Philips LCD 37PFL8404,bad flat cable to panel
  • zeko
    • Jan 2014
    • 30
    • Albanien
    Hi, one line to foil does not contact.
    How to fix it again???
    Thanks.
    Re: Philips LCD 37PFL8404,bad flat cable to panel
    Generally, that would be seen as unrepairable; the reason being it's too fine pitch and ribbon cannot be replaced without replacing whole LCD panel.
    • freakaftr8
      • Oct 2012
      • 3743
      Man this 3m 9703 conductive tape is really getting to me. I really want to try my luck on a panel.
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • bohaboha
        PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
        by bohaboha
        Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
        how to fix it thanks
        02-05-2025, 09:23 PM
      • NWArkGuy
        Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
        by NWArkGuy
        Well, I will be the first to admit that I screwed up...
        In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
        I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
        I have 2 that I have found and have in my possession. ...
        10-12-2023, 10:13 PM
      • double_DD
        Philips curling iron - is this a common AC cable?
        by double_DD
        Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
        As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
        Not sure if this is something Philips proprietary, or a standard, but the cable plug...
        08-18-2025, 10:04 AM
      • howardc64
        LG 49UJ6500 LCD panel lighter band that goes away
        by howardc64
        49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
        Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
        02-19-2023, 12:13 AM
