Sony LED 65X9005A shuts down after few seconds - looking for help
  • Diah
    replied
    Originally posted by tec3000
    Should I order the U ribbon cable right away or should I go ahead with the testing you described earlier?
    first inspect as mentioned bu lotas.. then need the u ribbon
  • lotas
    replied
    That's good news right? Likely the cause for my issue??
    + Missing components.
  • tec3000
    replied
  • Diah
    replied
    yes it is.... but still could be there another issue,, caused by smell and smoke lol
  • tec3000
    replied
    Originally posted by Diah
    I was hoping you'd say that! Because I have just discovered something! One of the U ribbon cables is ripped. That's good news right? Likely the cause for my issue??
  • Diah
    replied
    (I wrote it above. It was just a reflection!)
    Thank you for the detailed description. I will do this now but before I need to know something: what and where is the U ribbon cable??
  • tec3000
    replied
    there are another way to know why the gamma dead and where the issue.... using the original T-CON and the replacement one we need to do it in points turn on and check the screen
    A- with Original T-con in place all 4 ribbon cable connect to panel
    1- disconnect only left side U ribbon cable after test if no change put it back
    2- disconnect only right side U ribbon cable after test if no change put it back
    B. disconnect 2 ribbon from left side after test if no change put it back
    C- disconnect 2 ribbon from right side after test if no change put it back
    do all points again with replacement T-con
  • tec3000
    replied
    Originally posted by lotas
    This is more likely a reflection from the flash.
    Yes, luckily it's just a reflection! I took another pic.
  • Diah
    replied
    yes indeed...not only this from his last photo it show part of screen are off... like U ribbon... but i think he know now after many fail how to access
  • lotas
    replied
    Only 1/2 of the slats are visible here, half is hidden behind the body panel...
  • Diah
    replied
  • Diah
    replied
    if this the case then this line heated and lost the green color,, and maybe cut off ... i hope so
  • lotas
    replied
  • Diah
    replied
    photo No 2. there are unclear things to me... check them
    and you have 2 U ribbon cable connect 2 half on one side together... carefully take them out and inspect them
  • tec3000
    replied
    they pass..
    let check from the bottom... show the panel puffer boards if there any sign of burn parts or trace
    and here the pics:
  • tec3000
    replied
    they pass..
    hope you didn't remove or play with ribbon white the TV on..
    I have, I have.
    Since then the TV is like that. It also smelled a bit. I told about this when it happened a couple weeks ago. Remember? But I bought the cables and the t-con board AFTER that. Since then I didn't do any cable detaching while the TV was plugged in. Lesson learned....
  • Diah
    replied
    they pass..
  • tec3000
    replied
    ah, that's because it was an unused one. I got 10 instead of 4 from China! Here I just de-attached one of the new used one. There you see the marks:
  • lotas
    replied
    The thickness of the contact pad corresponds to the original. There are no traces left from the clamping of the connector, as if there is no contact..
  • tec3000
    replied
    Yes, that's what I thought. Then I aligned them as Diah said and it looks close. (Pic1)
    But the length of the pins is definitely different. The originals are longer. (Pic2) Is that a problem?
  • mauda
    Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
    by mauda
    I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
    Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
    05-21-2023, 11:56 PM
  • chaos-theory
    Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
    by chaos-theory
    I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
    Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
    03-14-2025, 05:37 PM
  • solveit68
    Lenovo L580 20LW-0010GE shuts down after a few seconds
    by solveit68
    Hello together,
    I am hoping for some tips here to repair a notebook.
    The notebook has following issue:
    After starting the notebook it shut down after a few seconds.
    Sometimes it is possible to enter the bios but then after, another few seconds it shuts down also.
    The time until shutdown varies slightly.
    What I've tried so far:
    - cmos cleared
    - removed all components that are not essential for motherboard testing including keyboard and touchpad
    - ram exchanged
    - same behaviour with power supply or battery...
    07-21-2023, 01:04 PM
  • doejohn11
    Lenovo Legion 5 17ach6h shuts off after 70 seconds.
    by doejohn11
    Hello guys. I have a legion 5 17ach6h with Ryzen 7 5600h and RTX3060.
    It was working perfectly fine but the cpu was overheating so i decided to replace thermal paste. I bought one from local hardware store and replcaed. it looked fine then the fan started to spin at the full speed after about 1 minute and then immediately shut off after 10 seconds. Then I though if i have done something wrong, so i cleaned up everything with IPA and put new thermal paste. but the issue was still there. After that, I came across this article where he had similar issue and he was able to solve it by replacing...
    04-19-2025, 07:38 AM
  • IamPritesh
    Sony VJF152C11N DA0HKDMB6D0 shuts down in 1 min
    by IamPritesh
    So I have this Sony VJF152C11N ( Board Number : DA0HKDMB6D0 ) which came to me with no charging issue. The Charging IC was getting hot so replaced it.
    ISL88732 replaced with ISL88731 and also the lower mosfet PQ59 ( NTTFS4C10NTAG ) with a similar N channel mosfet. Now the Charging is fine with 15.7 on BAT+ line but the new problem is that laptop boots till sony logo and then shuts down when battery is connected ( With or without AC adapter )
    What could be causing this is a non compatible IC or FET or poor soldering or some kind of shorting?
    07-31-2022, 05:23 AM
