they sound ok then (i was only asking as i had i strip in a set that was using more volts and amps i replaced that strip set worked fine) so oredered a whole new set maybe worth trying a replacement mainboard in yours set as new firmware not solving the issue.
JVC lt-32hg35e (Vestel) blinking LED
I noticed that the CPU is getting slightly warm, so it's an indication it's working.
I checked TP202 of short circuit protection while working and I measure 3V, is that okay?
Also, is it likely that the NAND died?Comment
I do this tomorrow and check it.
Will report back as soon as I can.
Thank you!Comment
It looks like 3V is missing.
I reflash the firmware, maybe I screwd up something.
Anything else I should check on the MB?Comment
let see what will happenComment
one things more... from the pdf it show there are other circuit LED driver boards work with 24V if this the case... the socket need to disconnect of 24V and turn on.. let see if it start with no BL..
also upload photo on the whole back of the Tv to see how boards connected togetherComment
I disconnected the LED driver board 24V connector and no effect, blinking led still.Comment
24v driver board plugged in and same symptom.Comment
i wrote the cable of pin 7 should slide it out from the socket ( take it out ) the 1KR connected to the pin in the socket and other end to any pin of 17-19-21
it look from yours photo you climp the 1KR to the end of the cable which it belong to pin 7..Comment
you are doing wrong..
I re-do it when I get to the TV.
Will report back soon, thank you!Comment
by unimatrix93Hello everyone, I have a constantly blinking Inexive LED TV.
Display is: VES390UNVA-2D-N01
Mainboard: 17MB97
PSU: 17IPS71
The TV power led start blinking constantly right after plugging it in, I tried to update via USB but did not help.... -
by KevinWysockiHi there,
My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
Flash upgrade didn't seem to work,... -
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by lapfixHello friends.
Hp elitebook 820 G3
Motherboard model : 6050A2892301 no schematics or Brd available.
Intel Core i5-6200U
chipset = Skylake
Ram = DDR4
I'm using SANDS-6050A2725001-MB-A01 BoardView for help
https://www.badcaps.net/forum/troubl...2725001-mb-a01
Power on but no display with average consumption = 0.127 amp
When i try to power off the lap responde to power button but... -
by France_53Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
- Loading...
