4 red flash led 65X950G boot Sony and android logo but then black
  • Ihandyrepair
    • Sep 2017
    • 44
    HI guys
    I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
    here is the issue
    I have Sony and android logo. but then 4 led red flash lights front of the tv
    I have 3.3v ref. 12v reg then T con 12v when I press the power on button
    but then I get black screen and 4 red flash light at the front LED
    but I get 3 led flash on the LED driver board.
    I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
    so I tried Nick cheat, check the BL_ERR for power
    but I don't get any, is that mean the back light should be ok?
    so anyone know what is the 3 flash red led on the LED board?
    also what could be the issue ? main board?
  • Storyteller12
    • Jun 2020
    • 625
    Replace backlights. That’s what the 4 blink code is. Nicks cheat is just a workaround and not a permanent fix anyways
      • 12335
      • U.S.
      He/she has no voltage on bl-error pin, possibly the led driver board, can you check voltages going to and from it.
        • 12335
        • U.S.
        Post some straight on pictures of each board and one of the whole back as to see how everything is connected.
          • 12335
          • U.S.
          Check those 2 fuses on that led driver board if you have not yet.
          • Ihandyrepair
            • Sep 2017
            • 44
            Hi
            I Tried the nick cheap trick
            grounding the BL_ERR still same problem
            Fuse on the led driver board are ok
            • Ihandyrepair
              • Sep 2017
              • 44
              This board showing green led at start
              then 3 flashing red
              • Ihandyrepair
                • Sep 2017
                • 44
                sometimes after removing a board or disconnect all wires to the main board or LD board. and put it back,
                it will boot all the way to start up menu, to select the language. but only for few seconds then screen off and flash 4 led red on front of the tv.
                any suggestion? is the back light LED ? LD board ? or main board?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4562
                  • Italy - Milan
                  if you.are able it would be nice to check the SW inside LED board microcon
                  • Ihandyrepair
                    • Sep 2017
                    • 44
                    Looking online
                    it seems the led backlight might be the issue
                    but anyone know a tip to check on the LD board to be sure the led is drawing more or less power or voltage ?
                    I only seen tech showing 2 wires Sony tv backlights repairs
                    where you can check the power withdraw with tester
                    so you can most likely confirm the issue
                    haven’t seen any repairs tech online with LD boards diagnosed
                    also they showed BL_ERR voltage up
                    This tv doesn’t have BL_ERR with power so I am worryi take it apart and all led are ok
                    • Ihandyrepair
                      • Sep 2017
                      • 44
                      hey Guys and ladies
                      I got the tv working again. there is another BL_ERR trace from mainboard to LD board. so tv now works fine. but the LD board still flash 3 times red.
                      after tv is working I used YouTube to show white screen. and I can noticed a dark spot near the centre so that means there is 1 or 2 LED backlight burnt.
                      I guess this will be a future project. at least with this test. I can be sure what to order.
                      you heard most people with 4 or 6 Sony blink red. they have replaced boards and still same issue
                      and I was worry if I open the tv and the led was ok. then just wasted time. and specially with 65 inch screen I am worry about cracking the screen.
                      I had open and fixed few 50 or 55 inch by myself. with larger screen. better have help or have to make one of those suction cup with frame to prevent the screen flex too much and crack. I can't believe those tech who just use 2 suction cups for 65 or 70 inch to remove the screen. I just think if one of those cup looses the grip. that is it for the screen.
                      anyways with this test. I can confirmed what is wrong with this tv.
                      or wait until more LED fail. because with pictures or videos going on the tv. I don't actually see the dark spot.
                        • 12335
                        • U.S.
                        Sonys are strange, funny there was no voltage on your bl-error pin.
                        • Ihandyrepair
                          • Sep 2017
                          • 44
                          Oh just let explain
                          this tv has 2 line that are BL_ERR
                          one from main board to power bower
                          this one is more obviously marked on the power board
                          2nd one is no so obviously
                          there wasn’t any label
                          but there is another one from main board to LD board
                          I saw YouTube for older model
                          the tech grounded that trace and works
                          of course I had to double check
                          I was getting 3v on the 2nd trace from main board to LD board
                          but no voltage from main board to power board
                          it is not a constant 3v, it was more like tv was doing test and and sending 3v for couple of times and shuts off
                          after ground it
                          it works
                          just reminder it is only temporary fix
                          need to replace the LED strip
                            • 12335
                            • U.S.
                            Ok, that makes sense, was wondering if you were doing the grounding correctly, not easy trying to do things remotely without seeing things in person. If you turn the backlights down as far as you can and still have reasonable picture it will last longer, being they will not be working as hard.
                            • Ihandyrepair
                              • Sep 2017
                              • 44
                              Thanks for the tip
                              I always lower my brightness to 50-60%
                              most tv die because most owners turn brightness to 100%
                              imagine how hot it can get if running 100% oh a hot day
                              but don’t tell anyone
                              that way I can buy or get free tv to repair
                              haha
                                • 12335
                                • U.S.
                                Lol, I'll try to keep it under my hat.
                                • Storyteller12
                                  • Jun 2020
                                  • 625
                                  4 blink code is definitely backlights. I just fixed this same model with same symptom replacing backlights
                                  • Ihandyrepair
                                    • Sep 2017
                                    • 44
                                    I guess it is most likely to be LED backlights
                                    but I want to be sure before you take everything apart
                                    right?
                                    By the way did you replace all led strips or just burnt one?
                                    And where did you get them? Sony oem? Or online tv used parts?
                                    I am worry about getting cheap led that burnt quickly
                                      • 12335
                                      • U.S.
                                      The ground out proves a backlight issue, real pain digging to backlights on these but only way to fix a bad led. You seem to definitely have a backlight issue. Something for other cases is 4 blinks can also relate to a ld board issue so jumping right at backlights in those cases could be a lot of wasted effort if the problem is only the ld board, remember not to assume, need to test and troubleshoot.
                                      • Storyteller12
                                        • Jun 2020
                                        • 625
                                        In terms of troubleshooting you are correct and Sonys manual states that as well. Sony only tries that because the tech can change the boards. They never tear apart and replace backlights. They provide new panel with backlights and reinstall your old boards or replace tv altogether
                                        However I have fixed a lot of these Sonys and never had ld board be bad. It’s always the backlights
                                        • Teban1306
                                          [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                          by Teban1306
                                          Hello everyone!
                                          I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                          System Information:
                                          • Model: Lenovo ThinkPad T14 Gen 1
                                          • Machine Type: 20S1S4E600 (Intel i7 variant)
                                          • Current BIOS: N2XET42W (1.33) - Latest version
                                          • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                          What I'm trying to achieve:
                                          Replace the default "LENOVO" boot logo with a custom image during POST.
                                          🔧 What I've tried:
                                          09-14-2025, 11:49 AM
                                        • reassor
                                          Sony kd70xf8305 very very slow android logo with sound
                                          by reassor
                                          Hi.
                                          Power is ok
                                          Tv turns on by it self when you turn IT off with button or pług.it shows sony logo the android logo but with like 1 frame every 10 sec. Music starts after like 1 min. After some time logo will Just hang. But i can turn volume up and down on a pilote but its very slow as well.
                                          Should i force update? If so how?
                                          I did reset.
                                          Mainboard Looks pristine.
                                          Very wierd.
                                          10-30-2023, 05:59 AM
                                        • rvh
                                          Repairing a Sony KD-49X8309 tv (android boot loop)
                                          by rvh
                                          I got a Sony led tv, that's stuck in a boot loop. It won't go any further the android screen and won't turn on further. The indicator light turns up white, and then it comes in a boot loop
                                          It seems, that all of the Sony tv of this X-range will end with these problems after 2-3 years or so.
                                          Television
                                          Sony KD-49X8309c
                                          Main board
                                          1-894-595-12
                                          Y210B300c
                                          Sony BMFW
                                          Panel:
                                          SYV4941
                                          The problem is the mainboard. That's confirmed by Sony.
                                          After some googling, i came...
                                          02-26-2020, 05:53 PM
                                        • mauda
                                          Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                          by mauda
                                          I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                          Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                          05-21-2023, 11:56 PM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
