Element Flx-3210 won't turn on
  • RoniRoni
    • Feb 2014
    • 19
    Re: Element Flx-3210 won't turn on
    I am not sure what pictures are going to do for you?
    • RoniRoni
      • Feb 2014
      • 19
      I hope this works.
      • selldoor
        Slow Learner
        • 7870
        They make me wonder too - I think I am going blind
        • RoniRoni
          • Feb 2014
          • 19
          I am looking for someone that has worked on this type of set before. I am looking for knowledge of the set on most of my questions. I can look at the board and see problem areas and I would have checked them out before joining this board.
          • jbofegs
            • Feb 2014
            I am experiencing the same problem RoniRoni has with this Element TV: Set worked fine for 5 years, then I used the VGA input. As soon as I removed the pc, tv screen said "no signal", then "powering down", and then never turned on again.
            Searching the web, I see this VGA issue is very common with this set. The question I have is (and I beleive what RoniRoni is asking also) Has anyone fixed a tv that died with the VGA problem? Was the problem in the power supply, or the main board, or the T-Con board? I am just trying to decide a direction to go, and determine if the set is worth fixing. Thanks.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              ^ Can you at least post clear pictures?
              • RoniRoni
                • Feb 2014
                • 19
                I have been testing the 37 pin D sub connector. I have been able to apply 5 volts to BL-ON and get the back lighting to turn on. I tryied applying 5 volts to power on and I get nothing. I also tested to see if this pin went high while touching the power button and I got nothing. Does anyone know what I should see at these connector points. I have a service manual for a FLM-2632 and it shows this connector. It seems to be the same as my model. Any input would help me out. Thank you
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  #28
                  Sounds like maybe the VGA is somehow corrupting the firmware of mainboard.....
                  TELEFIX
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    Ronironi, read through other posts and see how others are putting their posts together. Nobody is going to give you any help unless you answer their questions without attitude and post clear pictures. If you're as helpless as you seem, it might be pointless anyway.
                    • RoniRoni
                      • Feb 2014
                      • 19
                      Thank you for your help I don't want to be part of a board that acts like this. Other forums that I have been part of have had people on them that would try and help others. If I knew what I was doing I would not have come to this forum. Once again thank you to everyone that tried to help me. Its to bad there are a few on here that cause people to not want to be part of it.
                      • pajdek
                        Lenovo Y700-17ISK turn on and off
                        by pajdek
                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                        09-20-2023, 02:49 AM
                      • ThetraXXL
                        LG OLED C1, SOS-Turn Off, Stand alone test
                        by ThetraXXL
                        Hello guys,
                        I recently picked up an LG C1 in 65 inch size. Previous owner told me that the TV wonβ€˜t start, so I did believe due to PSU issue, but not this time. I could narrow it down to the T-Con or Panel.
                        PSU and Mainboard work both like intended, all Voltages available, Optical on when T-Con lower Ribbon is disconnected and I even managed to get some picture with P-Only, IN-STOP cycle but only for 2 sec. before shutdown.
                        For the stand alone test the panel starts with some flashing horizontal white lines and then continues to build up some color on the...
                        10-29-2024, 10:33 AM
                      • RdeveLabs
                        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                        by RdeveLabs
                        To all the members here...
                        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that β€œmaybe” you know how to solve this problem.
                        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                        05-05-2025, 04:59 AM
                      • masoksian
                        Dell latitude e7470 not turn on .power buton on off and Run Power problem
                        by masoksian
                        I am dealing with the problem of turning on and off my Dell e7470 notebook.
                        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                        The system does not turn on, there is no post.
                        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                        The problem continues in the same way.
                        I tried to turn on the Fn key, nothing came to the screen....
                        02-15-2025, 12:08 PM
                      • dqtech
                        lenovo x240 nm-a091 wont turn on
                        by dqtech
                        i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                        board number VIUX1 NM-A091 REV:1.0...
                        02-07-2024, 01:57 AM
