Bought a bricked 15" generic LCD TV and need firmware
  • void_ptr
    • Oct 2025
    Hi, folks. Thanks for all the work on this site. I am looking for help with a TV. I have a secondhand 15" LCD TV that won't turn on. The board is listed as CV3553M_B24_10 and the panel is a MG1561B01-1. I just want to use it as a portable gamer display and maybe a media player. The branding is "Emerson ETC-1500N" but I know it is a generic Chinese TV. Searching on the internet for compatible files turns up zilch and the ai bots aren't much help. Can someone please help me locate the fw for this TV?
  • lotas
    • Jan 2016
    • 4881
    • Russia
    Why do you think it's a firmware issue? I can't find anything using the motherboard number. Did you type the motherboard model correctly? Can I see a photo of the motherboard and see what processor it has?
    • lotas
      • Jan 2016
      • 4881
      • Russia
      Read your native dump with a spi flash programmer and post this dump here, I will check it and try to fix anything.
      • lotas
        • Jan 2016
        • 4881
        • Russia
        Can't read the dump or just don't have a programmer?
        • void_ptr
          • Oct 2025
          Well I believe the guy I got it from was trying to put firmware on it and bricked it. It is one of those clear TVs that are restricted from the factory. He was trying to restore the media playback functionality and apparently didn't pick the right file. (I don't have access to it, and I don't have a programmer.) The previous owner was no help, so I turned to the web. My initial google searches and AI convos turned up:
          1. It is not in fact an Emerson tv at all. It is common now for these clear tvs to be manufactured with Chinese parts and branded for resell in the US.
          2. I identified the board and panel based on serial numbers. CV3553M made by CVT, and MG1561 panel.
          3. AI tells me that firmware is based on the board and the panel, and I should find a file following that naming convention (i.e. CV3553M_1366x768.bin)
          4. AI even told me to come to this specific site to find a file that matches the pattern and "it knows will work" but would not give me a direct link.
          5. All my searches on this site for the file turn up nothing, so I am thinking the AI is going off of links that have been removed since it was trained.
          If anyone can help, I do appreciate it.
          • void_ptr
            • Oct 2025
            Found out the processor is an MSD3553ZUC as well. Hope that helps.
            By the way, my internet access is spotty, so forgive me if it takes a while between posts.
            • lotas
              • Jan 2016
              • 4881
              • Russia
              Your processor is MStar, but I need your dump to check it...
              • zklgfs
                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                by zklgfs
                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                08-11-2025, 02:14 PM
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
              • gurj1979
                Ubiquiti firmware help. US-8-150W POE
                by gurj1979
                Hi guys.
                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                Got New chip and writes good.
                THE PROBLEM...
                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                Does anyone have a Good Firmware I can have?...
                07-22-2024, 05:13 PM
              • alltvrepairs
                Graetz / Akai CV338H-T50 bricked after firmware upgrade
                by alltvrepairs
                The original fault was set not loading completely and reboots. I have downloaded a firmware on usb, tried the upload but midway says incorrect spftware and shuts down. I have blank raster now.
                Anyone has experience on this mainboard?
                In the download there are other apart from CtvUpgrade.bin
                03-15-2024, 12:18 PM
              • Slapito
                Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
                by Slapito
                I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
                Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
                I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
                I already downloaded the BIOS update file from msi official...
                10-09-2025, 02:00 AM
