AUO t-con - Help me identify and replace transistor please!
  • tn245
    • Oct 2013
    • 530
    Re: AUO t-con - Help me identify and replace transistor please!
    D812 is not short tom66.
    • tn245
      • Oct 2013
      • 530
      So tom66 after your hint about the boost converter not switching I figured maybe MOSFET Q811 wasn't getting the switching signal to it's base. I traced that back to U801 (see pic) which had been hiding under a thermal pad and I'm starting to suspect it may well be faulty. It is a BD8156EFV (datasheet attached).
      I'm not sure how exactly to test if it's faulty but it is getting 12V to VCC power supply input pins. Can anyone guide me on fault-finding for this IC? It's cheap enough to buy though will probably have to wait for delivery from China.
      • tn245
        • Oct 2013
        • 530
        A progress report.
        I put in the mosfet as suggested by T30M31, and replaced the BD8156EFV.
        Connected up the board without the panel connected and all voltages check out ok. Great!!
        But when I connect up the panel, I get no picture and the voltages change.
        Voltages without/with panel connected:
        AVDD 15.4V / 3.4V
        VGHC 24V / 28.3V
        VGMA_REF / 15.3V / 3.4V
        VGL -6V / -6V
        Without panel the pnp transistor I put in at the start of the thread has 15.5V, 14.8V, 15.4V (E/B/C). With panel connected collector drops to 3.3V while other pins stay the same.
        The panel is fine. It works with the other t-con I have, so there's still something wrong on this board.
        I will be testing more later, but any ideas would be greatly appreciated.
        • lookimback
          • Aug 2013
          • 1489
          You have a good board so you could compare readings of individual components between boards. Meter in ohms or diode test mode dependant on type of component. Find something that's significantly different, pull it and test it out of the board. I've had quite a bit of success doing that. I don't really have that much understanding of how a lot of this stuff works. I just learn it as I go.
          Also, if voltages are dropping when you connect it to the tv, it sounds like something is drawing the current to ground, or to somewhere other than it should be anyway. Still a shorted component somewhere. Did you notice anything hot after it had been connected to the TV for a minute?
          ------------signature starts here------------
          • T30M31
            • Feb 2014
            • 58
            Does the PNP transistor get hot with the panel connected?
            Have you checked R805, R806, C817, and C821? These all look like they are part of the Q812 circuit. It would probably be helpful to compare voltage readings on these components with the good TCON.
            The PNP transistor that you substituted may not have enough gain but that is only a guess since I don't know the specs on the original.
            The V0 boards looks like it used a zero ohm resistor/jumper at R807 in place of Q812. The Q812 circuit looks like it configured as a time delay circuit to sequence power.
            • lookimback
              • Aug 2013
              • 1489
              Voltage comparisons too, I forgot that one.
              • tn245
                • Oct 2013
                • 530
                Thanks for the replies guys.
                The PNP transistor is getting quite hot yes. Nothing else is particularly hot. The new ic is a little warm, but it had thermal pads top and bottom before which I haven't replaced yet so I think that is normal.
                T30M31, as the good board is the V0 board without that transistor, it's not possible to compare readings on those components as they are not present on the V0.
                Measuring resistance to ground from AVDD (collector of the PNP) it is actually just slightly lower on the good board.
                If the transistor doesn't have enough gain, would that be consistent with it getting hot?
                I'm tempted to try jumpering across R807 to cut out the transistor entirely and replicate what the V0 board is doing, just to rule out the transistor as the problem. Good idea or not?
                • lookimback
                  • Aug 2013
                  • 1489
                  Probably not. Might be other differences in the VO board that aren't physically aparent. That transistor doesn't necessarily have to be the faulty component. I had a main board recently which had a mosfet getting hot but it wasn't the bad component, the CPU was shorted to ground. It is going to be something on that path though. Something which comes after it I think.
                  • lookimback
                    • Aug 2013
                    • 1489
                    Since your voltages are normal until you connect the TV, I would suspect that the part of the circuit which is shorted is not completed until you connect the TV. Try connecting the board to the TV (with power off) and check for continuity between the pnp transistor and the connectors for the ribbon cables. If you find something with low resistance then check without the TV connected.
                    Edit: maybe not test between the pnp transistor and the ribbon cable connectors but actually trace the output of the transistor as far as you can and test from there.
                    • T30M31
                      • Feb 2014
                      • 58
                      Transistor gain would not be an issue with it getting hot. It must be something down stream of the transistor that is overloading it.
                      Probably not a good idea to jump around the transistor if it is overloaded. I would stick with resistance measurements of all that is fed by the collector of this transistor.
                      After thinking on it a bit more, the gain could be an issue. If the transistor is used as an on/off switch it may not be conducting enough to supply the load and this would cause excess power dissipation. If that is the case the jumper might be an OK test. Before trying the jumper I would compare the resistance from collector to ground on both TCON boards. Since the V0 board does not have the transistor measure from the pad where the collector would be connected.
                      If the V2 board has a lower resistance it is probably an overload condition. And as lookimback mentioned the TCON needs to be connected and power off when making this resistance check.
                      • tn245
                        • Oct 2013
                        • 530
                        That was my thinking T30M31 (re. your edit).
                        Resistance collector pad to ground V0: 5.5k, V2: 5.9k. So actually slightly higher on the V2 (bad board).
                        lookimback, I did the resistance check you mentioned before your edit, collector to ribbon connectors. Nothing was shorted/low ohms except where the AVDD connections are supposed to connect - same on good board.
                        I'll have to take a break until tomorrow on this one, when I will do more resistance checks and maybe try that jumper unless anyone thinks it's a really bad idea.
                        Thanks for all the help so far!
                          Transistor gain could cause it to get hot.
                          If the gain is too low, the transistor is no longer saturated and is acting as a fairly high impedance.
                          This means any current will make it heat up fast.
                          For example 30mA load, which would be a good guess for quiescent current on 15V, this would lead to a power dissipation of 0.36W ((15V - 3V)*0.03A) which in a SOT-23 package, with a thermal resistance of around 250°C/W, would heat the device to 90 deg C above ambient.
                          That's just an example. numbers are guesses.
                          • lookimback
                            • Aug 2013
                            • 1489
                            I wonder if it would be possible to convert this into a V0 board by removing the transistor and associated caps/resistors, and then adding the short chip? I suppose there is a possibility of other caps on the board having different capacitances. You could always compare the values between the boards though.
                            • tn245
                              • Oct 2013
                              • 530
                              tom66, that was my guess at what might be happening.
                              I think tomorrow I'll test it in a V0 configuration with the transistor bypassed. Otherwise I guess I'll be looking for an PNP with a higher gain.
                              • T30M31
                                • Feb 2014
                                • 58
                                It might be that Q812 is a P-Channel Power MOSFET instead of a general purpose PNP transistor. Something like an Si2369DS might work since it is designed for load switching.
                                I don't think there would be a great deal of risk in trying the jumper. You may want to remove the PNP transistor first. Anyone else have an opinion about this?
                                I just repaired the TCON in my KDL-40Z4100 and it was a version 3 board. If I get time tonight I will look at the photos I took of it and see if it has Q812 in a similar configuration. Maybe I can get some useful information from it.
                                • lookimback
                                  • Aug 2013
                                  • 1489
                                  Take a look at this. The part number is 25803. It's a V0 board but different configuration than yours.
                                  • tn245
                                    • Oct 2013
                                    • 530
                                    T30M31, thanks. So maybe I'll order some P-channel MOSFETs along with some higher gain PNPs to try out.
                                    Would any of these work for the MOSFET do you think? Since it'll be a lot cheaper and easier for me to order from cpc and they don't stock the one you suggested:
                                    http://goo.gl/dXR6F4
                                    The package body of the original part was a little chunkier than bipolars I've seen in SOT-23 and other transistors on the same board. Don't know if that means anything.
                                    lookimback. Wow, that's interesting. On that board there's the transistor AND the jumper effectively bypassing the transistor no? That seems odd. The part numbers don't seem to be very useful. I've seen the same parts on the same board versions with different numbers on them.
                                    • lookimback
                                      • Aug 2013
                                      • 1489
                                      I thought I might have solved it. Darn.
                                      • tn245
                                        • Oct 2013
                                        • 530
                                        Thanks for trying anyway. I had the part no as 25727. I think they're just in-house numbers. Anyway, the image encouraged me more to try jumpering the transistor which I will do in the morning.
                                        • lookimback
                                          • Aug 2013
                                          • 1489
                                          Yeah, the image pretty much shows it can be done.
                                          • elsomer
                                            help to identify transistor msi ms-15ck1
                                            by elsomer
                                            hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                                            02-17-2025, 05:30 PM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • Jean4634
                                            Help to identify destroyed transistor from a power supply's pool's robot KWADOO v.2
                                            by Jean4634
                                            Hi guys,
                                            Trying to repair a pcb from a power supply's pool's robot ( KWADOO v.2), i can't identify the burned transistor Q3.
                                            Could you help me ?
                                            Thks a lot
                                            Jean...
                                            07-25-2023, 08:10 AM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
