Le32m86bd
  • sordids999
    • May 2013
    • 2158
    Le32m86bd
    Hi guys
    just a quick question got this tv today the colours are really bright,noticed one cap was bulged so changed that but still the same.
    so i need a second opinion tcon board gone ?
    thanks
  • sordids999
    • May 2013
    • 2158
    Re: Le32m86bd
    Opps forgot to post a picture of the problem
      Re: Le32m86bd
      I'd check and see if t-con has an AS15 chip on it... common fault.
      • sordids999
        • May 2013
        • 2158
        Re: Le32m86bd
        As15-f showing on the chip tom
          Re: Le32m86bd
          Good, near the top right of board and AS15 there are a set of points marked VGAMA1 thru VGAMA22, see them? With the board installed and TV showing picture, measure voltage on each point with respect to ground. Report each reading, along with VGAMA name.
          • sordids999
            • May 2013
            • 2158
            Re: Le32m86bd
            VGAMA 1 15.3 v
            VGAMA 2 15.2 v
            VGAMA 7 12.6 v
            VGAMA 8 10.2 v
            VGAMA 9 9.73 v
            VGAMA 10 7.01 v
            VGAMA 11 6.88 v
            VGAMA 12 6.29 v
            VGAMA 13 4.72 v
            VGAMA 14 4.67 v
            VGAMA 15 7.75 v
            VGAMA 16 4.43 v
            VGAMA 21 0.41 v
            VGAMA 22 0.32 v
              Re: Le32m86bd
              Definitely bad. Replace AS15 chip or t-con board and it should be fixed.
              • sordids999
                • May 2013
                • 2158
                Re: Le32m86bd
                ok thanks m8
                • sordids999
                  • May 2013
                  • 2158
                  Re: Le32m86bd
                  Just a quick update replacement t-con board arrived all fixed !
                  thanks tom for your help
                    Re: Le32m86bd
                    nice to hear.
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • x_orange90_x
                      TCL 50S535 bad tcon or panel issue?
                      by x_orange90_x
                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                      03-29-2025, 11:02 PM
                    • Hakuu
                      by Hakuu
                      Hi There,
                      More Details
                      TV Model - LG OLED77G1PUA
                      07-12-2023, 02:37 PM
                    • netgearnetgear
                      TCL 43S423 TCON OR PANEL FAULTY???
                      by netgearnetgear
                      Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                      08-20-2025, 06:04 PM
                    • Daren87
                      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                      by Daren87
                      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                      08-13-2023, 03:25 PM
