TCL 65C715 backlight issue
    You mean that the BL ON signal is not sent to the PSU by the motherboard.
    BL ON is not so easy to take, but measured it and was present.
    I'll take the requested picture tomorrow.
    Regards
      you are afraid of the glued screen..LOL.... i advised you to arrange space at your place and take out the screen and keep it in safe place,, to have access to BL to be sure of them before order..
        Several tvs have main board send signal to PSU for backlight. How are you certain this isn't that way. But understood on legend. If you don't believe that's a possibility then it's PSU and LEDs.
          I've checked that point and i have the signal.
          Please find attached the requested pictures Click image for larger version
ID:	3332913 Click image for larger version
            Yep i've in mind your advice, just want to avoid having the tv open for weeks, it takes a lot of space dissassembled
              So tried to desassemble it to confirm led strips références, and i broke the panel.
              End of the story
                Sorry to hear, we are a forum to help figure stuff out. Next time can ask for help on how to remove the panels like that I would of shared my knowledge on how to.
                Do you plan on still testing to see what was potentially wrong with the lights.
                  You've done all possible and i thank you for that.
                  It's my mistake, i was too quick in a corner and broke the panel.
                    Many many videos on backlight replacement on youtube, breaking a panel stings for a while BUT on the bright side, it was only a tcl.
                      Ahah it's my first panel breakage since my first repair.
                      Ot must happen at one time.
                      Bought it with backlight default, my pitty but no so much money loss.
                      I learnt so much.
                        Yea, I randomly do that also. But are you still gonna test the tvs lights or did you rage quit. I have done this also lol
                          Nope I'll not rage quit, I'll disassemble the whole tv to sell parts in order to reduce the price for this lessons.
                          I'll test led by led to found out the real root cause to confirm hypothesis.
                            Excellent. Those blue LEDs can be taken out and sold sometimes also, if they are working that is. My qn82raxxxx whole set is like $200 and had 48 strips. On eBay 4 strips alone sold for $50 so who knows. Right on
                              Originally posted by Cornito View Post
                              Nope I'll not rage quit.
                              don't forget to delete TCL from yours daily live dictionary
                                Ahah why?
                                  I've completely dismantled the TV to take parts that can be sold. It's a huge mess; everything is glued, so it's quite impossible to fix a backlight issue.
                                  I measured all voltages LED by LED. The LED tester shows 6V directly on the majority of the LEDs, but on some, for a few milliseconds, I can see 9.2V, 15V, or 153V before reaching a steady 6V.
                                  It's as if the internal resistance needs to heat up a bit before becoming steady.
                                  This could be the root cause leading to PSU protection mode.
                                  So based on that I don't think I'll sell any LED strip
                                    Greetings. How did you disassemble the display together with the frame? Thanks
                                      Finally it seems i found the LED part number: GIC65LB100_3030F2.1D_V0.7_20200108
                                      Found these on AliExpress :
                                      https://fr.aliexpress.com/item/10050...|query_from%3A
                                      On pictures i can now understand why i've got so many connector and same not at the same height on the same led strip.
                                      I hope this can help somebody,
                                      But these links on Aliexpress are for 75" TV
                                        I had to place a plastic card between the frame and the LCD Panel.
                                        The plastic card has to be thin as possible, and just sliding the card, you should be able to unglue the LCD-Panel from the frame.
                                        Be sure that the bottom frame is removed first, LCD Panel is covered in the bottom of the screen
                                          Try to search with the reference i've shared, Link may have changed
