Vizio VO42L FHDTV10A Buttons not working
  • ntehicks
    • Mar 2011
    • 272
    I fixed this TV about 2 years ago. it had bad inverters. I purchased the upgraded boards and installed them. I am now getting a few buttons on the side control that are not working and some of the buttons on the remote are not working.
    The power button on the TV won't work but the power button on the remote works.
    The channels work on the TV but the remote does not work. When I try to change the volume on the remote vol - works but vol + changes inputs. I thought it would post this strange occurrence and see if someone can tell me where to start.
    Re: Vizio VO42L FHDTV10A Buttons not working
    Could be that a setting somewhere has got lost which tells the TV what remote control or side button assy it is supposed to work with.
    • ntehicks
      • Mar 2011
      • 272
      do you think a firmware update might fix that issue or is there a way to reset the tv
      • Ltank
        • Jun 2013
        • 776
        Are the batteries good? Any corrosion on battery contacts in remote? Some times buttons go bad from use or poor quality or dirt and grime that gets in remote. Remotes are commonly used while eating popcorn while watching TV. Check if any of your friends have a universal remote that can be programed for Vizio. I use a 15 buck universal remote from Walmart that I use at the shop. This will at least maybe fix one problem. The buttons on side of set may be the buttons or a loose connector from workinh on the set. There are little cards that reflect light from the infared remotes. This gives a reasonable idea thet the remote is working. Start witht e easy stuff before jumping to the complex repairs.
          You can also point the remote at your digital camera to check if the remote is putting out or not, you will see IR remote transmitter flashing on the camera's screen.
          I wonder about this " upgraded boards" if it is the correct one and it is really compatible with this chassis or was it working fine then you now have these problems.
          • ntehicks
            • Mar 2011
            • 272
            when I first got the tv one inverter had burned up. I replaced just the one and about 1 month later the other one died. so I found the replacement that would replace both inverters and give me a 6 month warranty. I replaced both and the tv work great. I would say it work for about 1 year and then it started doing this button thing. I will test the tv with a universal remote I have and see if that fixes that. I will also check the board for cold solder connections.
              OK, so you replaced the inverter boards which will not have any affect on the function of the switch assembly or the remote function. I thought you replaced the main board which is possible the cause of the problem you are having right now.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • cstout
                DeLonghi AC Remote only accepts 3V
                by cstout
                Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                I can't find any schematics...
                06-03-2024, 03:53 PM
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
              • ChillingCicada
                Vizio VO42L Issues: Need Guidance
                by ChillingCicada
                We've had our Vizio VO42L since before 2010, and it's worked flawlessly this entire time. However, just recently it started emitting a high-pitched buzzing/humming sound. I followed the basic troubleshooting tips of just unplugging it for a moment, and even holding down the power button while doing so, all to no avail.
                Furthermore, after I attempted these basic steps and powered the TV back on it would always begin visually flickering while the sound stuttered. After a few moments of being turned on this would go away, but it still periodically comes back.
                I also...
                06-09-2021, 05:47 PM
              • rustinjust
                Please help, where can I get a remote for my subwoofer?
                by rustinjust
                I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                Is there...
                10-28-2023, 03:43 AM
