Toshiba LED TV, blank screen
  • Louis82
    • Feb 2012
    • 240
    Re: Toshiba LED TV, blank screen
    Hi budm. My tv without making any modification (disconnecting yellow wire or adding a resistor) already measures 3.5v on pin 13 LED driver board. Is that normal? In post #82 you mention that it measure 5v full backlight power and that you add a resistor to lower it down to 3.5v.
    I tried what you guys been doing here, disconnected yellow wire pin 15 and I added a 200kohm resistor and power goes down to 2.2v and the screen flashes and goes black. I added another resistor 280kohms 2.8v and same thing. Any input?
    Thank you
    • tibimakai
      • Jan 2012
      • 3680
      Mine shows 3.5V as well, at maximum brightness. With a resistor, I have dropped it at 2.8V.
      • Louis82
        • Feb 2012
        • 240
        Yeah I did that. Lowered down to 2.8v and screen flashes in less than a minute.
        • tibimakai
          • Jan 2012
          • 3680
          My TV, it was running OK for hours at a time, so yours may be in worse shape, then mine.
          Bud should chip in.
            Thank you
            But do the backlights stay on without any resistor, if not, then your LEDs are too far gone.
            • Louis82
              • Feb 2012
              • 240
              Tv stays on for like 2-3 hours without any resistor or modification, then it blacks out.
              Last night I went in to the customer menu and lowered down the backlight setting from 100 to 30 and stayed on all night. This morning I thought I could probably bump it up to 50 but it started flashing again so I left it on 30 and is playing fine.
              Would you say that my LED's are extremely bad ?
                Yes, they are in real bad shape. If if it cannot work at 50% then you have to change the LEDs or live with less backlights until it dies. Also tell the customer when they get new TV to lower the backlights level down as low as possible to extend the life of the LEDs. It does not look like no matter what brands of TV you buy, they all seem to have bad LEDs problems.
                  I have noticed this failure mode with LEDs before. I have had several 230V "GU-10" LEDs fail, these are small ones you get in kitchens etc. Normally 35-50W halogen but replaced with LED to save energy.
                  Usually they begin to flicker and pulsate before they go out for good. Always just one LED that dies in a chain of about 50 or so. Seems it might be a failure of the bond wires as it's some kind of thermostatic effect.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    You should take the screen apart and see, which one causes the problem.
                    • Treydogg77
                      Treydogg77
                      • Mar 2013
                      • 99
                      • US
                      #110
                      Re: Toshiba LED TV, blank screen Question For "Bud"!
                      Bud,
                      Where can a man find LEDs for this unit other than Fleabay? If anyone else has a line on these led or led strips feel free to chime in!
                      Thank you,
                      T-Dub
                      • Treydogg77
                        Treydogg77
                        • Mar 2013
                        • 99
                        • US
                        #111
                        Re: Toshiba LED TV, blank screen, LED Replacement
                        Okay I finally took the TV apart to see how many LED were out and it was one! What's the easiest way to remove one of these LEDs? I have a light strip from another TV that I can use to replace the LED. I am having trouble removing the led without damaging it. Check the pictures
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4953
                          • New Zealand
                          #112
                          That's what hot air rework tools are for.
                          You may also be able to do it with a heat gun on low from the bottom side of the board.
                          -David VanHorn
                            BTW, the LEDs in that Video are Dual-LED (two LEDs connected in series inside one package) that is why the Vf is so high.
                            • Sierra9093
                              • Sep 2015
                              tibimakai, if you could find the time, could you post a picture of your repair regarding the resistors. I have unplugged the #15 wire and now my set is working. But i would like to add the resistors if that will help the fix stay fixed longer.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                That TV is sold already.
                                All the info that I have, is in the thread.
                                  Read post 88 on up to see what we have done.
                                  • Sierra9093
                                    • Sep 2015
                                    Originally posted by bktanner
                                    The above info was nearly correct. Pull the #15 wire and tape it off. (You can read the board code that says "dim".) Viola! I just figured this out today, and multiple tests show success.
                                    Did this and it seemed to work, but for how long. Other post say this may bring other issues, like heating and such. There is a work around by placing a resistor from "pin 13" to ground. My question is what "pin 13", there are a couple on the board. A Pic of the work around would help.
                                    • Sierra9093
                                      • Sep 2015
                                      Hi, pulled wire on pin 15, and it worked. I would like to put the resistor workaround for the heat problem. I wish you would post a picture or a diagram of the resistor fix. Thanks in advance.
                                        LED driver board pin 13. look at the pictures in post 88, and read the rest of the threads.
                                        • vesterlee2008
                                          • Oct 2015
                                          • 13
                                          I have the same issue, I have no back light or any kind of lights coming on my tv. I cant even see the Toshiba logo unless I shine a flash light on it. I have sound but no picture unless I shine a flash light on it. Any help is needed. I have read every thread and not one them helped with my issue.
                                          • Mad_Science
                                            Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
                                            by Mad_Science
                                            I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
                                            03-01-2024, 05:05 PM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • Chrissygizmo
                                            Panasonic TX-48CX350B backlights but white screen , blank screen
                                            by Chrissygizmo
                                            Hi all, I’ve got a problem I hope someone can help me fixi.
                                            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                            01-11-2025, 03:18 PM
                                            09-06-2024, 05:27 AM
                                          • dicky96
                                            HP Elitebook Screen blank - backlights but no image
                                            by dicky96
                                            Hi guys
                                            I'm trying to fix this laptop screen
                                            Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                            OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                            I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                            04-28-2021, 07:30 AM
