sansui lct32sd
  • willyam1
    • Feb 2012
    • 112
    • israel
    sansui lct32sd
    HI.
    can anyone tell me please how to go to factory mode.
    willyam
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: sansui lct32sd
    assuming you have searched on here and on the web, it might help to tell us
    the board manufacturer and board numbers. Try the ones for other sets in the stickies?
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      Re: sansui lct32sd
      if you have the main board im thinking of try this..press menu button on remote ,then channel-, then enter 1947 code, services mode will open,you should see the service menu.
      what is the problem your having?
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • willyam1
        • Feb 2012
        • 112
        • israel
        Re: sansui lct32sd
        thanks but no joy.
        i try all factory mode in this site no joy.
        main bord in this tv is 520-L32SEVK-010B AND the other main board that is conected to is 520-L32SEVK-030A.
        THE PROBLEM IS PIC IS OK IN VGA ANS HDMI BUT IN AV (RCA Y R W) NO COLOR OR STRIPS OF COLOR THE SYSTEM COLOR IS OK PAL .
        MAIN BORDS MADE BY-SMART TVISION TECH.
        THANKS WILLYAM
        • RRice25541
          Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
          by RRice25541
          So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
          the color is all outa wack, like the settings have been corupted,
          I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
          so
          The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
          when i bring up the menu and type the pass codes to access either mode the menu disappears...
          05-13-2022, 10:44 PM
        • masterm
          JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
          by masterm
          TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
          Problem with TV:
          - Netflix stopped working so i tried to do factory reset from the TV menu.
          - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
          - After waiting for some time, the TV went into a boot loop.
          - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
          04-30-2024, 03:03 AM
        • Coert van Dorsten
          Sansui Integrated Amplifier replacement volume control troubles
          by Coert van Dorsten
          Hi all you clever electronmic gooroos!
          I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
          10-15-2025, 02:54 PM
        • Hornnumb2
          Sansui sled4019 dim picture
          by Hornnumb2
          I have a sansui that just started having a dim picture, adjusting backlight settings up or down have no effect on display. I went ahead and ordered some backlight strips for it but find it weird that changing the setting has no effect. Could it be power related. Where should I start? Thanks Michael ...
          08-31-2025, 10:37 PM
        • Hornnumb2
          by Hornnumb2
