Sony Bravia KDL-37v5810 Power Fault
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Re: Sony Bravia KDL-37v5810 Power Fault
    I have a KDL40-W5810 in my room, could i use any boards from it to test in the 37 just to try find the fault or could this risk causing more damage??
      Do you also get 12vdc at the T-CON fuse? What happen if the T-CON board is not connected?
      • Easky15
        • Sep 2013
        • 285
        • Ireland
        no voltage at t-con fuse F1, When T-con is unplugged it is the same symptoms as when it's plugged in, Green light with no backlight..
          That means this now main board is also not sending the command on signal to the switched MOSFET on the main board that is used to supply the power to the T-CON either, sounds to me like your new board is not good either.
          • Easky15
            • Sep 2013
            • 285
            • Ireland
            Would it be safe to try the main board from a working kdl-40w5810 in this faulty kdl-37v5810 or is that a silly idea...?
            • mr. shr
              • Aug 2015
              • 24
              #26
              Hi All,
              I have the exact same fault with the exact same model (blank screen, green LED flashes on remote commands).
              Easky15 did you get any further with yours?
              I'm going to go through the trouble shooting guides on here and then try to perform the tests that budm suggests.
              • PopsCaps
                Sony Bravia KDL-40V2500 that will not power on
                by PopsCaps
                I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                I do not hear any sound and I cannot see any backlight.
                I have tried disconnecting every cable on each board one at a time to see if anything changes.
                The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                03-25-2025, 11:23 AM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • repair-it
                SONY Bravia OLED XR-77A80J will not power on
                by repair-it
                SONY XR-77A80J shuts off as soon as it is powered on. It goes into standby ok when plugged in but when power button is pressed, relay clicks and tv powers off. Power supply board makes a sound that sounds like momentary coil whine when it clicks off. The main board appears to turn on and has working optical.
                I pulled the power supply board for visual inspection & there wasn't anything obvious. I am not sure how to go about testing this OLED as it is a bit different than the last one (LG) I tried to repair. The only voltage listed on the PSU is 12v for T-CON. The 12v is not present...
                01-24-2024, 10:15 PM
              • SkishyIshy
                Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                by SkishyIshy
                Hey All,
                I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                03-17-2021, 11:44 AM
