Another Bad Panasonic Plasma
  • Morts
    • Jan 2014
    • 6
    I have been doing some searching on the forum and have not seen my problem covered.
    TV is a Panasonic TC-P50G10 I get SOS3 error code. I have seen the technical report on the 3 blink error code being bad main A board. I replaced the A board and I still get the 3 blink SOS. I disconnected the SC board and the SOS goes to 6 blinks. I am lost if anyone could give some advice here I would appreciate it.
    Is it possible I got a bad A board? Is there a way to test to see this is the problem? Thanks
    I apologize I did not state the model number in the title and can't edit it.
  • Toasty
    • Jul 2007
    • 4171
    Re: Another Bad Panasonic Plasma
    Did you see this link and follow it by any chance:
    http://www.justanswer.com/tv-repair/...not-power.html
    Some good checks there to see where problem might be.
    I've had similar problems and thought it was one board by all the tests. Found that another board had a short and was killing one of the voltages (pulling it low), tripping the fault for that voltage.
    Make sure you follow the procedures to disconnect the indicated lines to protect the other boards.
    T
    veritas odium parit
    • Morts
      • Jan 2014
      • 6
      Thank you sir much appreciated. I will definitely check it out and post results.
      • Toasty
        • Jul 2007
        • 4171
        Ever get anywhere with this?
        T
        veritas odium parit
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
