How can we check or test the led driver of an lcd tv.Can a load proportional to the voltage and current drawn by the driver be connected? How do you proceed?
tester driver led lcd tv
If the TV is powering up. Then with the TV OFF disconnect the Backlight connector and set your DMM to 1000V and connect the Balck lead to the chassis ground or and metallic area and the Red lead to the +ve pin on the Backlight LED connector. Turn ON the TV. If the Driver is working the voltage would go to 300V and gradually go back down to 70V or 0V.
If that doesn't happen the Driver is not working. Hope this helps.
by osrexHello, this is my first post and im just a beginner, so be easy on me guy. thanks
i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
i have no datasheet at all for the LED lights, all i have is its length.
long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,... -
by howardc64Problem
Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
Model & Board Pics
Conflicting Spec
Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
https://www.shopjimmy.com/vizio-gj-2k1... -
by charifNeed Audio Driver for Thomson P14C4BK128 (Windows 10/11)
I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
Here are the details:- Model: Thomson P14C4BK128
- Operating System: Windows 10 64-bit
If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
Thanks in advance for your help!-
by bohabohaHello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
any help?-
by harpI am trying to find graphics driver for old laptop eMachine G725, for winxp 32bit... from data on internet, https://gadgetaz.com/Laptop/eMachines_G725--1942 it will have Intel GMA 4500MHD graphics, so I downloaded a few of them but nothing work, error say: this computer does not meet the minimum requirements for installing the software. So, please somebody help me to find bare minimum graphics driver to see non deformed screen anymore...
- Loading...
