Graetz / Akai CV338H-T50 bricked after firmware upgrade
Tags: None
Is the software in an SPI chip ? never used the RT809
1. Write only one CtvUpgradde.bin file to a USB drive.
2. Disconnect the TV from the 220 V network.
3. Insert the USB drive into one of the connectors of the dual USB port.
4. Press the power button on the back panel of the TV and, holding it pressed, turn on the TV to the 220 V network.
5. Within 3-5 seconds, the software update process will start, and the red and green LED indicator will begin to turn on alternately, and information about the completion of the update process will be displayed on the screen. You can release the power key.
6. At the end of the process, the TV will go into standby mode and the indicator will turn red.Comment
firmware update started but at 25% displayed firmware error and rebooted with no display. Now Standby button red on. Backlights On.
tried several more times with another software and same happened.
I have 2 TVs with same problem.
Tried the software from https://www.kazmielecom.com/cv338h-t50-software/
TV1
MODEL: Graetz GR50E5300SA
PANEL: CX500DLEDM LE-5018S
TV2
MODEL: SMART TECH LE-5017SA
PANEL: CX500DLEDM LE-5017S
TRIED SOFTWARE:
File 1:
-CV338H-T50_1920x1080_LE-5018N_USB
File 2:
s_05-01-23-11_BBK_50LEX-7027FT2C
Описание.txt contains:
Model BBK 50LEX-7027/FT2C
- Mat. board CV338H-T50
- Matrix CX500DLEDM
I have this CH431 programmer available that I suspect I need to use now that the TV seems bricked. So I was trying to find some good directions if I can fully upload the upgrade file somehow.
I would appreciate any comments / hints please.
try find the YT video, especially those of ifix.net, where by connecting to the vga port UART, he gives a command that erases the previous firmware and leaves the Mboot (sorry don't remember the name) and puts the usb pen and starts upgrade with command..Comment
Try this update "Graetz GR50E5300SA CV338H-T50 V500HJ1-PE8 LE-5017S", first with one file, it won't work, try with all four files, try with different USB flash drives...https://drive.google.com/file/d/1zaf...HQDfW5ZB8/viewComment
With this firmware I have managed to revive the Graetz TV and seems all working fine.
The Smartec - wrong display but everything seems to work.
So am now looking for a matching firmware.
TCON Smart tech
Panel SmartTech
A tip will be underway Lotas for sure for your spot on help!Last edited by alltvrepairs; 03-16-2024, 06:00 AM.Comment
BOTH TV FIXED at last. Special tks to Lotas for sending me a good file to start with and all others contributing here.
Apparently I have been quite unlucky as the first 3 files downloaded contained errors and I had the impression I have bricked both sets.
The Graetz firmware worked immediattely.
Applied same firmware on Smarttech Tv, Tv revived but incorrect colours/bit rate due to different screen.
Have downloaded 5 more firmwares and finally found 1 that worked and had good picture, however required a Samsung Remote. Managed to Export the RC settings from the Graetz TV as use same remotes from SM Service Menu (Menu 1147).
Back to the Smarttech, Imported from SM the RC file and now remote changed fine... however noticed that from standby the TV needs the Samsung remote. Once on, switches to the original remote (strange).
Now I have exported the correct Display Settings to a USB and flashed again the Smartetch TV with the Graetz software. TV remote ok and wrong picture. Back to Service Mode and Imported the Display Settings from the USB. To see the change the TV needs to be switched Off and back ON.
Now I have everything in order. Checked WIFI and all ok.
lotas I owe u
Hi everyone, I have my TV stuck on smart TV, gr50e5300sa, I need the firmware but click link but it is no longer available, can you help me???Comment
Hi guys, I would also need firmware for Graetz GR50E5300SA as Uniko Shop. So lotas , would be nice if you can somehow provide it. Thank you so much.
Good news! Tks LOTAS.
TCON Smart tech
Panel SmartTech
A tip will be underway Lotas for sure for your spot on help!Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. :POOF:Comment
by codernov
https://i.ibb.co/Z1hKTkwW/0001.jpg
https://i.ibb.co/BK7YmhHx/2025-06-06-16-14-IMG-5818.jpg
This thing is pretty expensive. More than an average notebook.
Anyway. I got this job over facebook market place. Customer said he bought it used and it was working fine, then he decided to upgrade firmware and somewhere along the way the battery died or whatever we don't know, it got bricked. That's his story and he's sticking with it.
If we connect power supply to it, we are getting 21 milliamps and nothing is happening. Pressing buttons does nothing....-
by Eugenio60Hi all, I have a Graetz smart TV "GR50E5300SA" that gets stuck on the home logo and then turns off, could someone provide me with the firmware to restore it, thanks.
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...02-10-2024, 02:07 PM -
by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
by gurj1979Hi guys.
I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
Got New chip and writes good.
THE PROBLEM...
It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
Does anyone have a Good Firmware I can have?...-
Channel: Troubleshooting & Designing Networks
- Loading...
