LG 43LH510V Backlight problem
  • unimatrix93
    • Oct 2021
    • 343
    • MagyarorszĂĄg
    I'm trying to fix a small LG TV with wierd issue.
    So I check that the display is OK by fashing a lamp at the screen. LCD is okay OSD is showing up.
    Now since the BL is dark, I disconneted the BL from the mainboard and I injected voltage to it with my blacklight tester.
    The BL turns on, the tester shows around 80V. So the led strips are okay it seems.
    Now I started to suspect the BL driver IC which is a MP3378.
    I have a donor board (dead cpu) with the same IC, so I swapped the driver IC but it did not solve the issue.
    Some measurements:
    I read around 18.86V at the black light connector. With the BL connected and disconnected too.
    I checked the surrounding parts around the driver but I cannot find anything out of ordinary
    What do you guys think?😊
ID:	3255788Click image for larger version
    (Ignore the red and blue wire at the bottom of the left picture, its my benchtop PSU.)​
  • the Benninger
    • Nov 2022
    • 189
    • venezulan
    You could discard the source by jumping on it with a resistor, if it works you could discard the main board , I once saw it but I couldn't get information I'm sorry I hope this video takes you to the right path : https://www.youtube.com/watch?v=6hQOiN4-XPk
    • Diah
      • Feb 2013
      • 6365
      check pin 16 on the MP3378 if there are <5V
      • yokoono
        • Apr 2010
        • 485
        Even if the LEDs light up with the tester, you have faulty LEDs. Replace the strips.​
        • sickboy
          • Jun 2015
          • 86
          Agreed. The tester only supplies a limited current into the backlights. Some backlights will only fail under full current from their proper LED driver circuit.
          You could also check for a voltage spike at the LED output plug on the power supply as you turn the TV on.
          • EazyBone
            • Jun 2023
            • 1324
            • United states
            I have yet to find a set of LEDs that my led tester said were good and then turn on the TV and the LEDs don't work. Always been another problem not the LEDs. Only repaired about 100 sets of LEDs though.
            What is the legend for PSU to main board? There is a BL signal pin sometimes that needs voltage in order for power board to turn on BLs
            • Diah
              • Feb 2013
              • 6365
              this set doesn't have any power boards , it use external adapter AC-DC 19V. the signal you are referring go direct to the IC MP3378 , which it build in step-up circuit to feed LEDs, the MP3378 also have inside VOP to monitor the currents on LEDs if there are short or drop down then it will switch the step-up circuit off.
              • EazyBone
                • Jun 2023
                • 1324
                • United states
                Word.
                • unimatrix93
                  • Oct 2021
                  • 343
                  • MagyarorszĂĄg
                  i measure 12v on pin 16.
                  • Diah
                    • Feb 2013
                    • 6365
                    12V !!!!! the IC operate under 5V so the specification said... however LG use LED with zener protect diode build in.... you need to take the screen apart and test LEDs one by one with diode mode..
                    • lotas
                      • Jan 2016
                      • 4595
                      • Russia
                      12V !!!!! the IC operate under 5V .
                      Everything is correct on 16 pin and should be 12v (output power on 16 pin is set by a resistor divider).
                      • EazyBone
                        • Jun 2023
                        • 1324
                        • United states
                        Where do you get these schematics from?
                        • lotas
                          • Jan 2016
                          • 4595
                          • Russia
                          From the Internet and repair forums.
                          • EazyBone
                            • Jun 2023
                            • 1324
                            • United states
                            Well that narrows it down lol
                            • unimatrix93
                              • Oct 2021
                              • 343
                              • MagyarorszĂĄg
                              Turns out you guys were right about the backlight.
                              I ditched my BL tester and used my bech powersupply with 20V/0.60A.
                              Out of the three LED stripes the middle one had a faulty LED which only showed it's fault with the lab PSU, not with the tester.
                              Now I fixed the BL, but I wonder if I could increase the longevity of the LEDs bz decreaseing the current it supplyied by the TV board.
                              I'm not sure about which resistors should I remove. I cannot measure voltage on R525/8/6/4, so i don't think they are part of the backlight circuit.
                              • lotas
                                • Jan 2016
                                • 4595
                                • Russia
                                Increase the resistance of R508 a little.
                                • unimatrix93
                                  • Oct 2021
                                  • 343
                                  • MagyarorszĂĄg
                                  Thank you,
                                  I replaced R508 (5.6kohm) with a 8kOhm resistor.
                                  Current draw dropped from around 900mA to 700mA.
                                  • pnv
                                    tester driver led lcd tv
                                    by pnv
                                    How can we check or test the led driver of an lcd tv.Can a load proportional to the voltage and current drawn by the driver be connected? How do you proceed?
                                    02-22-2025, 05:21 AM
                                  • osrex
                                    LED DRIVER KEEPS DYING
                                    by osrex
                                    Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                    i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                    i have no datasheet at all for the LED lights, all i have is its length.
                                    long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                    as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                    05-05-2025, 03:36 PM
                                  • howardc64
                                    Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                    by howardc64
                                    Problem
                                    Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                    Model & Board Pics
                                    Conflicting Spec
                                    Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                    https://www.shopjimmy.com/vizio-gj-2k1...
                                    10-10-2024, 01:16 PM
                                  • charif
                                    Audio Driver for Thomson P14C4BK128
                                    by charif
                                    Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                                    I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                                    The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                                    Here are the details:
                                    • Model: Thomson P14C4BK128
                                    • Operating System: Windows 10 64-bit
                                    If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                                    Thanks in advance for your help!
                                    04-30-2025, 05:41 PM
                                  • bohaboha
                                    how to install gl usb2.0 uvc camera device driver on windows 10
                                    by bohaboha
                                    Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                                    but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                                    any help?
                                    01-26-2025, 08:33 PM
