soundboks 3 bricked firmware ($600 bluetooth speaker)
  • codernov
    +1 786 407 9817
    • Jun 2025
    • United States of America
    https://i.ibb.co/Z1hKTkwW/0001.jpg
    https://i.ibb.co/BK7YmhHx/2025-06-06-16-14-IMG-5818.jpg
    This thing is pretty expensive. More than an average notebook.
    Anyway. I got this job over facebook market place. Customer said he bought it used and it was working fine, then he decided to upgrade firmware and somewhere along the way the battery died or whatever we don't know, it got bricked. That's his story and he's sticking with it.
    If we connect power supply to it, we are getting 21 milliamps and nothing is happening. Pressing buttons does nothing. We got a 3.3V rail and we got a 5V rail. Board looks good under microscope. There are reset pins under S/N sticker, shorting them drops power to 0 milliamps and then it comes back to 21 milliamps. I suspect it just goes to some prompt and there is no firmware.
    Problem is to get a dump for it. I've searched internet and got no results. I did contact the manufacturer, very quick response, they told me to send it in, for money they'll reflash it. No good. I might advice customer to send in the board to get it reflashed.... But I prefer to do it myself and get paid.
    I need a firmware dump
    MC is PIC32MX470F
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8882
    You need the firmware from the manufacturer. Before you do anything crazy, chances are that the chip is read protected. Try reading your chip with a programmer. You just cant dump a different same model speaker. It will output only garbage if the protection is on, unless you are able to glitch the chip and extract firmware that way.
    Not that easy getting the firmware as you think it is.
    • Lichtmacher
      • Feb 2026
      Hello, I'm facing the same Problem right now. I think that my Soundboks is stuck in a boot loop.
      Did you just send it to support for a reflash or did you find another solution?
      • u666sa
        • Jan 2014
        • 94
        Resolution was to send the board to manufacturer for programming. You email them, they are really nice and tell you the price and everything.
        • Lichtmacher
          • Feb 2026
          Thank you very much
          • ngvuanh
            • Jul 2013
            • 58
            It might be just me but I don't even see flashable firmware chip in your pics to start with.
            • Lichtmacher
              • Feb 2026
              The board does have an dock for easy reprogram, but I don't have the firmware, the tools or the knowledge to do it properly and it is likely read and write protected. I'm choosing to send it to Soundboks for a reflash of the software for 90 bucks (shipment included). I will Upload Pictures of the motherboard for anyone interested, because some transistors seam to miss on the board from default.
              • u666sa
                • Jan 2014
                • 94
                Firmware is inside PIC MC, with big white dot indicating it's a flushable ic.
                • Lichtmacher
                  • Feb 2026
                  It's a PIC32MX470F512H-I/MR. It's wery likely read and debug protected. Thought of reflashing it, but that would ether require to get the firmware of some suspicious site, or making my own which is likely not possible because of the custom skaa chip by eleven that is on the board.
                  • Bruggefan
                    MD71-HB0 Firmware bricked of X557-AT2 NICs
                    by Bruggefan
                    Hi all
                    I'm having troubles with an Gigabyte MD71-HB0 rev 1.1.
                    I've read on different forums that many people had issues just like I had, but for some reason, mine got worse.
                    What happened:
                    - Did BMC firmware update in 2020
                    - Doing this, my MAC adresses were cleared from my nics
                    - Added MAC adresses with an eeupdate tool
                    Things worked fine for years, however about a year ago I performed a BMC and BIOS upgrade again.
                    Since then, both my 10Gbit and my 1Gbit NICs stopped working.
                    The amber led on the NICs is solid on, no matter...
                    12-18-2025, 03:12 AM
                  • zklgfs
                    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                    by zklgfs
                    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                    08-11-2025, 02:14 PM
                  • thesame
                    Bose Speaker Model 415859 not charging, bricked during update.
                    by thesame
                    I have this bluetooth speaker that came in for battery replacement, customer bought the original battery for replacement, the speaker was working connected to the charger, after installing the new battery i have 3.8v measured at the battery wires on the board, the old one was measuring a resistance instead of volts, i have connected the speaker to the charger and it was not drawing any current, not powering on.
                    I have remembered that i have fixed the same model of the speaker a few months ago with the same behaviour not charging with original battery in good voltage after updating it to...
                    05-21-2026, 01:28 AM
                  • satbeginner
                    Firmware for Marantz SR6009 needed, bricked after power fail
                    by satbeginner
                    new to Badcaps, my name is Leo, I am a retired Dutch engineer now living in sunny Spain.
                    After a power fail my trusty Marantz SR6009 bricked its firmware.
                    I checked all voltages and fuses but these are all OK.
                    Furthermore, when I initiate the Firmware restore via USB, the display lights up with the USB message and the walking dots, so to me it seems the hardware is still OK.
                    But, I need the firmware file to restore the firmware via USB.
                    I know it is a longshot because of the age of this amp, but I can only hope..
                    Thanks...
                    04-04-2026, 03:13 AM
                  • weisian
                    VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
                    by weisian
                    I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
                    1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
                    2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
                    03-12-2026, 05:54 AM
