Apple M1 Boards & Exclamatory Error?
  • ugamazing
    • Jun 2013
    • 171
    • usa
    We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
    Has anyone else run into this issue and solved it successfully? It's been a very elusive issue on these and we would love to resolve it.
  • ugamazing
    • Jun 2013
    • 171
    • usa
    I have some new good information for this issue, for any others:
    We took four 820-02016 boards that were afflicted by this same issue--no history liquid/drop, but with a sudden exclamatory symbol without the ability to boot to anything (IR/OS/etc). We decided to just wholesale figure this out, so we did the following:
    1. Reflowed the CPUs on ALL FOUR boards; this RESOLVED the issue (for ~36 hours so far) on TWO of the boards.
    2. On the two boards that the issue persisted on, we replaced the SSDs. NEITHER BOARD resolved after this.
    3. We took one of the CPUs from the non-resolved boards and transferred to a working but locked board. ISSUE PERSISTED.
    4. We did not do this last step, but I suspect if we were to transfer a working/locked CPU to one of these boards, the issue would subside as well.
    So, this appears to be a CPU fault issue. Reflowing the CPU very likely is just a temporary solution, and I expect the failure is actually inside the CPU. I expect the two "fixed" boards to fail after some time, but this is not a certainty.
    Conclusion is that this exclamatory-symbol failure is likely always a CPU failure and not related to the nands. It could be a different story in some cases, but I suspect it will be the CPU 95%+ of the time.
    • ugamazing
      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
      by ugamazing
      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
      12-17-2024, 07:05 PM
    • a_p3rson
      Apple Watch Charging Controller Schematics / Boardview - 820-02601
      by a_p3rson
      Hi there,
      I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
      You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
      This daughterboard uses an interesting...
      04-21-2025, 11:41 PM
    • Ancient1
      I'm stuck . Panasonic TH-L32U20M panel's boards issue
      by Ancient1
      Hi
      The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
      Actions :
      1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
      1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
      Obviously the fault is from or on the Right, secondary board
      2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
      09-03-2023, 03:51 AM
      Apple MacBook Pro 13 A1278 820-3115-B fan maintenance issue
      820-3115-B fan maintenance issue (user supplied document no further details)...
      10-01-2024, 06:14 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
