lg42 lh2000
  • welshlad27
    • Jan 2014
    • 30
    lg42 lh2000
    hi guys i have got a 42lg lh2000 stuck on a red standby /power light ,
    i have replaced the psu 4 times and still no joy with it comeing on
    been told it cud be the av board or even the noise filter were the mains plugs in ne 1 have ne other ideas please
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: lg42 lh2000
    A pic of the chassis and the various boards would help....
    TELEFIX
    • welshlad27
      • Jan 2014
      • 30
      Re: lg42 lh2000
      pic of the chassis and the boards
      capture screen
      screen shots
      screencast
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Re: lg42 lh2000
        When you Try and turn on,--does the red-light go off--even for half a second?
        From turning mains on--does the red-light flash at all?
        Any flicker/life at all from the backlight when turned on?
        TELEFIX
        • welshlad27
          • Jan 2014
          • 30
          Re: lg42 lh2000
          no to all of that mate .its just stays a solid red /orange colour
            Re: lg42 lh2000
            What made you consider the power supply initially? Have you checked any of the voltages from the PSU board?
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Re: lg42 lh2000
              Sounds to me there's some issue with the mainboard....
              Whats its full number, I'll have a look on Monday--see if I have one, that chassis is pretty common, scrapped a few over the months....
              TELEFIX
              • welshlad27
                • Jan 2014
                • 30
                Re: lg42 lh2000
                thats what i was told by a tv tech that psu was the fault ,now it looks like its no the fault
                • welshlad27
                  • Jan 2014
                  • 30
                  Re: lg42 lh2000
                  give me 5 and ill get u main board model number
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Re: lg42 lh2000
                    Great!
                    BTW--Please could you use Full Words in posts as in 'You' not u,-- it can piss some guys off!
                    Back in work Monday, so I'll have a look--no guarantee I'll have the right one though.
                    TELEFIX
                    • welshlad27
                      • Jan 2014
                      • 30
                      Re: lg42 lh2000
                      ld91a/g
                      eax60686904(2)
                      09.04..09 n t y
                      • welshlad27
                        • Jan 2014
                        • 30
                        Re: lg42 lh2000
                        Great!
                        sorry force off habit .and thank you very much
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          Re: lg42 lh2000
                          I just brought home a very similar 37lh20 two days ago with the exact same problem. You can force the PSU on with two resistors to test the PSU and the inverter.
                          • welshlad27
                            • Jan 2014
                            • 30
                            Re: lg42 lh2000
                            im sure the 37 lh2000 is same boards in side .how do i do that please
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Re: lg42 lh2000
                              If I remember correctly, on my PSU, the connector that has the harness that runs from the main board to the PSU has a pin marked "on/off" and one marked "INV on". Run one 1K ohm resistor from the 5.2V pin to the "on/off" pin and the other one from another 5.2V to the "INV on" pin. Post a close up picture of that connector on your PSU. It needs to be clear enough to read the markings for each pin. One of us will tell you exactly how to do it.
                              This is from another TV, but it should give you the idea.
                              https://www.badcaps.net/forum/attach...6&d=1355670365
                              • welshlad27
                                • Jan 2014
                                • 30
                                Re: lg42 lh2000
                                capture software
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  Re: lg42 lh2000
                                  Yes just connect 500ohm to 1000 ohm resistors as JB1313 says
                                  Also we prefer pictures posted with "manage attachments" as in time yours will disappear making the post less useful for others in future
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    Re: lg42 lh2000
                                    OK, thanks for the pic. Like selldoor says, "managa attachments" is considerably easier for us to use. We can copy the pic and highlight areas for you if you use manage attachments.
                                    Back to the subject at hand. Plug the harness into that connector and unplug the other end from the main. If your set is like mine, there should be one blue wire and the rest in that harness are grey. Place the end of one resistor into the hole in the connector directly next to the blue wire. Skip two holes and place the other end of that resistor into the hole for 5.2V. Put one end of your other resistor into the third hole down from the other end in the same row. Put the other end into the hole directly above the hole that has the other resistor in it for 5.2V. There are four pins for 5.2V, you should be able to use any of the other three.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Re: lg42 lh2000
                                      Hope this helps
                                      • johnboy1313
                                        • Nov 2012
                                        • 1959
                                        Re: lg42 lh2000
                                        To be clear, the PSU should be mounted in the TV with all harnesses connected to it. Unplug the set from the power outlet before you start. Plug it in once you've used the resistors and the backlights should come on at that point.
                                        • madan1
                                          Modding HPF filter
                                          by madan1
                                          Hi everyone.
                                          Recently scored a dead amp from a mackie srm1801 subwoofer and after fixing it, now I'm thinking about a home cinema/party subwoofer project.
                                          Most likely I will use a 15" JBL woofer, which I already have and a diy box.
                                          After reading the mackie user manual, I noticed that it has a 40hz HPF (labeled as "36Hz BUTTERWORTH HPF" in the SM) to protect the speaker from low frequencies. Indeed this seems to be good idea for the intended usage - professional music subwoofer, but bad for movies, where one would expect to "feel" the SUBwoofer....
                                          09-24-2025, 02:06 PM
                                        • chopduel
                                          Bad mains power causing TV malfunctions?
                                          by chopduel
                                          I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
                                          Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
                                          • TV would randomly turn off then back on.
                                          • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
                                          • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
                                          12-29-2024, 03:20 AM
                                        • Califauna
                                          Help with boom box modification
                                          by Califauna
                                          Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
                                          I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
                                          From factory the specs of the boom box are:
                                          -Power Input: DC 5V
                                          -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
                                          -Drivers:
                                          -2 x Woofer, 70mm, 10Ω, 70mm,15W
                                          -2 X Tweeter, 8Ω, 30mm,10W x 2
                                          -Frequency...
                                          12-04-2021, 01:53 PM
                                        • cheese007
                                          Input Filter Filling: How to Choose Components?
                                          by cheese007
                                          Recently acquired one of those silly Logisys acrylic power supplies and lucked into getting one of the "better" ones (most of an input filter, bridge rectifier instead of 4 diode treatment, OK-sized heatsinks, etc.) and wanted to fill out what I can on the board + get some decent caps on there (especially the primary side since I highly doubt the ones in there are actually 1000uf). My questions are:
                                          1. How do I know what components to install re: the input filter? It seem to be missing an X cap, a resistor, and a Y cap.
                                          2. Where can I find a good heatsink for the bridge...
                                          12-06-2023, 09:59 AM
                                        • PennyLane
                                          Trying to locate a capacitor for a Skytec Crossover filter
                                          by PennyLane
                                          Hi
                                          I'm trying to locate what i believe to be Radial Electrolytic Capacitors 100v 82uf Non-polar for a Skytec Crossover filter.
                                          02-19-2025, 06:47 AM
