westinghouse LVM-47w1
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    #41
    Re: westinghouse LVM-47w1
    no around 1200v - 1600v DC to power the tubes
    only with a known working inverter
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • smai
      • Dec 2013
      • 69
      the ribbon that i unplug to make the tv stay on, goes across to the master board, i can unplug either and the TV will power on, (i tested for continuity)
      also when i test for voltage on the copper pads on the slave board i get nothing, when i test on the master board the TV shuts off ?? sounds like a bad slave board ?
      • mcross
        • Sep 2011
        • 201
        Did. You check the fuse on the slave inverter ?
        • smai
          • Dec 2013
          • 69
          yea none are open
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            #45
            might work,can you disconnect slave and vise versa,one at a time,and see if mainboard,and psu still power up? and remain so,something is dragging everything down on them inverters
            im leaning towards faulty tubes now
            • smai
              • Dec 2013
              • 69
              i moved the master inverter board to the location of the slave plugged in all the tubes etc, it powered right up and remained on, so the fault has to be in the slave board, i re examined it everything looks fine so one of the components must be shorting out on the inside
              • smai
                • Dec 2013
                • 69
                update i ordered an inverter board and had the same result turns out while plugged in when i move this (see pic) ribbon around it will either turn on the rest of the tubes and stay on, leave right side tubes off and stay on or do what it was originally doing lights off and a creek (audible noise)
                so im taking a guess that the ribbon is bad ? but i cant seem to find that part anywhere
                any thoughts on locating one or what the problem might actually be ?
                thanks
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • lostone
                  Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                  by lostone
                  Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                  First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                  When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                  05-19-2024, 11:40 AM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
