LG 42LD550 picture scrambled
  • ChiefDJ
    • Jan 2014
    • 6
    I bought this TV new about 3 years ago and it has worked great until about 3 weeks ago when all of the AV inputs stopped working. I get sound from anything hooked up through AV or composite but no picture. Anything hooked into HDMI still worked fine though.
    Then tonight as we were watching TV after it had been on for about an hour, the picture went scrambled with horizontal and diagonal lines (see attached pictures). Still get sound, but the picture is messed up on everything, even the TV menus. I've unplugged the TV for over an hour and when I plugged it back in there was no change.
    I've been looking at replacement mainboards and there are NONE available anywhere. (can't believe it).
    Anyone have any suggestions for what I can look at?
    [IMG][/IMG]
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 42LD550 picture scrambled
    Wow that's an interesting one. Definitely mainboard related. Since the tcon is built into the mainboard it's harder to diagnose what on the board is bad but start with heating the board with a hair dryer to start. See if it gets better
      Had one like this before - similar model - turned out the TV had a 720p motherboard installed (or configured as such) in a TV with a 1080p panel. It could also be possible that the configuration EEPROM is corrupted.
      • ChiefDJ
        • Jan 2014
        • 6
        Tom,
        I read the thread you are talking about, but there is no way it has the wrong board in it. I bought it new and it has worked fine for over 3 years. The picture just went scrambled all the sudden as we were watching it.
        If the EEPROM has become corrupted, what would I do about that?
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          scart out to another tv,picture the same?,if it is ,mainboard fail,im guessing the video chip is getting toasty,havent seen this kind of fault relating to t-con board before
          fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
          please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            Originally posted by ChiefDJ
            Tom,
            a new pre-programmed eeprom,or a blank with the correct firmware,i dont think this is eeprom related though
            also,does it affect the menu screen?
            • ChiefDJ
              • Jan 2014
              • 6
              Yes it does. I can see the menu coming up because the colors and different lines change, but it is also scrambled.
              • multimeter
                • Jan 2011
                • 739
                • united kingdom
                and does pic change when scarted out to another tv?
                • ChiefDJ
                  • Jan 2014
                  • 6
                  I haven't tried this. How would I do it? Could I try connecting my laptop to the RGB port? Would this accomplish what you want to look at?
                  • multimeter
                    • Jan 2011
                    • 739
                    • united kingdom
                    keep the tv your fixing on,use a scart cable to connect to another tv,and select the right channel,if your mainboard is working the second tv will have a good picture-menus etc,if the picture is the showing the same fault on the other tv,your mainboard has failed
                    • ChiefDJ
                      • Jan 2014
                      • 6
                      I dont have a scart cable or another TV to connect it to. ANything else I can try?
                      • multimeter
                        • Jan 2011
                        • 739
                        • united kingdom
                        you could try laptop,vga on tv?,rgb?
                        • minishotglass
                          • Sep 2014
                          OP can I get an update on the solution? Running across the same issue and about to order a replacement main board. Thanks.
                          • Jackching
                            Intel PC hooked to X90L television picture cut-off
                            by Jackching
                            I have my Intel PC hooked to my Sony X90L television and each time the power is cycled on the tv, the bottom of the PC screen gets cut-off. Only half of the taskbar shows until i go into display settings and cycle the display size and it'll work fine until the next time I power off the tv. I updated the drivers. The graphics is UHD 630.
                            10-27-2024, 11:43 AM
                          • JJAAMM
                            by JJAAMM
                            Problem
                            07-06-2023, 06:01 AM
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • Bloopeta
                            Samsung QE55Q7CAM scrambled picture / squares
                            by Bloopeta
                            Quick question please, not much info or pics to go on unfortunately as its not my TV, and I dont have it infront of me, but was wondering if anyone has come across this before, and what the problem possibly could be?
                            Samsung QE55Q7CAM
                            Owner states after the tv has been on standby for a long period of time, when switched on, it displays scrambled/blocked image as pictured.
                            If one connect cable is disconnected and reconnected or power turned off at the main socket it will work fine with no problems until its been left on standby again for a long time.
                            09-02-2023, 03:23 PM
                          • CyberPhoenix
                            Issue with picture quality of Sony bravia TV
                            by CyberPhoenix
                            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                            01-22-2024, 02:08 AM
