*Please help* GRUNDIG GULCD37HDIT wont turn on
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    #41
    Re: *Please help* GRUNDIG GULCD37HDIT wont turn on
    if thats the case then,either the inverter is causing the 24v to drop out while its connected to the psu due to a fault on it,id be inclined to pull the 24v line out of the connector,and inject 24v from bench supply into the 24v cable to inverter,and jumpering bl_on to its stby voltage to at least check backlights are fine and inverter,after checking shorts to ground on it.
    then do resistance tests on the 24v pin at the inverter cable end for shorts,then checking components back along that trace for problems,it maybe one of the out put diodes coming off the smpt that supply's that rail is shorted or open.
    i wasnt sure if the 24v should be present if the bl_on signal was 0v,i trust tom's judgement
    ,so im taking his word as a baseline.
    earlier in the thread it was pointing to mainboard failiure,but def seems like a psu fault
    which is good news as they are easier to fix
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • simple-me
      • Jan 2014
      • 27
      • England
      #42
      Multimeter.....should I look at replacing the PSU?
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        #43
        if you have limited test equipment and/or no experience,then id say yes,get another psu,from a trusted seller,with a returns policy
        making sure you match the part numbers
        some say "tested"working,but id take that with a pinch of salt.....
        • simple-me
          • Jan 2014
          • 27
          • England
          #44
          I'll check around for pn# 3122 133 33122 PLCD 190 PT3 23341 and report back later...thanks
          • simple-me
            • Jan 2014
            • 27
            • England
            #45
            No 24v on any of the inverter cables
            Correction...
            I do get 24v on the white inverter cables when all the wiring is connected up!
            • simple-me
              • Jan 2014
              • 27
              • England
              #46
              hello all,
              I got a replacement psu and tried this but the tv will still not turn on!??
              • simple-me
                • Jan 2014
                • 27
                • England
                #47
                Got the tv working...after some serious technical help!
                Thank you Tom66
                Here's how it happened...
                Replaced LDO U713, part 1117-33.
                Output voltage was unstable 1.3V to 1.7V, changing when power button pressed. No shorts on output. Temporary bodge job connected 3.3V from one part of board to other - set then powered up.
                Freeze-spraying regulator did not affect performance.
                After this test showed signs of life, regulator was replaced with Farnell P/N# 1469051 and TV worked perfect after that.
                  Free TV repair in return for curry :P
                  BTW, forgot to note, the regulator was supposed to output 3.3V. Found another regulator outputting that so tied them together for a brief test and it worked.
                  • simple-me
                    • Jan 2014
                    • 27
                    • England
                    #49
                    Was a little spicy but you survived it :P
                    Thanks for your help mate...
                    • Gusse
                      GE62VR 6RF Apache Pro - reboot until turn ON stuck at 1.6A
                      by Gusse
                      I am asking for your help because I am having a problem with no image on an MSI GE62VR 6RF Apache Pro.
                      Here is a list of things I have checked:
                      - Removed/reinserted the RAM
                      - Removed the hard drive
                      - Removed the SSD
                      - Connected via HDMI -> no image
                      - Tested caps lock -> working
                      - USB key -> “activity” (LED flashes when inserted)
                      - Reflashed the BIOS with CH341 using a version found on the MSI website (then checked the dump read with UEFI Tool) -> same result
                      - Checked the power rails around the CPU on the...
                      10-07-2025, 06:17 AM
                    • PITERPENY
                      MacBook A1989. Stuck in DFU and won't turn on!
                      by PITERPENY
                      MacBook A1989. does not work with dfu. Stuck in DFU and won't turn on!
                      20 volts and 0.00 amperes
                      Does anyone have any suggestions?
                      It's possible that the problem is in the EFI (BIOS),
                      who has the EFI ROM file please share
                      01-11-2024, 07:43 PM
                    • pajdek
                      Lenovo Y700-17ISK turn on and off
                      by pajdek
                      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                      09-20-2023, 02:49 AM
                    • Stunt
                      Hp Laptop Stuck on Hp protected by hp sure start screen
                      by Stunt
                      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                      screen that's it and stuck there. I left it until the following day and i still...
                      09-02-2025, 01:51 PM
                    • Sergio Kub
                      820-02536 It doesn't turn on, it's stuck at 5V.
                      by Sergio Kub
                      Has anyone ever removed the shielding from the 820-02536 board to access some components ?
                      I need to check the 5V (PP5V_CHGR_SW) and other points.
                      11-03-2025, 03:02 PM
