Cracked Screen plasmas and buffer/ysus board
+ More Options
Posts
  • Glitcher
    • Mar 2013
    • 673
    • USa
    I've come across cases where a cracked screen from a Plasma tv ends up shorting one of the buffer boards.
    Do cracked plasmas usually only short out the buffer board? What about the Y sustain boards?
  • tocold4u2
    • Dec 2012
    • 284
    • usa
    Re: Cracked Screen plasmas and buffer/ysus board
    i will say that its is usually buffers ..the x and y main. some. sets damage n short out more componets than others..
    • freakaftr8
      • Oct 2012
      • 3743
      Usually 3 out of 5 fail on cracked screens. Its a gamble.
        Newer panels. Not applicable for most older plasmas and also if the set was never powered up it does not apply.
        • freakaftr8
          • Oct 2012
          • 3743
          True. But.my assumption is based on the people around here that think a cracked screen will still work fine. And those people also should not drive or breed. Lol
            Yeah just needs some new plasma liquid m8 and she'll be good u can buy it from Tesco.
            • libyantiger
              • Dec 2010
              got one ...i picked from trash with small crack very samll ...trouble shooting reveals bad buffer i replaced with a one "also from trash believe it or not"
              the buffer was rusted because it was in recycle bin area
              i pick it up and clean it with thinner solution
              after immense cleaning i install it in tv and power up
              the tv worked with smeared picture
              shutwon it twice no problem
              i tried to reset one or tow of the ribbon cables
              when i fire the tv again it wont work ...the buffer got shorted again
              still though not sure if the buffer got bad because of bad connection or because of cracked panel loading it to death
                Cracked pane killed it, I have no doubt.
                • flocko
                  • Nov 2012
                  • 1121
                  • uk
                  Tom the plasma liquid used to be in the same aisle as the LCD/plasma crack repair glue,they was out of both on my last tesco shopping trip, just aswell I am not right out.still have half a tube of each if you need some
                    Oh is that right next to the headlight fluid and left handed screwdrivers?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      is that also next to the sky hooks and the skirtingboard ladders and also the tins of tartan paint.
                      • flocko
                        • Nov 2012
                        • 1121
                        • uk
                        They still had the sky hooks but only in the large size , alright for hanging out your washing on a windy day
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          lol when i was on a youth training scheme i was put at a tyre fitting station one day i was being taught wheel balancing and get sent too the shop for a long weight/wait lol you can guess how long i was stood there for as they had rang the shop first hahaha
                          • llonen
                            • Sep 2014
                            • 495
                            • hampshire
                            I worked for a long time at a micro electronics company test and inspection, when I started there they tried that with me, sent me to the stores dept with among other requests a long weight / wait. it was in the afternoon so I buggered off home for the rest of the day. Got back the next morning and when asked I produced the stores slip and asked "Long enough for you"
                            • odgaf
                              • Apr 2015
                              • 36
                              haha at the tartan paint i vaguely remember being sent for that when i was a kid lol, also the glass hammer, the tin of elbow grease, also i remember being sent to the bakers for virgin tarts and it took me a long time to figure our why i never got the same tart
                              sky hooks and long weights ahahaha i got some victims lined up for those
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                when when your young i guess you fall for these all i got to say revenge is sweet lol
                                • Ryan.man
                                  by Ryan.man
                                  02-04-2025, 12:23 PM
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                • Chrissygizmo
                                  by Chrissygizmo
                                  02-10-2025, 12:33 AM
                                • spice_disc
                                  Vizio TV M50-C1 reboot cycle and static on screen
                                  by spice_disc
                                  I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                  The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                  09-08-2024, 02:37 PM
                                • ipatch
                                  ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                                  by ipatch
                                  i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                                  08-24-2024, 02:36 PM
