SONY Bravia OLED XR-77A80J will not power on
  • repair-it
    • Nov 2020
    • 116
    • US
    SONY XR-77A80J shuts off as soon as it is powered on. It goes into standby ok when plugged in but when power button is pressed, relay clicks and tv powers off. Power supply board makes a sound that sounds like momentary coil whine when it clicks off. The main board appears to turn on and has working optical.
    I pulled the power supply board for visual inspection & there wasn't anything obvious. I am not sure how to go about testing this OLED as it is a bit different than the last one (LG) I tried to repair. The only voltage listed on the PSU is 12v for T-CON. The 12v is not present at either connector. There are 4 opto's on the PSU so I am wondering if maybe there is an issue with secondary side possibly not getting power.
    This TV is REALLY big! 😳
    Click image for larger version  Name:	SONY XR-77A80J.jpg Views:	0 Size:	2.99 MB ID:	3203848
    Click image for larger version  Name:	XR-77A80J Main board.jpg Views:	0 Size:	2.79 MB ID:	3203849 Click image for larger version  Name:	XR-77A80J t-con board.jpg Views:	0 Size:	2.76 MB ID:	3203850 Click image for larger version  Name:	XR-77A80J PSU.jpg Views:	0 Size:	3.18 MB ID:	3203851
Name:	XR-77A80J PSU outputs.jpg
  • Diah
    • Feb 2013
    • 6541
    disconnect the 2 socket in Red color and power on... check if it remain ON and Optic lit on... if yes... put them back and disconnect the only LVDS in yellow color... power on and check if it go On and the optic lit too.
    IF no result . you need to take out the PSU alone on the table and do the following testing Only on Socket 6401
    1- plug it in wall and test Pin 6 STBY. there should be 3.3-5V. if this the case then
    2- jumper it to PiN 5 Power_ON the Relay will click once
    3- keep the Jumper in pint 2 and jumper PIN 6 to Pin 1 TCON12V_ON you will have on socket 601 12V
    4-Always keep the Jumper in point 2 in place and make another jumper from Pin 6 to Pin 3 EVDD_On you will have on socket 501 19-24 V for EVDD
    if all V fine then yours PSU fine.
    • Diah
      • Feb 2013
      • 6541
      if yours work on the post above after point 4 all fine.. put back yours PSU in place and keep the jumpers all in place... don't connect the socket 6401 which it goes to main boards...
      disconnect the 2 LVDS ( in yellow from T-CON side ) the other 3 sockets on t-con should be connected ... power on the set yours screen should come ON and you can see if there issue on it... this is Standalone test for T-CON and panel..
      if there are color pattern and the screen clean.... mean yours TV issue at MB.
      • repair-it
        • Nov 2020
        • 116
        • US
        ok, I think I have a faulty PSU. I did as you said and I do not have any standby voltage so I didn't go any further. Also, there is no voltage present on the 2 large caps on the secondary side. Before I disconnected everything I powered up the board and main caps went to 380v but then board shut down. After removal and powering up, main caps only went to 160v. What really sucks is both Main Board & PSU for this TV are hard to come by right now.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4532
          • Italy - Milan
          As per situation in post1 you must have STB, at standby state at least.. the test suggested is wrong if made to test PSB, since white connector on tcon feeds 12v, by detaching only 2 connectors if the tcon is SC then PSB shuts off..
          post a 2000x2000 pic very bright no flash of tcon, need to check power components..
          • EazyBone
            • Jun 2023
            • 1362
            • United states
            I don't think you tested enough. I'm pretty sure on stby the main caps will be lower at 160 and when PSON triggers they'd go up to 380. I don't think you've done enough testing.
            Those 2 caps on. Secondary side will only show voltage once tcon 12v happens. So they are going to appear dead.
            I had this same TV a few months ago, tested a million times. With everything disconnected check the stby pin again for voltage. What is it?
            But this kit is at shop jimmy for $300 for all the parts, and you can also make offer on there as well, which worked for me.
            • repair-it
              • Nov 2020
              • 116
              • US
              Yes, what you say about the voltage difference makes sense. The problem is finding replacement boards. The other issue is reprogramming the set after board replacement unless you can find a matching set. Far more than I'm getting paid to do, so it is going onto someone else to mess with. Not worth my time & effort.
              • EazyBone
                • Jun 2023
                • 1362
                • United states
                Alright.. there isn't different versions for this set they I know of. All good. Good tv to go to waste
                • grilledchicken
                  • Aug 2025
                  • 4
                  Hi, I will try this test to rule out my motherboard. I tested power supply but jumping pins I have all voltage 3.5v, 12V, 24V. when I press power button on TV or remote nothing happens. I tried on 3 different mainboards.. I cant be that lucky all 3 Mainboards are bad? will try this test to see if panel comes on... with your trick without the Mainboard connected and LVDS cable not connected .. panel should turn on and I should see color or sometihng ?
                  • grilledchicken
                    • Aug 2025
                    • 4
                    *****Updated**** once I replaced the TCONN Board TV booted up without issues with Mainboard connected and no blinking errors. only problem is the screen is black now. what else could be wrong ? tv is facing down. I will try and flip it over later and see if I can connect some HDMI to it and see if anything shows. but as of now screen is black nothing. but TV is on.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4532
                      • Italy - Milan
                      Ehm, who are you? You need to open your own thread as i think you have different issues from the O.P., as always i read all posts for nothing discovering at the end you are not the O.P. so i lost minutes.. see how GOOD ARE YOU!
                      • grilledchicken
                        • Aug 2025
                        • 4
                        ****Finallly UPDATE****
                        after replacing the 2 LVDS cables since I had from donor TV... the screen came on..... ANOTHER TV FIXED lol.. I cant believe it the cables was giving me problems
                        • lotas
                          • Jan 2016
                          • 4835
                          • Russia
                          Now you will know that SONY lvds cables are complete crap, they often become unusable, the most common problem...
                          • PopsCaps
                            Sony Bravia KDL-40V2500 that will not power on
                            by PopsCaps
                            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                            I do not hear any sound and I cannot see any backlight.
                            I have tried disconnecting every cable on each board one at a time to see if anything changes.
                            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                            03-25-2025, 11:23 AM
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • SkishyIshy
                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                            by SkishyIshy
                            Hey All,
                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                            03-17-2021, 11:44 AM
