JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
  • masterm
    • Apr 2024
    TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
    Problem with TV:
    - Netflix stopped working so i tried to do factory reset from the TV menu.
    - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
    - After waiting for some time, the TV went into a boot loop.
    - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
    - Tried to turn off and start again but same as above (JVC logo on-screen, LED blinking, boot loop)
    - Menu 4725 from the remote does not work
    - I am also not sure of the version of software i need to get the TV working again, if it is a firmware problem
    - Manufactured by Vestel (17mb130E)
    Please let me know what other information can i provide to identify the issue here.
    I am a beginner, trying to revive my TV. The TV was working absolutely fine until i tried to do factory reset to make Netflix work and here we are!
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Is this a Google TV?
    • masterm
      • Apr 2024
      No, not a google TV.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        what lcd screen number is used in this set its usually printed on a white sticker also maybe worth you asking this question in this thread Eeprom dump thread! - Badcaps
        • masterm
          • Apr 2024
          LCD Panel model: VES430QNUL-2D-U01
          thanks, will post it on the EEprom dump thread too.
          • sheffieldyorky
            ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
            by sheffieldyorky
            Hey there people
            While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
            This is what I tried, but not in any order.
            Google
            YouTube
            BIOS
            Command Prompt (administrator privileges)
            On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
            10-25-2025, 02:22 AM
          • mon2
            Hisense 55Q9G Android reset / factory firmware reload
            by mon2
            Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
            After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
            01-03-2024, 10:25 AM
          • pfrcom
            Reset/erase Hynix SC210 to factory default
            by pfrcom
            Some Googling made this seem straightforward, but it ain't necessarily so:
            First try was Hynix Drive Manager, supposed to be able to do PSID reset
            In Win7 x86 context, what shoddy software – this greeted me first time I clicked it from Start menu:
            After wild goose chase triggered by the OpenGL bit, I tried swapping graphics cards until penny dropped when it still objected to a Radeon HD3450
            How I got it work:
            1. Command prompt
            2. Change to install directory \Program Files\SK Hynix Drive Manager
            3....
            04-23-2022, 07:30 AM
          • LEONARDO DE FREITAS
            Chinese multimedia crashes on the home screen, could someone help with the software or factory reset?
            by LEONARDO DE FREITAS
            Hello everyone, I have 2 multimedia systems with a 9-inch screen that turns on and only stays on the Android screen. It is very likely a software update. I have 2 software programs here but the multimedia system does not start the installation. Has anyone encountered this problem? I would be grateful if you could help.
            04-18-2025, 09:58 AM
          • AJ847.63e
            A1708 unable to reinstall Monterey after factory reset - disk utility error 478
            by AJ847.63e
            I've got a A1708 which we decided to sell off as we no longer use it. We factory reset the device to wipe all data which went fine but when trying to reinstall macOS it fails with the generic “ MacOS “Installation Failed, An Error Occurred While Installing”. I've tried the usual solutions like the first aid utility apple recommends and also disc utility delete the partitions but still get the same error. Digging into the logs you can see it's giving an error 478 but unfortunately wasn't able to get much info on that on google so I'm unsure where to go from here....
            02-20-2023, 02:51 AM
