LG 55EG910v (Green Nosie Screen) BURNT on NOT ?
  • kokos
    azlabgr
    • Sep 2014
    • 17
    • Greece
    Hi ! to all fellows out there!
    I have an LG 55inch 55RG910V-ZB Curved TV. With the following problem: When I turn it ON with Remote I get a Green noise Screen (attached foto).
    I have tried reseating all ribons, Checked PSU 24V,12V,3v ,etc voltages.
    The TV opens on the first Green noise screen and it freezes there -no respone of menu keys ,etc -only on/off via Remote. (I also noticed carefully that except from green noise screen there is a ghost image at bottom and left vertical side)
    I tried connected the lan and I can seee TV via local lan (as a device I didn't tried to cast etc).
    Is there any way of testinf T-con? I read different posts that I can check T-con to view with Red,Green,Blue screen.
    LG technicians and service manual estimates this is a panel fault (burnt screen!) BUT I am far for beliving it yet! as 2 days ago (of the total 10days TV not working) ONLY ONCE! TV started OK with normal screen menus, broadcast channels etc ! 😁
    Please any help what to try would be welcome!
    Thank you for your time.
  • Diah
    • Feb 2013
    • 6379
    Panel issue at side COF of the right side ( need to remove all.. if the set belong to you..you can play with it by cutting the right bezel and remove the COF... but if it will display correct image are unknown.. such TV described as scrap.
    • kokos
      azlabgr
      • Sep 2014
      • 17
      • Greece
      (thank you for quick response)
      ....despite the fact that only ONCE TV started ok ?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4347
        • Italy - Milan
        What do you mean? With a PC? You see the TV received by TV set? With which program?
        My guess is it could be a bad tcon.. put that in freezer and then when frost mount it and test tv..
        • kokos
          azlabgr
          • Sep 2014
          • 17
          • Greece
          Yes I wasn't clear enough: I mean if I connect the LAN the TV can be detected on the lan vua the ip address.
          Do you think? I will try this...
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4347
            • Italy - Milan
            put card in a bag before putting in freezer
            • kokos
              azlabgr
              • Sep 2014
              • 17
              • Greece
              +1
              • kokos
                azlabgr
                • Sep 2014
                • 17
                • Greece
                No luck So far . I really don't know how to proceed. Only one time TV started normally without any issues. Despite that 15 days now it show signs of burnt screen!. Is there any chance of having problems with T-con? May be I try Diah recommendation and start dremel(ling) screen apart!
                  • 12206
                  • U.S.
                  Well if you can get a tcon at reasonable price, try one, if no joy probably time to give up.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4347
                    • Italy - Milan
                    Where are and how are those burnings? Dremeling is not an answer because you don't know where are, if there are, the faulty COG, or if there are COF, you don't even know on which side are those..
                      • 12206
                      • U.S.
                      As funny as it would be to see someone take a dremel to a tv, I don't think that's what Diah meant for you to do.
                      • jimjoe123
                        LCD TV Green/Pink screen problem
                        by jimjoe123
                        I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                        Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                        Then each time...
                        02-23-2020, 01:29 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • String2016
                        samsung np300e green screen
                        by String2016
                        I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
                        07-26-2025, 04:00 AM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
