Philips 55PUS7303 LCD lines
  • Diah
    • Feb 2013
    • 6397
    Originally posted by rtstorm
    I have bench power supply
    this is wromg... u need to have the 12v from the tv self for example on the MB LVDS socket u have t-con 12V...( pins 1-5 i think ) connect jumpers direct to f101,,, solder it not just touch
    • lotas
      • Jan 2016
      • 4656
      • Russia
      There is no need to change which motherboard the problem is in the panel (in the buffer strips), if the panel is AUO, then as always the TVS diodes assemblies, take a photo of the buffer strips on the left and right sides.
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        i dis this but the screen is black, only backlight
        ...the quieter you become the more you are able to hear...
        • Diah
          • Feb 2013
          • 6397
          you are wrong 1 too.... look on the first post when TV boot logo, and screen when half screen test... how it come you will be as the other asshole.
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            here is the right and left side. Manufacturer is AUO
            • Diah
              • Feb 2013
              • 6397
              do it again and check VCC on the winbond spi on t-CON if there > 3V
              • lotas
                • Jan 2016
                • 4656
                • Russia
                #27
                Again, you can’t prove anything, watch the video to see what the problems are with these panels!
                https://www.youtube.com/watch?v=KsQmOS-vIsI
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  #28
                  there is 3.43V on pin 1 of Winbond IC
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    #29
                    yes this guy have exact problem like i do, but he have problem only on one side of the screen. But i do not understand did he just remove the diodes or?
                    • lotas
                      • Jan 2016
                      • 4656
                      • Russia
                      #30
                      Carefully remove these assemblies from both sides.
                      • Diah
                        • Feb 2013
                        • 6397
                        i don't need to watch You tube fake...i have enough Philips under my hand, ESD diode over all panels will remain work if you remove them..
                        • datasheetcrawler
                          • Nov 2023
                          • 18
                          • United Kingdom
                          #32
                          Note:
                          Im the site owner and travelling so will leave it to mods to decide if Davi.p goading a user then reporting their response warrants a ban.
                          • lotas
                            • Jan 2016
                            • 4656
                            • Russia
                            #33
                            Yes, he just deleted them.
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              #34
                              Guys please dont argue, i appreciate all your help
                              • Diah
                                • Feb 2013
                                • 6397
                                we don't, argue .. only i hate some one suggust scrap TV with out prof of test... Youtube or edit video for me no go.. what i share here only what i know and faced.. other matter will let my self out.
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  #36
                                  I remove the 4 diodes and guess what? tv work :-) Thank you!
                                  is this ok to leave panel without those diodes? What are they for?
                                  • lotas
                                    • Jan 2016
                                    • 4656
                                    • Russia
                                    #37
                                    Well, we saw it, it's good that we didn't order the motherboard, and the same problem would have remained!
                                    You don't need to install these diodes, they are more problems than they are worth.
                                    • rtstorm
                                      • Feb 2012
                                      • 971
                                      • Croatia
                                      #38
                                      Yes, thank you. Hope this will help someone else with this kind of problem.
                                      • lotas
                                        • Jan 2016
                                        • 4656
                                        • Russia
                                        #39
                                        you are wrong
                                        So where am I wrong?
                                        • Diah
                                          • Feb 2013
                                          • 6397
                                          ESD can be moved as i said before--- ... they are not JUST DIODE,,,, as they are controlled with Freq. this i wrote before,,, this freq generated and monitored by MB.-- oscilloscope will show you.. not ohmmeter. say its diy .. i will accepet it... but don't say issue or repair
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • grandad99
                                            philips 58PUS8105/12 horizontal lines
                                            by grandad99
                                            hi all and hoping i could get some help please.
                                            my philips 58PUS8105/12 has started acting weird.
                                            its getting these lines across it and sometimes a strange black half circle sometimes appears on the right hand side edge of the screen,the screen is cool to the touch all the way around except where you get to that black halfcircle about the size of a smartie right on the bezel edge of the screen,its quite hot.
                                            tv prob 3 years old and only used on weekends for a few hours so not done much.
                                            i popped the back off and cleaned the ribbon contacts all to no...
                                            08-01-2023, 10:37 AM
                                          • Stanley1843
                                            by Stanley1843
                                            06-29-2024, 11:54 AM
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
