iMAC A1418 Backlight issue
  • roman728
    • Jul 2018
    • 28
    • Slovakia
    Hello friends,
    I have this unit with no backlight on screen. After inspection i determined there is a shorted capacitor on BKL_BOOST circuit. I removed the capacitor, short is gone but backlight still not working. I found that Q9702 is not open and R9721 is only around 70kOhms but according to schematics it should be 301k. I removed the resistor and connected the gate of Q9702 directly to GND. Now i have 12v passing by the mosfet to turn on backlight IC LP8561 (U9700) but BKL_BOOST circuit is not working. I can measure only 12V there but it should be around 60V.
    Can you tell me what to measure next ?
    Schematics can be found here : https://www.badcaps.net/forum/troubl...90#post1031290
  • FriedFred
    • May 2024
    • 141
    I suggest to add those removed, damaged capacitors and not only just remove them. Usually, the boost circuit needs the capacitor to boost an input voltage to a desired output voltage.
    • Cornito
      Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
      by Cornito
      Hello Team,
      I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
      Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
      Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
      08-08-2024, 08:09 AM
    • cheebster
      iPad Pro 12.9 5th Gen Backlight Issue
      by cheebster
      Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
      Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
      Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
      The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
      Anyone...
      05-20-2025, 09:17 AM
    • Acnologia
      Lenovo Thinkpad T540P - Showing at 14" inch but NOT at 15.6" inch (Backlight issue) ?
      by Acnologia
      Hello to all members of badcaps.
      Another brainstorming that i have been messing with for months as a side project.
      Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
      I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
      Step 1.
      Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
      Machine > Doesn't give display it's really dim.
      Step 2.
      Use the same...
      11-05-2025, 04:02 AM
    • Cornito
      TCL 65C715 backlight issue
      by Cornito
      Hello team,
      I'm back with another topic.
      It's a 65C715 TCL tv with backlight issue.
      But the problem is a bit strange.
      When I took this tv from the marketplace backlight didn't work but picture was ok.
      Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
      Putting all back together the tv worked fine for weeks. => Contact issue??
      Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
      06-09-2024, 02:24 AM
    • Stephen
      iMac 27” 2020 Boot issue
      by Stephen
      Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
      08-16-2024, 09:32 AM
