ps50q7hd
  • tonyuk
    • Feb 2014
    • 238
    ps50q7hd
    hi guys yes another tv lol just been giving this ps50q7hd now i cant get anthing from hdmi ive tried ps3 just get black screen if i try sky it comes on for 1 sec then goes of and says backup on sky any help ?
  • Dang
    • Aug 2013
    • 440
    Re: ps50q7hd
    Only a couple of things I can think of and that's to go into the service menu and look for something called HDMI MP DLY or very similar, it should be set to 9, if it's sky high HDMI ports can drop out altogether and won't show up, make sure it's set to 9 or 10, see if it helps, if not a board change might be needed.
    • tonyuk
      • Feb 2014
      • 238
      Re: ps50q7hd
      thanks how do i get into service menu ? i did try looking at settings but could not find anything for hdmi
      • sordids999
        • May 2013
        • 2154
        Re: ps50q7hd
        To access the advanced menu, you need to:
        Power off on remote.
        Press Info, Menu, Mute, Power in that sequence.
        This brings up the service menu.
        Please then proceed with care.
        Scroll down to each option in the submenus - do not use left/right arrow to navigate across the menu
        Press menu to return to the main service menu screen.
        make sure you right down anything you change
        • tonyuk
          • Feb 2014
          • 238
          Re: ps50q7hd
          ok im in menu but cant see anything for hdmi ? do i have to have this lead in from my sky box first ? many thanks guys
          • tonyuk
            • Feb 2014
            • 238
            Re: ps50q7hd
            ok still no joy finding anything for hdmi i done a reset on tv but still get nothing on hdmi ?
            • Dang
              • Aug 2013
              • 440
              Re: ps50q7hd
              Sorry, I believe it's option 2, will be HDMI HP DLY.
              • tw2005
                • Oct 2011
                • 6458
                Re: ps50q7hd
                I suppose you've tried turning both devices off, hook the cable up, turn TV on, turn source on then select HDMI source on TV? Check output resolution?
                That's all the ideas I have. I Did not see any special setting in the service menu.
                service manual
                9 HDMI/DVI IN
                - Connect to the HDMI jack of a device with HDMI output.
                These inputs can also be used as a DVI connection
                with separate analog audio inputs. An optional
                HDMI/DVI cable will be necessary to make this
                connection. When using the optional HDMI/DVI adapter,
                the DVI analog audio inputs on your TV allow you to
                receive left and right audio from your DVI device.
                (Not compatible with PC)
                - When connecting this product via HDMI or DVI to a
                Set Top Box, DVD Player or Games Console etc,
                make sure that it has been set to a compatible video
                output mode as shown in the table below. Failure to
                observe this may result in picture distortion, image
                breakup or no picture.
                - Do not attempt to connect the HDMI/DVI connector to a
                PC or Laptop Graphics Card.
                same from user guide
                HDMI/DVI IN
                (This will result in a blank screen being displayed)
                DVI AUDIO IN L/R
                - DVI audio outputs for external devices
                • tonyuk
                  • Feb 2014
                  • 238
                  Re: ps50q7hd
                  ok tried that and this is what i get see pic also on black screen theres another problerm as seen in next pic sparkles and bottom left looks like a logo ?
                  • tonyuk
                    • Feb 2014
                    • 238
                    Re: ps50q7hd
                    also in service menu 9 is blank ? also says hdmi calibration failure
                    • tw2005
                      • Oct 2011
                      • 6458
                      Re: ps50q7hd
                      No, service MANUAL paragraph 9. I'm just quoting the pubs. Sounds like you're in a calibration section which i would not mess with.
                      Just in case it was something simple.
                      • tw2005
                        • Oct 2011
                        • 6458
                        Re: ps50q7hd
                        Looks like it's working, HDCP not supported. One of the other guys is probably more up to speed but encryption issue i'm guessing?
                        • tonyuk
                          • Feb 2014
                          • 238
                          Re: ps50q7hd
                          thanks ive tried to reset tv but still get same probs so im now lost
                          • tw2005
                            • Oct 2011
                            • 6458
                            Re: ps50q7hd
                            You really need somone who is local or knows more. Not me.
                            Dug up this. Not sure if it helps any.
                            http://helpforum.sky.com/t5/Sky-HD-P...or/td-p/651768
                            • tw2005
                              • Oct 2011
                              • 6458
                              Re: ps50q7hd
                              I think the TV is fine, compatibility issue. I very much doubt any adjustment at the TV end will fix.
                              • tonyuk
                                • Feb 2014
                                • 238
                                Re: ps50q7hd
                                thanks but dont work with a ps3 or any other hd ?
                                also what do you think the prob in pic 2 is the tv had sparkles so i up the volts and got rid of most of them but still when on black screen is look like pic 2 ?
                                  Re: ps50q7hd
                                  This is a common fault with older TVs, and you can blame hollywood / copyright industry...
                                  They insist on encrypting the connection between the set top box/bluray and the TV because they don't want it to be copied. If the secret encryption keys used to encrypt this are compromised then the data can be copied. The keys are usually compromised after some time because people copy them and the standard is horribly broken allowing anyone who knows what they are doing to copy said keys after monitoring the HDMI data for around an hour or two.
                                  End conclusion is TVs that are older than a few years can have their keys revoked (banned permanently from showing HD content) and the boxes will refuse to send them HD content. Yes, this means any TV nowadays because it turns out once the signal reaches the main board it's completely unencrypted from main to t-con/panel/PDP... and there are full datasheets describing these formats in my signature for example and across the wider internet.
                                  Even though PirateBay and other sites are full of pirated movies, sports, TV, often less than two days after release - in other words, it's not making any difference - they continue with this "f**k the customer" policy.
                                  Only thing you can really do is get a "HDCP stripper" - like HDFury - but they cost a lot of money...
                                  NOTE: eBay has banned HDCP strippers because of the industry complaining, despite them not being very complex at all... the HDFury retails at $250 but looks to contain less than $10 of parts. http://www.3dfury.eu/images/hdfury2_5.jpg So if it were not for the 'bay banning them then you'd have cheap ones from China in no time... and the industry would hate for their broken, expensive standard (£1.50 per bluray player, £0.10 per disc, £3.00 per TV) to seem even worse!
                                  /rant
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Re: ps50q7hd
                                    Aging panel? I worked on one of these and had the same issue. Gradually got worse as it running on a black panel and I think with the blue screen on it was bad too in selected areas on the panel. I tried forever to adjust it out with little success. Was not too bad watching it normally.
                                    As for no PS3 or any HD, I don't have an answer but if the output resolution is correct for what the TV can process I'm at a loss but that message is probably being sent by the skybox and the image is good so something is working.
                                    Not something I've had to deal with.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Re: ps50q7hd
                                      /rant
                                      Nicely said
                                        Re: ps50q7hd
                                        Yeah, looks like panel aging to me. I couldn't get rid of it on my Q96 properly... luckily the Q96 was a freebie. I would never pay much for one of these sets, too many problems.
                                        Same cause as LG panel aging prematurely, but there's no firmware update for these...
                                        Notice the poor discharge on the gradients.
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • aliougm
                                          Marantz SR4003 AVR HDMI board issue, seeking for help
                                          by aliougm
                                          I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                                          Connection as below:
                                          Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                                          If I bypassed AVR then HDTV screen color be good.
                                          I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                                          3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                                          I replaced all...
                                          04-30-2022, 12:21 PM
                                        • japlytic
                                          Certain DisplayPort-HDMI cables can disable HDMI CEC communication
                                          by japlytic
                                          With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
                                          An examination of the HDMI CEC wiring...
                                          07-10-2022, 09:48 PM
                                        • spleenharvester
                                          Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
                                          by spleenharvester
                                          I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
                                          I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
                                          03-12-2025, 03:42 PM
                                        • RossMoodley1967
                                          LG LCD TV HDMI PORT FAULTY
                                          by RossMoodley1967
                                          LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
                                          02-28-2024, 08:38 AM
