Rca RWOSU7047 No Picture
  • Helikvar
    • Jul 2018
    • 68
    Tv powers on and has backlights but no picture.All voltages from power supply to main board are correct.
  • Helikvar
    • Jul 2018
    • 68
    T-con voltages when powered on
    VIN12_1 12.1v
    V33M 3.3v
    V1D8 1.8v
    HVDD 64mv and dropping
    AVDD 1.2 mv
    VGHP 1.8mv
    VGL_GOP 56mv
    • EazyBone
      • Jun 2023
      • 1362
      • United states
      Try disconnect panel ribbon on buffer board, 1 side at a time. You have 2 orange ribbons at bottom of tv, do one at a time and plug in, turn on tv see if you get 2/3 of a picture on either side when doing this. Make sure to disconnect the ribbon from the middle buffer board to avoid shorting the ribbon cables when you turn on tv.
      • Helikvar
        • Jul 2018
        • 68
        Ok I did as you suggested one ribbon at a time and still no picture or 2/3 picture.
        • lotas
          • Jan 2016
          • 4835
          • Russia
          AVDD 1.2 mv
          VGHP 1.8mv
          VGL_GOP 56mv
          You do not have any supply voltage to the panel, check what the resistance is at these points relative to the ground, first with the panel disconnected, then with the panel connected.
          • Helikvar
            • Jul 2018
            • 68
            Panel disconnected
            HVDD to ground 10.5 megaohm
            AVDD to ground 38.3 kilohm
            VGHP to ground 62.5 kilohm
            VGL_GOP to ground 7.86 kilohm
            Panel connected
            HVDD to ground 136kilohm
            AVDD to ground 35.26 kilohm
            VGHP to ground 50.4 kilohm
            VGL_GOP to ground 7.81 kilohm
            While taking resistance readings the test points would either start higher and then decrease until leveling off or else vice versa.
            • lotas
              • Jan 2016
              • 4835
              • Russia
              The low resistance is not visible, what the resistance is rising and falling is that the ceramic capacitors are discharging and charging, also check these points with the connected panel relative to the ground and to each other.
              • Helikvar
                • Jul 2018
                • 68
                I checked those points indicated relative to ground and each other and they all read as infinity.
                . Does the t-con board itself monitor the panel voltages and shut them down due to a fault or does the motherboard do that.
                I believe the t-con board itself produces the panel voltages so is probably responsible for monitoring them and turning them on or shutting them down.
                . Is it safe to say the problem is with the t-con or panel as apposed to the mainboard or just to soon to tell yet.
                • petehall347
                  • Jan 2015
                  • 4448
                  • United Kingdom
                  is u403 cooked ? or is it just dirt ?
                  • Helikvar
                    • Jul 2018
                    • 68
                    It was just dirt .I cleaned it up and sent another pic.Its temperature goes up to around 46°C when tv is powered on for about 10 minutes .
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                    • maneatingmonkey
                      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                      by maneatingmonkey
                      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                      03-27-2024, 07:17 AM
                    • netgearnetgear
                      TCL 43S423 TCON OR PANEL FAULTY???
                      by netgearnetgear
                      Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                      08-20-2025, 06:04 PM
                    • Capacitorial
                      Powersupply has all the voltages - Monitor still no power
                      by Capacitorial
                      Hello guys,
                      I have a Philips 240B7QPJEB. The monitor seems completely dead.
                      I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                      On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                      The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                      The weird thing is, that the Power LED is powered over the TCON board.
                      On The TCON...
                      12-28-2024, 02:12 PM
                    • zesko
                      xps 9520 ribbon cable
                      by zesko
                      I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
                      There is 2 models, idk which one is needed on my laptop.
                      0xkvng
                      00vpr2
                      Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
                      Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
                      thanks...
                      10-23-2025, 05:03 PM
