Toshiba LED TV, blank screen
  • freakaftr8
    replied
    Re: Toshiba LED TV, blank screen
    Try heating the tcon board up underneath the metal cover.
  • MDluffy
    replied
    After power up, the big red toshiba letters come up fine, and they are on a light gray background (this has never failed...it always shows the red toshiba). After a few seconds the toshiba goes away, the gray turns to dark black. Used a flashlight and could not see any faint image or grayness at all...
  • selldoor
    replied
    If when it has gone dark, in a dull room can you shine a flashlight onto the screen from
    different angles to see if there is still a faint image.
  • MDluffy
    replied
    Re: Toshiba LED TV, blank screen [46L5200U1]
    Here are pictures of the boards. I could not see any obvious vented caps, or other damage. Thank you for any help you can offer. MDluffy
  • MDluffy
    replied
    My apologies, I thought I had put in the TV section.
    Thank you. Will try to by next weekend. MDluffy
    replied
    Please move this post to TV section, and also upload good clear pictures of the boards.
  • MDluffy
    started a topic Toshiba LED TV, blank screen
    To all:
    The TV was working fine, just over a year old. Turn it on one day and the screen is blank. Here are some observations. turn on tv, front small power on green light is on, the red toshiba name comes up and can see fine on a dark gray background. the toshiba goes away, and the screen turns from dark gray to black/blank. Can still hear sound, channels work, input selection works, on/off works, but screen is blank. Changed input to dvd (by guessing at the menu choice since screen bland...), same results. TV model is 46L52000U1. I've disconnected from AC (left for hours), and powered up again, same results. Toshiba forums say this is common, with only answer is to see a repair shop....My question is if someone can point me to a specific module or board that might be bad. I'm very willing to open her up and troubleshoot/replace parts. Thanks in advance. MDluffy
  • Mad_Science
    Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
    by Mad_Science
    I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
    03-01-2024, 05:05 PM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • Chrissygizmo
    Panasonic TX-48CX350B backlights but white screen , blank screen
    by Chrissygizmo
    Hi all, I’ve got a problem I hope someone can help me fixi.
    I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
    01-11-2025, 03:18 PM
    09-06-2024, 05:27 AM
  • dicky96
    HP Elitebook Screen blank - backlights but no image
    by dicky96
    Hi guys
    I'm trying to fix this laptop screen
    Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
    OK so I have the original screen which works but has lines across the bottom quarter of the screen
    I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
    04-28-2021, 07:30 AM
