LG 65UK6090PUA - picture dark
  • Danstona
    • Dec 2017
    • 48
    Was watching this set, and suddenly it went dark. Picture is still visible, just very dark. Tried checking all settings, adjusting brightness to 100% no change. Reset through menus, no change.
    bought used boards from ebay (power and input boards) replaced with same results, changing brightness does seem to have a slight affect.. but not to normal visibility of picture.
    I'm handy, fixed TVs before.. I can't see any issues with boards... hoping someone can point me in the right direction to properly diagnose. I don't believe the LEDs are caput, since the picture is on and equal across screen for visibility... just too dark.
    thanks
    • 12330
    • U.S.
    Pictures of each board and one including all the boards.
      • 12330
      • U.S.
      We no longer help people who do not post pictures... maybe that's just me.
      • Danstona
        • Dec 2017
        • 48
        Original power boardreplacement power board
        • Danstona
          • Dec 2017
          • 48
          Click image for larger version  Name:	20240310_184108.jpg Views:	0 Size:	2.91 MB ID:	3232480original power board
          • Danstona
            • Dec 2017
            • 48
ID:	3232487original input board
            • Danstona
              • Dec 2017
              • 48
ID:	3232489replacement input board
              • Storyteller12
                • Jun 2020
                • 625
                My guess is backlights. Especially if you replaced both boards and same symptom. But you need a multimeter and led tester to test the backlights.
                • Danstona
                  • Dec 2017
                  • 48
                  Well I have good multimeter.. I would need to know what the led tester is... with the back off, they light up... I just feel like they should either work or not... not be half bright but still be defective.
                    • 12330
                    • U.S.
                    So you're saying when you turn tv on you can see the backlights are on, can you very carefully check the dc voltage of looks like C611 the 460 volt capacitor put a probe on each lead, use CAUTION it could be about 400 volts, so watch where you put your hands, you don't want that going thru you, don't do if you're uncomfortable with this kind of testing.
                      • 12330
                      • U.S.
                      Something to try, heat up looks like C205 500 volt capacitor for a minute or so with a hairdryer, try tv, see if there's any change, don't wait til it cools down, try it while it's still hot.
                        • 12330
                        • U.S.
                        Since things acted the same, maybe keep original mainboard in for testing.
                        • Danstona
                          • Dec 2017
                          • 48
                          Sorry for such a long time since testing. I still have the set in basement for repairing, I just had some issues preventing me from doing the tests.
                          I checked voltage on the c611 460v cap and it has 21.7v on each lead to a grounding screw.
                          I tried heating up c205 as suggested and if any change, it was the tv not starting immediately, but no chance in picture at all.
                          • EazyBone
                            • Jun 2023
                            • 1362
                            • United states
                            Long time.. lol anyway, still backlights should be tested. Using a tester. Amazon $15
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4537
                              • Italy - Milan
                              Hi, sorry i do not understand well if the light from the back could he considered ok or not. Anyway my two checks: is there a light sensor on a separate small pcb watching the room? Have you opened the panel leds pool and saw how the bars are made? Some Samsung bars comprises opto diodes in a series, for light measuring, the series could be broken.. bye..
                              • Danstona
                                • Dec 2017
                                • 48
                                See photos, both are taken in darkened room
                                • EazyBone
                                  • Jun 2023
                                  • 1362
                                  • United states
                                  Is the photo of the screen showing the defect of being dark? Am I missing something it looks fine. Can you circle whatever it is.
                                  • Danstona
                                    • Dec 2017
                                    • 48
                                    This is the image, this is from a completely black room. The picture is very "dim" it's there, but it's as if the backlights aren't firing fully. This is why I don't think it's the backlights that are the issue, they all work, but the whole screen is very dark.
                                    I can test them if you explain the process, I purchased the tester now.
                                    • KYBOSH
                                      • Oct 2011
                                      • 581
                                      • Unknown
                                      Its likely your backlights. When they fail they usually very noticeable (whole sections of the strip are out) but its possible that failing LEDs with higher resistances can drop the overall brightness of a number of strips. This TV set us about 6 years old so a replacement of the LED lightstrip wouldnt be a bad idea (~$50US on shopjimmy) if you intend on keeping it for the long haul. The chances of the PSU doing this (without throwing an error) is almost non-existent.
                                      Good Luck!
                                      Also be sure to send a video feed to the TV to gauge its proper brightness. The menu/screensaver screens are programmed to have pretty light brightness settings. If you want to show an example then install a FireTv doggle on it, crank the brightness up and then show us what you are seeing.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4537
                                        • Italy - Milan
                                        The chances of the PSU doing this (without throwing an error) is almost non-existent. Good Luck!
                                        You let me think also to another possible issue, that is... right the power supply! The backlight controller ic sometimes fails alone, also in such a way..
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • ugamazing
                                          Apple M1 Boards & Exclamatory Error?
                                          by ugamazing
                                          We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
                                          Has anyone else run into this...
                                          02-20-2025, 09:24 AM
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
