Samsung LN32C350 No Backlight
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Hey guys, I need some help with this one.
    I initially got this set with the problem of no power and no standby light.
    I opened it up and found a bad mains fuse and one shorted FET that's labeled 10NM60N. I replaced the fused and the fet with a 10NM60ND.
    The standby light is now on and the set turns on with the Samsung chime but there is no backlight. I shined a light on the screen and can see the picture.
    How do I know if this is a main board or PSU/inverter problem? What voltages should I check?
    Re: Samsung LN32C350 No Backlight
    Look to see if the main board send the BL_ON signal to this power supply/inverter combo board. Check the DC voltage on the big main filter to see if it has about 370~400VDC right at the two legs.
    • Glitcher
      • Mar 2013
      • 673
      • USa
      Hmm I only see one labeled BLU_ON, is that the one? Its measuring 0.05V
      In standby the cap measures 162.2V, but once I turn on the set, it drops to about 157.6V. I'm guessing that's a problem in the PSU?
      • selldoor
        Slow Learner
        • 7870
        If you unplug the lead to the lamps does the voltage at the big cap still drop?
        Is there no flash from the lamps at all?
        • Glitcher
          • Mar 2013
          • 673
          • USa
          There's no flash at all.
          There's two connections going to the lamps. I just tried unplugging both connections and then individually and the big cap would still drop its voltage in all cases.
            "In standby the cap measures 162.2V, but once I turn on the set, it drops to about 157.6V" the PFC voltage booster is not working. Need to find out if PS_ON is also present, no PS_ON = No PFC Voltage booster.
            • Glitcher
              • Mar 2013
              • 673
              • USa
              While in standby PS_ON measures 0.04V and while the set is on, PS_ON measures 1.98V.
                So the PS_ON is OK, but the PFC Voltage booster is not working, that will the next section to work on.
                  Post good pictures of the bottom side of this PS-Inverter board, in the means time check all the Diodes (especially the two black one next to that main filter cap) on the primary side of the circuits, and look for any burnt/damaged parts.
                  • Glitcher
                    • Mar 2013
                    • 673
                    • USa
                    So far I checked all the diodes on the PSU in circuit. They all seem good with readings in one direction and infinite in the other.
                    There are no obvious burnt/broken components that I'm seeing.
                      That MOSFET you replaced is for the PFC circuit, there is a SMD IC close by that MOSFET, it is an PFC Controller IC which is more likely to be damaged when the MOSFET went out, so you need to get the IC number to get the spec sheet and the pin outs, then you will need to check ALL the resistors and diode connected to the Gate and any resistor connected to the Source pin of that MOSFET you replaced.
                        I'll just leave this here...
                        Check DP805 is not short.
                        Check Vcc across CP809 for PFC controller.
                        Check Vcc across CM804 for standby voltage/multi voltage.
                        edit: above might not be relevant if PFC IC is damaged, did not read post fully.
                        • Glitcher
                          • Mar 2013
                          • 673
                          • USa
                          I checked the resistors directly connected to the gate pin and they measure to the correct range. The diode beside is still in question, since I'm not sure how to check that.
                          I'm guessing that 8 pinned IC (IC802S) to the left of the FET is the PFC IC ? From tom's schematic its a FAN7530MX. I found the datasheet for it but not sure how to check if its still good. Should I check the voltages of each pin, and since its in the primary side, I should check them relative to the main cap correct?
                          Tom - Thanks for the schematic, I checked DP805 out of circuit and it appears normal. What did you mean when you said to check the "Vcc"?
                            You can check the resistance of all the pins against the Ground pin, report the reading. Also check the voltage on the VCC pin, main cap negative is the circuit ground ref. for the primary side.
                            • tieny
                              • Feb 2012
                              • 478
                              ...deleted *wrong thread...
                              • Glitcher
                                • Mar 2013
                                • 673
                                • USa
                                Measurements are shown below in the photo.
                                The Vcc pin measures 15.9V while the set is on.
                                The CS pin has a low resistance reading, but im not sure if it means it shorted or not. Measuring the voltage it reads 0.71V while set is on.
                                Reading the datasheet
                                Pin 4 CS: "This pin is the input of the over-current protection comparator. The MOSFET current is
                                sensed using a sensing resistor and the resulting voltage is applied to this pin. An
                                internal RC filter is included to filter switching noise."
                                Not sure what it means.
                                  CS pin is connected to ground via very low ohm resistor (<1 ohm) so that's normal. If you have got 16V at that IC you should have PFC voltage.
                                  Check DP803, RP803, RP823, RP802 (SMD resistor/diode probably.)
                                  DP803: normal diode check (not open)
                                  RP803: 30 ohms
                                  RP823: 68 ohms
                                  RP802: 10k ohms
                                  Also CP810 - across diode DP805 - should read open
                                  • Glitcher
                                    • Mar 2013
                                    • 673
                                    • USa
                                    How would you go about testing the smd diode (DP803), the one with 3 pins,
                                      For now, check to see it is not open circuit. As that is all is important for now to get that FET going.
                                      • Glitcher
                                        • Mar 2013
                                        • 673
                                        • USa
                                        I checked it with diode mode. It reads 0.095 in both directions. It reads this for both pins.
                                        • SJX1290
                                          No Standby Light on Samsung SAMSUNG UE65NU7022
                                          by SJX1290
                                          I have Samsung UN65MU6300FXZA with Mainboard BN41-02662A, dead , No Standby Light. I suspect result of main power jumping. Checked all voltages on main board ok,..
                                          My main suspect is bad flash memory, ...
                                          Any suggestions or can someone please​ check dump file, in the attachment
                                          Thank you...
                                          09-07-2024, 01:35 AM
                                        • Jovica123
                                          Samsung UE55AU8072U no standby light
                                          by Jovica123
                                          i have here Samsung UE55AU8072U no standby light.
                                          Panel model : CY-SA055HGXY1V
                                          Motheboard model : bn41-02844A bn94-16868V
                                          When i press the power button,standby light turn on,after i release it immediately turns off.
                                          Unplugged main board from power supply - BACKLIGHTS COME ON.
                                          I think the motheboard is problem.
                                          I fixed two TV with same mistake,but they were 6000-series,there was a problem with the contents of the w25q40 chip.
                                          Here are all dumps : ic801(24c512),ic1603 and ic1604(25q40)....
                                          12-10-2023, 09:21 AM
                                        • slimsoul
                                          Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                                          by slimsoul
                                          Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                                          I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                                          I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                                          The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                                          03-12-2024, 03:55 AM
                                        • Michael Long
                                          No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          by Michael Long
                                          I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          Dead / No Power / No Standby Light results after power company had three
                                          consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                          After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                          09-13-2022, 06:55 AM
                                          09-07-2024, 05:50 AM
