Sony XBR-65X900E Static Lines
  • ChattFix
    • Oct 2021
    • 79
    • US
    Hey everyone, I have a Sony Xbox-65x900e with static lines. I’m assuming either the panel or t-con. Any suggestions before I start diagnosing? Service manual says T-con, panel, or B* Board (which I have no idea what that is)
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4540
    • Italy - Milan
    Xbox...ahah.. is it LCD, OLED? Has it good sound when RF input is present? It sounds mainly bad main board, do a screen self test with 12v jumper from PSB and MB lvds out detached
    • ChattFix
      • Oct 2021
      • 79
      • US
      Haha thats blasphemy! So I spoke to one of my guys in France and he stated it was FRC chip, I took a quick look at the service manual and I think its the MFC11. I found a listing on ebay that was a repair service for the main board and it had the picture I posted. I need more equipment for the SPI to flash these IC's but I dont have the income or time. So I'm going to replace the mainboard and I'll post my results.
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • iglitare
        by iglitare
        09-04-2025, 07:13 AM
      • ggil44
        Sony XBR-65X750D Horizontal lines bottom of screen
        by ggil44
        Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
        05-30-2023, 07:51 PM
      • Chrissygizmo
        Sony KD-55XG9505 lines on screen problem
        by Chrissygizmo
        Hello again everyone,
        This is my latest mission, to try getting this Sony tv back to normal working order…
        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
        02-19-2025, 11:31 AM
      • noisykid
        Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
        by noisykid
        5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
        12-30-2024, 07:15 PM
