Re: Toshiba LED TV, blank screen
Same model number as the OP?
I don't know, I am not familiar with these. Just going by what the others have said.Leave a comment:
Hi Agent24.
My tv has dim line 3.2 v at turn on then goes to .2 v .Is this normal?
The bl on has constant 3.2.
The regulator. You mean 24v regulator of psu? Or the one on green inverter?Last edited by hienton2; 09-11-2014, 07:04 PM.Leave a comment:
Pulling wires is not a proper repair. The circuit worked before without these modifications, something has failed and modifying things will not properly fix it. Do not expect these kinds of fixes to last in any case.
In post #32 electronicsurplus mentions a voltage regulator going bad. That would be my first part to check.Leave a comment:
I had 4 of these with the same problem , easiest way to fix is just pull out the yellow 15 wire as mentioned. fixed all 4.Leave a comment:
MDluffy, we never heard if you got the issue fixed on your Toshiba 46L5200U1. I am running into the same exact problem where I have sound and the Red Toshiba logo flashes on for a second then goes Black. I've tried the different "Dim" configuration mentioned above (cross 15 & 16; capping off 15; capping off 14) and have had no luck. It would be great to hear what the final diagnostic was cor your unit. Thank you!Leave a comment:
Are you talking about the wires/ribbons attached to the boards? That was the first thing I did was to disconnect, clean them off, and reconnect them. There was no change in the issue which prompted me to post in this forum.Leave a comment:
The wires can be reconnected easily. They have a quick-release. Try it.Leave a comment:
I downloaded and installed the firmware update and the TV worked great for about an hour as my kids and I watched a couple episodes of The Simpsons. I told my wife it was fixed, she came downstairs to see and it crapped out again. Dammit.Leave a comment:
Hi Folks...I picked up this same model through Craigslist last week knowing it had a very similar issue. The only difference is when turned on, i will typically get an image for a 5-10 seconds, then the screen starts flashing and goes blank. You can see the image but the backlight stops working. Audio continues to work fine. I can power the set off with the remote and immediately turn back on and the image will come back. Once in a while i can get the image to stay on for 30-40 minutes. I did a quick experiment by changing the input selection once the flashing started, and from what I could tell it did have some effect since I was able to continue seeing the menu image and the screen stopped flashing. Turning the input back to ANT/CABLE the screen would begin flashing again.
Certainly sounds like it could be a main board issue. Do you think the fix stated above would be helpful in my case? When the image stays on, the TV looks great and I'm hesitant to cut or disconnect wires that i wouldn't be able to reconnect later. Also, I hear so many horror stories of upgrading firmware I'm afraid to try itLeave a comment:
Or do the same on pin 14 ex_dim (External Dim) control signal line on that CN001 of the LED power supply board which is the same as pin 14 (DIM) of the connector P804 of the Main power supply board which is connected pin 15 of P802, the Dim control signal is just looped through the power supply board connectors.
On post 32 saying to swap the wire on pin 15 (DIM) and 16 (BL_ON: Backlights on), I do not believe that will not work because you need the BL_ON signal line to turn on the backlights circuits. The question is: Is the BL_ON or the DIM signal present or not? And is the EX_DIM PWM or Analog Dimming control signal?Last edited by budm; 07-07-2014, 05:45 PM.Leave a comment:
The above info was nearly correct. Pull the #15 wire and tape it off. (You can read the board code that says "dim".) Viola! I just figured this out today, and multiple tests show success.Leave a comment:
I have the same issue with my unit. The wire switch doesn't change the issue. Has anyone been able to get a straight fix for this issue or am I going to have to start fishing. ThanksLeave a comment:
In fact, this is a very common failure with a Great deal of LED TelevisionsLeave a comment:
We have had many successful repairs with this model
There is a failed Voltage Regulator on the Main Board which controls dimming feature But,
This problem can be very simply be repaired by crossing wires 15 & 16 on the connector from the Power Supply to the Main Board.
The TV will not have the dimming feature but, this can easily be adjusted in the Menu by selecting Dynamic Mode or, the mode which suits your taste
Alternatively, (IF you have the proper equipment) you can change the SMD Voltage Regulator
This is a very common failure in these Televisions
This fix applies ONLY to the set initially powering on showing the Red Toshiba Logo and fade to black
Hope this Helps
Aimee
Electronic SurplusLeave a comment:
All the parts I bought were second hand, but from "working" units...will try and look for a new PSU.Leave a comment:
Was the new PSU you bought brand new or 2nd hand? If it was brand new then probably something else in the TV is bad, if it was 2nd hand... who knows.Leave a comment:
5 for 5...when TV is on, screen blank but can hear sound and use controls - pull the AC plug, wait 2 sec, plug back in (nothing else) then the TV will come back on with screen working...if I cycle power with the remote control, it screen will not turn on....Leave a comment:
More than likely... I also found the setup that auto-shows in native format... seems like all the channels are now in HD and full screen... So yesterday, after an hour or so, the screen goes blank. Today, on power up it was blank (with sound and control). Cycled power twice with same result. New observation though... instead of using the remote power button, I unplugged the outlet from the wall and plugged back in... it came up fine!? Will try a few more times to see if this is a fluke or not. Thanks MDLuffyLeave a comment:
by Mad_ScienceI have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
03-01-2024, 05:05 PM -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM -
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
by dicky96Hi guys
I'm trying to fix this laptop screen
Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
OK so I have the original screen which works but has lines across the bottom quarter of the screen
I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would... - Loading...
