My first plasma, RCA 42PA30RQ - Sound but no picture
  • lookimback
    • Aug 2013
    • 1489
    Re: My first plasma, RCA 42PA30RQ - Sound but no picture
    The RCA buffer isn't working either. Can't find a datasheet for the ICs. However, once I remove the two which had burn holes the short between the pads on the regulator went away. I'll post the resistance reading in about a half hour, when I get home. Also, I don't know if the regulator was bad or not because I cracked it while removing it.
    ------------signature starts here------------
    • lookimback
      • Aug 2013
      • 1489
      With the ICs removed, I get 3.189k ohms between the ground pad and and the pad closest to the diode (right side pin). With the ICs in place it was shorted.
      • lookimback
        • Aug 2013
        • 1489
        Finally got it working. Ended up replacing the X and Y mains and the Y buffer. Plus I converted it to a Samsung PN42C450B1D.
        • Jimmy60
          • Jul 2014
          • 17
          Can I ask a dumb question? When I check voltage coming from the power supply board I only get 3.2 VDC on the two VS check points. Does that indicate I have a power supply problem? Or is this a feed back voltage from the X or Y boards?
          Thanks for your help.
          Jim
          • lookimback
            • Aug 2013
            • 1489
            The correct voltage for VS should be around 207v. The panel sticker has the voltages on it. This would be with the PS on. I don't know what it would be when off. Make sure you have your standby voltage present and that you're getting a turn on signal from the main.
            • kissmedave
              • Aug 2014
              • 11
              I have the same rca and the same issue sound but no video.
              What board i supose to replace?
              • tw2005
                • Oct 2011
                • 6458
                Safest way would be to replace the X,Y and Y buffer boards all at once, unless you can work out what's good or bad but a few of us have tried the short cuts and ended up replacing the lot.
                The long way can be the cheaper way too, always a chance you put a good board in and it fails again because of the bad one you missed.
                I think Xmain is the main problem but can kill the ymain.
                I tried repairing the x and ended up blowing the y so i did the 3. The buffer was ok in the end but x & y were definitely shot.
                • kissmedave
                  • Aug 2014
                  • 11
                  Tw2005,
                  Thank you so much, i will replace all 3 like you said.
                  May you tell me those parts#? I will go ebay look for it.
                  • tw2005
                    • Oct 2011
                    • 6458
                    They are on the boards but if you go to Shopjimmy and type in your TV model itwill list the boards. You can find a few revisions like for the buffer but all work.
                    can't do all the work for you, best way to learn is to figure it out which you will.
                    http://www.shopjimmy.com/catalogsear...lt/?q=42pa30rq
                    don't think you'll find a firmware upgrade unless you contact RCA but the Samsungs did but obviously can not be used on this as the main board is not Samsung.
                    Worth looking around a bit before you buy but pretty cheap really $90, 3 boards and should be working again.
                    • tw2005
                      • Oct 2011
                      • 6458
                      PM sent
                      • kissmedave
                        • Aug 2014
                        • 11
                        Oh, man!
                        Thank so much, very cheap man!
                        I bought y & x to replace it first.
                        Not sure about y buffer board.
                        • tw2005
                          • Oct 2011
                          • 6458
                          Oh, man!
                          Well, your choice, y buffer may be ok, maybe not. But if it's bad and blows the y and then the X
                          • kissmedave
                            • Aug 2014
                            • 11
                            OK...I am not sure what is looks like for the y buffer, I need to take the picture in morning.
                            Earlier you have posted those link for me, there are 3 of y buffer and I am not sure which one to buy.
                            For the y & x board I had both pictures on my cell phone, not y buffer.
                            And the links you pm to me are broken, not woking (error 404).
                            can you tell me what p/n for they buffer?. I go back to main webpage to search for it.
                            Thanks again tw2005!!!
                            • tw2005
                              • Oct 2011
                              • 6458
                              they're in sequence so 739 would be the last 3 digits. Yeah i posted it then removed it and the site abbreviates it so you got incomplete link.
                              Sorry about that chief.
                              Pretty sure all revisions will work, I think there maybe 4, Rev A-D
                              • kissmedave
                                • Aug 2014
                                • 11
                                I already ordered X &Y on the way, I still looking for y buffer.
                                I will replace all 3 at same time, will post back later.
                                • kissmedave
                                  • Aug 2014
                                  • 11
                                  Thanks for your pm emailed to me. Will buy one y buffer, and post back after 3 boards are installed.
                                  • kissmedave
                                    • Aug 2014
                                    • 11
                                    I already received X & Y board yesturday, I don't want to try without Y buffer board.
                                    Like you (tw2005)said if the Y buffer bad will blow off the new X & Y board, Y buffer will be here next week for sure, because I ordered a day after X & Y board.
                                    I will update when I receive a new Y buffer board.
                                    • lookimback
                                      • Aug 2013
                                      • 1489
                                      If you go to shopjimmy, you can also find part numbers for compatible substitute Y buffers. They may look slightly different, as some have different capacitors and ICs, but they will work. I found the part numbers for a compatible substitute, then I searched eBay for those numbers. Found one for $18.
                                      In my experience with this TV, a bad X or Y main took out the buffer, but a bad buffer did not take out the X or Y mains.
                                      I had to replace all 3. I first tried just the X. The new one shorted instantly. I didn't care because I had already ordered the RJP30E2 and RJH30E2s. My intention was to refurbish them anyway. While waiting on those MOSFETs, I came across another TV with the same parts and broken panel, for $15 delivered to my door. It had a bad buffer, but good X and Y mains. I put them in and then tried both buffers with no luck. The one I ordered on eBay did the trick. When all was said and done, I had a working TV and 2 refurbished and working X mains which I sold on eBay. I came out with a profit and haven't even sold the TV yet. Right now I'm letting a friend's mom use it as a loner while I work on her TV.
                                      • kissmedave
                                        • Aug 2014
                                        • 11
                                        Hi lookimback,
                                        You are good on lcd tv, and I'm not.
                                        This is my first tv broken down, and thank a lot for your explanation.
                                        I have to buy all 3 samsung parts because my Rca built with samsung parts.
                                        Tw2005 PM me for the place to buy it is very good price, I bough 3 samsung parts less than $100.
                                        Thanks both of you for helping me.
                                        • lookimback
                                          • Aug 2013
                                          • 1489
                                          Trust me when I say this, you have 4 options for replacing the Y buffer. And they are all made by Samsung.
                                          These are the cheapest of each variation. The LJ92-01739C is the lowest priced and is from the same seller I bought mine from.
                                          LJ92-01739A
                                          LJ92-01739B
                                          LJ92-01739C
                                          LJ92-01739D
                                          All of those are compatible. The only differences are that some use electrolytic capacitors instead of ceramics, and ICs used may be a different brand. So they may look slightly different. But they will all work.
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
                                          • SluggerB
                                            LG Plasma (PDP50R10101) No picture No sound
                                            by SluggerB
                                            This is my first Craigslist freebie fix attempt. 50 inch LG Plasma TV Previous owner said over time it was struggling to turn on, it would take 4-5 times to turn on, the one day it just did entirely. I took it home and plugged it in, I her a click, then a second later another click, and nothing. Dead as a doorknob
                                            So I took the back off and check voltages. The power supply appears fine, I checked the VS, VA, and 5V voltages and they all measured correct, on the power supply board and on the display boards (Y and X boards). All the fuses are fine
                                            Following a YouTube videos...
                                            12-03-2022, 09:10 PM
