Can I fit a UE49MU6470 Diffuser into a UE49NU7100K?
  • fuus
    • Jun 2012
    • 123
    • England
    Evening all,
    Long time no post!
    I have a UE49NU7100K here with the classic melted diffuser and damaged backlight from getting too hot. Locally there is a UE49MU6470 available which I could pick up to replace the melted diffuser. Would this work or am I missing something? They look like the same style of backlight.
    If this sounds good, where is the best place to buy a new backlight? Will I regret buying from Aliexpress?
    Thanks in advance for any help
  • fuus
    • Jun 2012
    • 123
    • England
    Originally posted by Storyteller12
    Re: Post your Samsung NU model series backlight failures and diffuser melt-downs here
    I got one of these today un55nu6900 and threw it in the corner to clean out some old junk TVs. Then I had the idea to try and use a different frame and backlights since these keep having the same problem.
    Long story short I used the chassis and backlights from a un55mu6300. Put the screen in and main board from the nu series and powered it up. Works great and no longer have to worry about the backlights burning out and cracking/ melting the diffuser.
    This won’t help most people but any techs/ shops with TVs that have broken screens might find it useful.
    Yes, the mu is full array so different setup as the nu is edgelit
    Some useful information narrowed down, but the pictures I'm looking at of the stripped MU look like an edgelight.... Further research required. Thank you Storyteller12
    • EazyBone
      • Jun 2023
      • 1348
      • United states
      I transplant diffusers all the time. The new one(hope it's free) could have same melter diffuser without knowing yet either. Also sometimes the thickness of the diffuser changes. Those look like European models but the nu6000 and nu7000 here from like 2018-2020 roughly in US are basically the same, some RU series etc also. I'm sure you'd have luck. All the dimensions length and width are the same here, only the thickness is different. I've also used slightly thicker diffusers then original and all the side snap pieces went down no problem with the height difference.
      Edit also for the post above, I have gotten TVs that had good backlights and bad panel and instead of changing the diffuser sheet (never goes back together easy) I have transplanted the screen and boards only. The frames were exactly the same so I could transplant the boards etc. I feel once you take off the diffuser frame that's where all the problems start also. So if you can get away with doing that, I prefer this method. It's not "new backlights" but it's ones that still work. Either way this at least worked for me.
      Funny enough though!! I did this one time and the original frame had a 2 blink reboot panel. I transplanted a new screen and boards to this frame and 1 week later the NEW TV had 2 blink reboot panel. Could of been a coincidence but thought I'd share that
      • fuus
        • Jun 2012
        • 123
        • England
        Cheers EazyBone but it looks like the MU range I was looking to transplant have a different style of backlight - full array, i.e. from the top & bottom rather than just the bottom. I am hoping to hear from Storyteller12 as it sounds like has successfully transplanted a MU backlight onto an NU screen, but this could well be outside my skillset if it requires significant work
        Otherwise it looks like a new diffuser is available for roughly £20 delivered as option 2 https://www.sos-parts.com/diffuser-t...8a-123726.html
        • EazyBone
          • Jun 2023
          • 1348
          • United states
          OMG if it's that cheap. You need to order it. Ive transplanted a MU and a NU and both were edge lit. But yes I see his model is a full array. I've pulled apart many full array and they aren't even close to an edgelit diffuser so I wonder the same question.
          Save yourself a headache and order a new one if it's that cheap
          • fuus
            • Jun 2012
            • 123
            • England
            Thank you EazyBone. If you're also replacing the backlight on these models is it worthwhile paying a premium for some sort of nicer part? Or will a cheap chinese one do the trick?
            • EazyBone
              • Jun 2023
              • 1348
              • United states
              In my personal experience, you can't tell what's a more premium part. I'm pretty sure all of the lights come from China and are machine built.
              I have only been doing this about 8-9 months now so I don't know how long they would theoretically last. So far I bought 3 strips of LEDs from shop jimmy. One set was faulty. I bought about 40 from ali express, 1 was defective after a month. I bought about 60 from eBay. None have broke yet, although eBay/aliexpress sellers are likely the same. But this only assumes my customers reached out to me again, potentially more broke and no one has wrote back. Maybe lotas, diah, Davi or storyteller have a better answer
              • fuus
                • Jun 2012
                • 123
                • England
                There are two different diffusers listed as available for this model - BN61-15664A & BN61-15658A - if I disassemble mine is this part number etched into the diffuser somewhere? Or is there another resource for finding which would be the correct part?
                Thanks in advance
                • EazyBone
                  • Jun 2023
                  • 1348
                  • United states
                  Whatever link you put says it's compatible with your tv so likely it is. Samsungs tend to have many compatible parts for same TV. I cannot say 100 percent, but if the website says it's compatible and it isn't, wouldn't you be able to just get a refund?
                  • fuus
                    • Jun 2012
                    • 123
                    • England
                    You make an excellent point - I'll order the cheap one.
                    In case anyone was in doubt....
                    Melty melty Click image for larger version
Name:	20240405_193252 - Copy.jpg
                    • EazyBone
                      • Jun 2023
                      • 1348
                      • United states
                      Just make sure after you install the diffuser/lights and push down all the plastic edges that you plug it in. If any raised spots are on the frame or not pushed down enough it will show as bright spots on bottom of screen. Make sure you disconnect main board from PSU before you plug it in so that it turns only lights on
                      • Storyteller12
                        • Jun 2020
                        • 624
                        Eazybone the mu series that are edgelit are the 7000 series and higher. The 6000 series are full array.
                        you can put the nu series screen in the mu series chassis but you need to use the mu chassis power board and nu mainboard.
                        also I think I needed to extend the wires for the power button. It’s a slightly different button on the mu chassis but everything worked when powered up.
                        • fuus
                          • Jun 2012
                          • 123
                          • England
                          Thanks for coming back both. Sale of the MU unit fell through so I've gone ahead and ordered a new diffuser and backlight - total cost £32 delivered. Lets hope that sorts it
                          Storyteller12 I can see why you are so anti repair on these units - awful design - but the set is going to be for personal use and I'll just set the backlight on a low setting
                          • fuus
                            • Jun 2012
                            • 123
                            • England
                            The ordered diffuser turned up and it's the wrong one so I'm looking at other options. There is a smashed UE65AU7100K locally - is this edge lit or something else does anyone know? Cheers, Rufus
                            • fuus
                              • Jun 2012
                              • 123
                              • England
                              Answered my own question - AU seems to not use edge lighting https://www.aliexpress.com/item/1005005628342872
                              • Storyteller12
                                • Jun 2020
                                • 624
                                My research shows that model ue65au7100 is edgelit.
                                however I’m in the US and they do not make this tv here. We only have AU8000. But the au8000 is edgelit also
                                • lotas
                                  • Jan 2016
                                  • 4665
                                  • Russia
                                  AU8000 has edge lighting (Edge LED)
                                  , and AU7100 has a regular one (Direct LED). https://www.ebay.co.uk/itm/126305819263
                                  • fuus
                                    • Jun 2012
                                    • 123
                                    • England
                                    Thanks both. I've found a smashed UE49MU6220K a bit further away, but the seller wants silly money for it. Might have to bide my time until something smashed comes up!
                                    • fuus
                                      • Jun 2012
                                      • 123
                                      • England
                                      Right I've picked up a UE49NU7172U for £10 to use for parts for this. The screen was smashed so initially I have disassembled the TV to check it's backlight is all working correctly and....
                                      Has the broken panel somehow leaked into the diffuser? Or does it just need carefully wiping clean? I have the bulbs here to do the backlight so that should be simple enough
                                      This is turning into more hassle than it's worth!
                                      Click image for larger version  Name:	20240423_203251.jpg Views:	0 Size:	1.41 MB ID:	3258470
                                      • EazyBone
                                        • Jun 2023
                                        • 1348
                                        • United states
                                        Something leaked onto it, water or some liquid. Does it wipe down? Would definitely try that first.
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • mrsith
                                          Samsung UE49NU7100K melted diffuser
                                          by mrsith
                                          I have seen some threads that touched this subject, but none of them actually answered the question I have in my mind.
                                          I've bought a 'not working' Samsung UE49NU7100K, which turned out to be working but with no backlights. I did not bother to do any PSU measurings as TV itself is working, was pretty sure a single LED has burned out.
                                          After disassembling I was surprised to see edge-lit backlight and the diffuser which was cracked and melted in many, many places, almost like every single LED has burned it. Most of the LEDs look burned out by the way, which made...
                                          03-24-2021, 12:08 PM
                                        • Kemer
                                          Graphics Card mounting frame
                                          by Kemer
                                          Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                                          As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                                          I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                                          What worries me right now is the possibility that...
                                          09-14-2024, 08:57 AM
                                        • V3dran
                                          Diffuser/LPG for UE50NU7022KXXH
                                          by V3dran
                                          I'm trying to repair a UE50NU7022KXXH with a cracked diffuser/lpg and now also with burned leds
                                          There are 4/5 white spots on the bottom that are not visible since the left side is dark now so I want to change the diffuser/lpg
                                          Looking the samsung spare parts, I see that there is a DIFFUSER PLATE and a LPG so I'm wondering what is really broken?
                                          https://www.samsungparts.eu/samsung-...n61-15659a.htm DIFFUSER PLATE 1125x625x2,5mm
                                          https://www.samsungparts.eu/samsung-...n61-15661a.htm LPG 1101x619x2,7mm...
                                          06-26-2025, 01:54 AM
                                        • mecha1166
                                          Reattaching new edge to edge LCD panel to tv frame - Hisense 55a6g and others
                                          by mecha1166
                                          Some new tvs have an LCD screen attached to the outside of the frame with foam tape. These are "edge to edge" as they are called. I am trying to figure out how to reattach an LCD panel back up to the frame. The manufacturer used 3/16 inch foam tape along the top and rh/lh edges. I used a razor blade to separate the panel from the metal frame. The metal frame that the panel is taped to is 1/4 inch wide along the 2 sides and top. I completely removed the residue from the metal frame. There is some residue on the panel itself along the 3 edges, I removed almost all of it using alcohol and...
                                          06-13-2024, 02:28 PM
