Logik l423ed11 vertical lines
  • efwiofoi
    • Nov 2013
    • 76
    i have a logik l423ed11 42inch lcd, the picture shows a vertical line that moves from left to right, i think it's the 'no signal' logo which is moving about. if i press menu a wider pattern comes up in the middle.
    any ideas what this would be, panel / main board / tcon?
    thanks
    Re: Logik l423ed11 vertical lines
    It's a fairly new TV so I'd be going "PANEL!!"
    There is a chance, if the t-con is separate, that a loss of VGH or VGL voltage could also cause this.
    BTW, you never PM'd me back about the Vestel board, are you still interested in it?
    • efwiofoi
      • Nov 2013
      • 76
      hi tom i was thinking the same
      it does have a tcon though so maybe there is hope?
      it has an LG panel LC420EUN, with an upside down tcon
      re the vestel board yes, i will pm you about it.
        Need a shot of this board.
        https://www.badcaps.net/forum/attach...3&d=1390070388
        where the labels can be seen for test voltages. Like VON, VOFF, or alternatively VGH and VGL.
        • efwiofoi
          • Nov 2013
          • 76
          here is a close up of the tcon
          there is 11.85v on the main fuse.
          what else can i check?
          the main board has a jumper that sets either 5 or 12v for the tcon
          i can get the tcon on ebay, £20
          • efwiofoi
            • Nov 2013
            • 76
            the pads on the right half mostly measure -.97v
            the left most one (vcomrfb?) is 5.61v and vcom is 5.61
            z out is 5.8
            • efwiofoi
              • Nov 2013
              • 76
                See image. Test each ringed point, board plugged in and set powered up, DC volts, red probe on point, black probe on chassis. Report adjacent label to each point - VGL, VGH, AVDD, AVCC, Vcore, VCOM_FB.
                • efwiofoi
                  • Nov 2013
                  • 76
                  ok i get:
                  VGL -0.97v
                  VGH -0.73v
                  AVDD 11.56v
                  AVCC 3.29v
                  Vcore 1.97v
                  VCOM_FB 5.14v
                    VGL and VGH are your problem. I bet, since voltages are so close, there is a short between them in the panel. Try unplugging one ribbon at a time and see what happens, sadly this will probably NOT be repairable.
                    • efwiofoi
                      • Nov 2013
                      • 76
                      with the ribbon near them out they are the same (vgl -0.97 vgh -0.73). with the other ribbon out only, vgl is -1.56 and vgh is -0.73
                      with both ribbons disconnected: vgl is -1.56 and vgh is -0.73
                        Sounds like a short, which has since damaged them, you could try replacing the components around there (likely a transistor or resistor) or the t-con but I suspect there's a fair chance they'll fail shortly afterwards due to panel fault.
                        • efwiofoi
                          • Nov 2013
                          • 76
                          ok
                          thanks for the help. what voltage should vgl and vgh be?
                            VGL around -5V to -10V for all panels.
                            VGH around +20V to +28V for early panels, +17V to +30V for newer panels like this.
                            The VGL deselects a line on the screen, so it doesn't take data, VGH selects it, the Gate in Panel driver (see DS: ) swings between VGL and VGH for each line in the screen.
                            So when a line is at VGL, it is "muted" and it is not looking for data, when it is at VGH it is listening for data, in between the two it could do either, I think that's why all lines show the same.
                            • efwiofoi
                              • Nov 2013
                              • 76
                              i bought a new tcon, connected it up without the screen ribbons and measured +28v on vgh and -5 on vgl.
                              as soon as i powered it up with the ribbons connected there was a burning smell from the tcon. the voltages are back to around -0.7 again.
                              i took the panel out and removed the bezel to see the boards that are bonded to the screen. nothing much to see except one is sticky. looking at the edge of the panel something has been spilled on the screen and run down onto the left board (panel is mounted upside down). it looks like it was coke, its brown and sticky. theres not much on these boards only 2 pin components. i think there's a chance if i clean this off and buy another tcon it might work?alcohol spray and a tooth brush?
                              • truep
                                • Aug 2010
                                • 373
                                Very little chance, I' would give it a try though. I've had four with liquid damage and none worked after cleaning. If it got on the cables to the panel, forget trying to fix it.
                                • efwiofoi
                                  • Nov 2013
                                  • 76
                                  it got on one of the ribbons, after cleaning there is a little black dot between two gold pins where the ribbon bonds to the pcb. in two minds whether to try another tcon, i think i might leave it.
                                  bit of a step backwards putting the ribbons at the lower edge
                                    They put 'em on the bottom because they were getting too hot at the top, but the massive disadvantage means ANY liquid spill has a good chance of wrecking the panel. At least tab bonds were fixable... it feels like it's a deliberate failure mode... a little sealant around the bottom of the panel and it'd all be OK, but no...
                                    I had a 37" LG LED with water damage, half screen missing, couldn't fix it.
                                    • efwiofoi
                                      • Nov 2013
                                      • 76
                                      another one for the scrap heap
                                      it kind of fits better now they started putting the tcon underneath, leaving it thinner at the top, but many more unrepairable tvs, as its common to get something spilled on the screen.
                                      they are never going to bother sealing it, it might cause problems as well due to a small amount of movement needed for thermal expansion.
                                      bad news for lcd's
                                        LCDs are less reliable than plasmas. Let's hope OLED are better, but somehow, I don't see that they will be.
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
