i guess it is not there the misfact
        2) chips Richtek RT6935 & 6939 are most suspected, both has probably internal registers, has also down side several tiny traces, one of them maybe for Gamma purposes, i would remove solder on those pins and put some other, starting with rt6939..
        • jonah1024
          • Jul 2024
          • 44
          • Romania
          I did the freezing can test with the tv in color test mode with no change in the aspect. I applied froze all the ICs including the main one, the DC-DC ones and the spi,
          1) I also did some continuity tests on all capacitors to see if anyone is shorted but not one is. There's only a ceramic part that's bigger than all capacitors but I think that's also an inductor (I marked it with an arrow). I also tested the inductors and all of them have continuity.
          2) What I also noticed is that one or two of the inductors is buzzing.
          The two inductors circled in red are the ones that seem to be buzzing, not sure if it's one or both since they're pretty close and touching them doesn't help distingusihing. The left beige ceramic one is silent.
          3) All the IC's (especially the DC-DC) are really heating up so that ipa evaporates almost instantly, is that normal? I don't have thermal camera unfortunately.
          I'll proceed with your next instructions with the RT6939 IC solder in the meantime.
          Thanks!
          I've attached some closeup pictures of the inductors, the bottom of the RT6939 IC and a video with the whole board closeup.
          Closeup Video: https://youtube.com/shorts/DMK1J5xcO0s
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4520
            • Italy - Milan
            Wait.. don't touch things now... the heating is a new element, also the oxydation i see.is.another element, take an external power supply and supply tcon with its 12v, quite probably power supply is feeding bad the screen, the piece marked with arrow in last pic is an inductor from a sm dc dc converter.. second possible answer, one of the choke inductors is badly oxydized and feeds badly the rest of the tcon (vdd signal, source voltage, maybe are suffering also source cofs and thats why discolorated image)
            • jonah1024
              • Jul 2024
              • 44
              • Romania
              #26
              Currently I made it so that the T-con is only receiving the +12V and GND lines from the LVDS (used tape). Is this ok? TV goes into color test loop if powered on.
              What should I do now? Try and desolder the corroded inductors?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4520
                • Italy - Milan
                #27
                what i clearly write, try esternal PSU to ensure internal one is ok, if same heating happens, that is not ok, then the fault is within tcon, second job try cure every oxydized part, don't know exactly how, try dry deoxy spray, for the truth i can't tell you all, also renewing solder joint is a second pass, try every inductor resistance, try freezing on them, locate the problematic one and replace it if needed.. my guess is this set is been outdoor for long and has severe oxydation on almost all the tcon, needs a special treatment, sorry i cant reveal all tricks now..
                • jonah1024
                  • Jul 2024
                  • 44
                  • Romania
                  #28
                  Used a separate 12V PSU and tapped into the fuse that normally takes the 12V from the LVDS and the DC-DC ICs and inductors still heatup .
                  I noticed that the color test mode doesn't start this way, only the backlight is on.
                  • Diah
                    • Feb 2013
                    • 6501
                    stop playing with panel t-con... yours issue at MB / Firmware section. show yours MB brand name.
                    • jonah1024
                      • Jul 2024
                      • 44
                      • Romania
                      #30
                      Hmm this is getting really interesting.
                      Mainboard is a T.MS6488E.U703
                      it has a MStar 6488 chip
                      • jonah1024
                        • Jul 2024
                        • 44
                        • Romania
                        #31
                        Diah
                        I upgraded the TV using the usb flash method:
                        (allupgrade_6488_NUX_U.bin and UMC_KMODE.txt) but after the upgrade the issue persisted. The firmware updated from V4.58 to V4.86
                        what firmware are you referring to?
                        Iona
                        • jonah1024
                          • Jul 2024
                          • 44
                          • Romania
                          #32
                          I really can’t fathom this:
                          If I power the Tcon with 12v from TV PSU I get the color test mode (burning mode)
                          If I power the Tcon externally, nothing happens on screen (only backlight is on which is wired to TV psu).
                          I’m using a 12V 3A power brick to power externally since I don’t have a proper lab psu.
                          I’ve checked the input voltage on board and there seems to be a drop to 11.8V or so. I then used a variable boost converter to get 12.2V on board but nothing happend.
                          • Diah
                            • Feb 2013
                            • 6501
                            this tell as i said T-CON and panel are fine... replace MB
                              • 12313
                              • U.S.
                              #34
                              Any guesses as to why the inductors on driver board are buzzing, do you think it's because something from mainboard isn't getting thru correctly?
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4520
                                • Italy - Milan
                                #35
                                Not much strange, the ext. psu has more current, tcon components can draw more current due to excessive resistance on oxydized parts, some IC has built in temp. guard and a error shut down happens.. the fault is oxydation as i have said..
                                • jonah1024
                                  • Jul 2024
                                  • 44
                                  • Romania
                                  #36
                                  Why though? 🤔 When the color test happens with the panel receiving only power and no data from mainboard, the defect is still there on all colors. To me this limits the problem to T-con… when T-con also receives data as well I get image, I can navigate menus and so, but everything is smudged as per pictures.
                                  I am trying to understand the process and logic. Maybe I wasn’t clear with some specific symptoms.
                                  Here is a new video with the defect. The background should be black and not tinted blue like that.
                                  https://youtu.be/NRPO67Wahj0
                                  • Diah
                                    • Feb 2013
                                    • 6501
                                    I am trying to understand the process and logic. Maybe I wasn't clear with some specific symptoms.
                                    this first time you mentioned the behavior of the screen same at standalone test... then panel issue or its driver at its T-con... try hard reset from service menu
                                    • jonah1024
                                      • Jul 2024
                                      • 44
                                      • Romania
                                      #38
                                      With ext PSU, only one of the DC-DC seams to be heating up, the RT6939 (if I remember correctly) and the inductor next to it. It might be that the other IC shuts down as you say?
                                      • jonah1024
                                        • Jul 2024
                                        • 44
                                        • Romania
                                        #39
                                        Already did factory reset from service menu. Also upgraded firmware, no change.
                                        • Diah
                                          • Feb 2013
                                          • 6501
                                          then take the screen apart to check downside if there any leak of liquid... its just 40 no risk at all.
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
                                          • thesharpfella
                                            Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                            by thesharpfella
                                            Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                            07-23-2024, 10:37 AM
