Philips PSU (715G7350-P01-000-002S) behaving funny
  • hervou
    Hervé
    • Apr 2024
    • 11
    • France
    I'm becoming crazy trying to fix the Philips TV of my old man (model 43PUS6201/12 - the TV, not my dad). I've read again and again discussions about this and similar TV models, on badcaps (thanks so much !). I see no other option than asking for your help.
    The symptom is simple : when I plug the power cord, the red "stand-by" LED does not light on anymore, and the TV powers-on neither with the remote control nor with the rear button. I guess at this point you immediately think at the 5V (or other voltage depending on the hardware) stand-by output...
    So, I disconnect the suspicious PSU from the rest of the system, I feed the board with 220V AC and measure DC outputs on CN9101. Notice here that I DON'T shortcut the 3.5/5V standby output with PS_ON in the first place, neither with a wire nor a 1K resistor. Therefore I'm expecting to see only this standby voltage and none of the 12V. Curiously I see the exact opposite behavior :
    - 12 volts on 12VA/16VA
    - 12 volts on 12V/16V
    - 0 volt on +3.5/+5V
    Well, I guess I must have misunderstood something. Anyway, measuring 0 volts on an output that should obviously deliver 3.5, 3.7 or 5 volts (*) leads me to think that the PSU is faulty.
    (*) : This detail is documented on page 34 of the Chassis service manual kindly provided by elektrotanya.com. I feel the doc is a bit unclear which behavior to expect with each of PSU variants 715G7350, 715G6973 and 715G6887. Not important actually.
    Then I chase leaking caps, smoked ICs and all, nothing obvious. Finally I play it humble and buy a replacement board at AliExpress (sorry...). But... I see the exact same behavior oin the new board (looking like a worked-on piece). I ask for refund, buy another one, same thing again. At this point I think that the main board might be damaged and shortcut this standby output voltage, and each time kill the PSU on first power-on. So, I should test output voltages before connecting it to the main board. I ask for refund again and buy a PSU. This time I test it carefullly. And... Same behavior again !
    I see only two possibilities :
    - I'm dumb and I've misunderstood something around how these outputs are supposed to behave
    - my karma is aweful, I probably was a serial killer in a previous life or something. And all these PSU I receive have a similar issue with this 3.5/5V.
    Then I've also measured voltages with PSU and mainboard connected :
    - I read a quite stable 0.8 volts on 3.5/5V
    - and a stable 0.56 volts on PS_ON
    - of course, 12V and 12VA outputs stay at 12 volts
    Not sure whether these measurements are meaningful, though.
    Thank you for reading, helping, advising and chiding
    Hervé
  • Diah
    • Feb 2013
    • 6499
    shows us please yours equipment that you used by measure volts..
    and check this ceramic cap if its broken from leg or had any sign of broken at surface
    • hervou
      Hervé
      • Apr 2024
      • 11
      • France
      Thank you for your help Diah.
      I've got only a low-end digital multimeter, brand "Lifedom" (photo attached). The battery is new and I use the same caliber "20V" to measure the 12V and 3.5/5V, so I guess there is no doubt on this particular caliber.
      Note : although I've had electronics courses I have no skill in understanding a power supply schematic or in cleanly unsoldering and testing components, that's why I have not tried to components (for example those contained in the famous "repair kit").
      Capacitor C9149 looks sane on the aliexpress.
      Out of curiosity I've had a look at the original board, and this capacitor was not soldered. I've noticed a couple of differences between both boards :
      - original board had no C9149, no FB9904 and no C9922
      - aliexpress board has neither L9301 nor C9309. And two more components are missing on the rear side : Q9107 and U9901.
      I have no clue what these differences imply !
      Cheers,
      Hervé
      • Diah
        • Feb 2013
        • 6499
        put the original PSU alone on table and plug it with main cord... just tell what do you have on this points black probe as yours DMM and red with V DC.
        • hervou
          Hervé
          • Apr 2024
          • 11
          • France
          Breaking news.
          Preamble : I remember having tried to understand the schematic to identify the possible faulty component. At some point I must have considered that the smart next step was to unsolder one leg of D9105 to test it. But as I've got neither a desoldering braid nor a powerful enough iron (and no experience in that field too) I've damaged the soldering point on the board (and I would probably have burned the diode if it wasn't already). See the piece of art attached. Now as you might see on the picture, in its "natural position" the cathode is unsoldered.
          Back to the present : in these conditions I check the voltage from the rear side of the PCB as you've asked. And I read 3.7 volts (!!!). Which I'm pretty sure I've never seen before.
          So, I plug back the main board to the PSU to see if by chance the stand-by LED goes to life. And... It does. Incredible. I quickly unplug the system (this diode obviously has a function, so having it removed can do some damage...).
          New test : I unplug the main board from the PSU and test again the voltage you asked while pressing on D9105 with some gear to have the cathode in contact. And when in contact the 3.7 volts disappears, I see 0 volt. I remove pressure on the diode, voltage comes back.
          Does this make sense ?
          Is it possible that the D9105 was a good guess and although I wasn't able to unsolder/test/solder by chance we are now certain it is the faulty component ?
          By the way this still doesn't make clear to me why the 3 chinese boards (!) have no stand-by voltage...
          • Diah
            • Feb 2013
            • 6499
            take out the regulator next to diode and check it in diode mode out side the circuit.
            • hervou
              Hervé
              • Apr 2024
              • 11
              • France
              You mean Q9106, which is a K22A10N1 mosfet (photo attached) ?
              I've soldered out (easier than the CMS diode) and tested as requested.
              I see no short between any of the gate, the source and the drain. Infinite resistance everywhere, even with the highest caliber on the multimeter.
              If I should order some units of this shottky, feel free to advise a brand / model. Then I'll just have to find a friend with the appropriate equiment (or try with my 30W iron).
              Thank you Diah !
              • Diah
                • Feb 2013
                • 6499
                measure it again to be sure i diode mode between source & drain.. it should read diode in one direction
                • hervou
                  Hervé
                  • Apr 2024
                  • 11
                  • France
                  [post edited, I've just got that a multimeter in diode mode displays volts and not ohms haha]
                  Ho yeah, right. I was in diode mode, but I didn't test both directions. Testing again I find infinite resistance everywhere except :
                  - red probe on source, black on drain : 0.9 volts drop voltage
                  - red probe on source, black on gate : 0.6 volts drop voltage
                  I've tested the nearby half-unsoldered shottky D9105 too, it shows 0 volts / 0 ohms in both directions. I guess there is no doubt that this one is dead.
                  • Diah
                    • Feb 2013
                    • 6499
                    yes replace it, its open... also be sure D9105 tested correct fine.
                    • lotas
                      • Jan 2016
                      • 4805
                      • Russia
                      If the probes are swapped, what will it show?
                      • hervou
                        Hervé
                        • Apr 2024
                        • 11
                        • France
                        Ho maybe I wasn't clear enough. Probes swapped gives infinite resistance / OL on both.
                        • lotas
                          • Jan 2016
                          • 4805
                          • Russia
                          This means the Mosfet is working and there is no need to change it!
                          Replace the Schottky diode.
                          • Diah
                            • Feb 2013
                            • 6499
                            then from where this result you stated LOL
                            • lotas
                              • Jan 2016
                              • 4805
                              • Russia
                              There is a diode installed inside the Mosfet, which shows the parameters of the diode.
                              • Diah
                                • Feb 2013
                                • 6499
                                but he wrote that he took the other one out and he did compare the test ...LOL
                                • hervou
                                  Hervé
                                  • Apr 2024
                                  • 11
                                  • France
                                  Well maybe I wasn't clear enough. I have tested both components (and did not compare results).
                                  - You advised to test the Mosfet, seemingly it is okay.
                                  - I've also tested the Shottky diode and it looks like this one is damaged - but actually this is obvious since my message #5.
                                  I just thought you were wondering if the damaged Shottky had also destroyed some neighouring component, which was a good thing to do.
                                  I replace the shottky diode and keep you updated. Thank you guys !
                                  • Diah
                                    • Feb 2013
                                    • 6499
                                    if the diode shorted then you must change the Mosfet too, doesn't matter what reading you have by test.
                                    • lotas
                                      • Jan 2016
                                      • 4805
                                      • Russia
                                      Well then, replace U9105 too for the collection, it controls this transistor.
                                      • Diah
                                        • Feb 2013
                                        • 6499
                                        U9105 are innocent ... the crime with tester. LOL
                                        • u666sa
                                          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                          by u666sa
                                          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                          Platform: ipa32 la-m024p rev 1b
                                          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                          I found a short on the other side:
                                          10-04-2025, 05:03 PM
                                        • supermattch
                                          HP 15dy-2021nr wont power on mystery volts
                                          by supermattch
                                          Hi everyone.
                                          I am diagnosing my personal laptop, because it wont power on and no leds light up.
                                          At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                                          Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                                          09-23-2025, 12:13 PM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
