Vizio V585-J01 dancing lines and image doubling
  • x_orange90_x
    • May 2015
    • 727
    I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
    Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
    Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
    I swapped the ribbons as well to see if it was a ribbon issue but the symptoms did not change.
    Attached are photos of the boards as well as the scaler for the left side
  • EazyBone
    • Jun 2023
    • 1351
    • United states
    Try tape method. My guess is panel because I have had something like this before. Check buffer board for Shorts
    • x_orange90_x
      • May 2015
      • 727
      I will check the caps for short. If I find one hopefully I can replace it. I plan to sell this set and if I successfully do the tape truck there would be visible signs in the image, right?
      • EazyBone
        • Jun 2023
        • 1351
        • United states
        You won't be able to sell this.. if tape works
        Tape will just show is a panel short usually without wasting a bunch of time, for me it does anyway. Since you got half a screen with lines probably is panel..
        Yes something will generally be off in the picture with tape. Tape isn't really a fix.. so ethically I cant sell them, so I just take the good parts and put em on ebay
        • x_orange90_x
          • May 2015
          • 727
          Ya that's why I'm hoping to find a bad capacitor or something fixable. If not oh well, parts as you said.
          • Diah
            • Feb 2013
            • 6403
            from yours photo of half panel disconnected you have the line s and clear white half screen... it tell the T-CON issue or ribbon cable damage
            • EazyBone
              • Jun 2023
              • 1351
              • United states
              As diah said, could be TCON. I've never had luck with TCON yet. Or ribbon that is.
              Where you located orange? You get quite a few tvs I've seen as well.
              • x_orange90_x
                • May 2015
                • 727
                I can rule out the ribbon as I already tried swapping them and the symptoms were the same. It would be nice if it were just a TCON. The way that the lines move and everything kinda morphs DOES look like a TCON issue.
                I haven't checked the caps on the scaler yet, but I will before jumping the gun and buying a board.
                EazyBone I live about 20 minutes northeast of Detroit.
                • x_orange90_x
                  • May 2015
                  • 727
                  I unlatched the left side ribbon and started wiggling it around and can get almost a full picture. As I said earlier, I did try swapping ribbons and still had the same result which is weird because this looks like a ribbon problem, or possibly a connection issue within the sockets?
                  Extra info: I blocked off the clock signals and get the image attached
                  Can clock signals be bad on the TCON side, or only the panel side?
                  • EazyBone
                    • Jun 2023
                    • 1351
                    • United states
                    You'll have to ask one of the more advanced people here I'm not sure. I've had a few Vizio's do something similar to this and I couldn't make it go any different.
                    • Diah
                      • Feb 2013
                      • 6403
                      panel fault , the dancing jumping of the image can be stopped but the lines will remain on screen by
                      try masking the first 3 pins on the left side of ribbon cable ( the one on your left hand when you looking from the back... and the first three will be the first lines on the left side of the ribbon cable..
                      if this not succeed do the same of the right side.instate of the left side.
                      i just got 2 sets yesterday Grundig size 50 same the T-con you have and same issue
                      • x_orange90_x
                        • May 2015
                        • 727
                        Update: messed around with this some more tonight and by taping off probably 10 or more traces I got a very nice picture with just a shadow banner across the bottom. However, after about 2 or 3 minutes it fades into bright purple and looks terrible. Turning the tv off and back on instantly restores it to just the shadow banner.
                        Is this the best I can hope to achieve with tape, or am I missing another pin somewhere that could prevent it from turning purple? Further, would this be an actual fault inside of the panel, or would a bad capacitor on the scaler board for that side cause this and be repairable if I could track it down and replace it?
                        • x_orange90_x
                          • May 2015
                          • 727
                          Any thoughts or opinions?
                          • Diah
                            • Feb 2013
                            • 6403
                            Originally posted by x_orange90_x
                            Any thoughts or orpinions?
                            how its possible when you want from a blind man to play soccer,,, yours TV a blind one LOL
                            • EazyBone
                              • Jun 2023
                              • 1351
                              • United states
                              My thoughts is trash it. Screen defects aren't worth the time. Probably a panel short. Small TV not worth much. Take parts out and trashola
                              • x_orange90_x
                                • May 2015
                                • 727
                                58" is SMALL??
                                So would the short literally be INSIDE of the panel? Or a shorted component on the attached PCBs? If I could just make it NOT turn purple anymore I'd keep it and use it for myself.
                                • Diah
                                  • Feb 2013
                                  • 6403
                                  58" is SMALL??
                                  from yours photo , remove the bezel you could find at the same place of the screen class have broken
                                  • x_orange90_x
                                    • May 2015
                                    • 727
                                    🤔 Would that really cause the color morphing AFTER a few minutes of being on and looking relatively good as in the first couple pics?
                                    I was wondering if maybe I covered TOO MANY pins with the tape.. like I said tho, powering off and back on instantly gets rid of the purple again for another few minutes.
                                    • Diah
                                      • Feb 2013
                                      • 6403
                                      color morphing caused by masking... i am talking above on the main problem post 1
                                      • x_orange90_x
                                        • May 2015
                                        • 727
                                        Oh. It's the same TV tho! No cracks as far as I know, I just haven't had a chance to really mess with it again until just recently. I cleared up the image using the tape method. It's just the grey shadow at the bottom now that eventually fades purple. I have maybe 10 or 12 covered, so I'm wondering if that's overkill and actually causing the purple to come in.
                                        Attached video shows the purple morphing in over the course of 1 minute.
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • brad2157
                                          Vizio E70-E3 Two white vertical lines
                                          by brad2157
                                          I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                                          Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                                          Replacement main board - Boots up fine, but starting...
                                          12-13-2021, 05:11 PM
                                        • viking509
                                          vizio e65 e3 LED tv color vertical lines center tv only
                                          by viking509
                                          I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                                          03-21-2023, 12:48 AM
                                        • rapid911
                                          Vizio M58Q7 colored horizontal lines
                                          by rapid911
                                          Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
                                          05-28-2023, 04:17 PM
