lg42 lh2000
  • johnboy1313
    • Nov 2012
    • 1959
    Re: lg42 lh2000
    If you're not comfortable with it, let me know. I'll force my set on and get clear pictures to show you how but it'll be in about six hours from now.
    • madan1
      Modding HPF filter
      by madan1
      Hi everyone.
      Recently scored a dead amp from a mackie srm1801 subwoofer and after fixing it, now I'm thinking about a home cinema/party subwoofer project.
      Most likely I will use a 15" JBL woofer, which I already have and a diy box.
      After reading the mackie user manual, I noticed that it has a 40hz HPF (labeled as "36Hz BUTTERWORTH HPF" in the SM) to protect the speaker from low frequencies. Indeed this seems to be good idea for the intended usage - professional music subwoofer, but bad for movies, where one would expect to "feel" the SUBwoofer....
      09-24-2025, 02:06 PM
    • chopduel
      Bad mains power causing TV malfunctions?
      by chopduel
      I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
      Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
      • TV would randomly turn off then back on.
      • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
      • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
      12-29-2024, 03:20 AM
    • Califauna
      Help with boom box modification
      by Califauna
      Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
      I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
      From factory the specs of the boom box are:
      -Power Input: DC 5V
      -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
      -Drivers:
      -2 x Woofer, 70mm, 10Ω, 70mm,15W
      -2 X Tweeter, 8Ω, 30mm,10W x 2
      -Frequency...
      12-04-2021, 01:53 PM
    • cheese007
      Input Filter Filling: How to Choose Components?
      by cheese007
      Recently acquired one of those silly Logisys acrylic power supplies and lucked into getting one of the "better" ones (most of an input filter, bridge rectifier instead of 4 diode treatment, OK-sized heatsinks, etc.) and wanted to fill out what I can on the board + get some decent caps on there (especially the primary side since I highly doubt the ones in there are actually 1000uf). My questions are:
      1. How do I know what components to install re: the input filter? It seem to be missing an X cap, a resistor, and a Y cap.
      2. Where can I find a good heatsink for the bridge...
      12-06-2023, 09:59 AM
    • PennyLane
      Trying to locate a capacitor for a Skytec Crossover filter
      by PennyLane
      Hi
      I'm trying to locate what i believe to be Radial Electrolytic Capacitors 100v 82uf Non-polar for a Skytec Crossover filter.
      02-19-2025, 06:47 AM
