Sansui Integrated Amplifier replacement volume control troubles
  • Coert van Dorsten
    • Oct 2025
    Hi all you clever electronmic gooroos!
    I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right channel joins in. This should obvioulsy start at minimium together. Ive wired the pot with RIGHTsignal IN on track and signal OUT to the amplifier stage on the wiper and then the ground wire on the other side of the track. Ditto for the LEFT Channel .Ive also joined the the 2 ground wires on the pot together.
    I think the 250K pot is too sensitive at minimum making a slight tolearnce differeance bwteen the start of the 2 tracks very noticable.
    Any advice or explenation of what is happening here would be vey much appreciated.
    Thank you
    Coert
  • crackedprint
    Sony HCD-HX80R Amplifier Volume Control Problem
    by crackedprint
    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
    I have tried a Cold Reset as per the service manual.
    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
    I have looked all the way through the service manual and tried many online...
    01-21-2025, 12:18 PM
  • karthur
    Vizio D65x-G4 Volume changes on its own
    by karthur
    On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
    It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
    06-05-2025, 08:13 AM
  • freethink
    Kenwood KR-A70 Receiver Balance changes with volume controls?
    by freethink
    I have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
    11-23-2025, 07:53 PM
  • BigOof
    Marantz SR5007 popping on volume change and mute in Direct Mode
    by BigOof
    I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
    12-12-2024, 06:15 AM
  • Dannyx
    Simple volume control for audio amplifier ?
    by Dannyx
    Good day folks. I want to run a Bose subwoofer and some random speakers on my PC at home. I don't have an amp for this project yet and I was looking for decent solutions and I figured I could very well run them on a car amp. Why not a regular hi-fi amp ? I figured a car amp would fit better under my desk. I looked at a Sony XMN1004 which is relatively affordable, yet of decent enough quality and with good reviews overall. Conveniently enough, this Bose Acoustimass 5 Series II sub (what a name) I have has two drivers inside, each with its own separate terminal, so I can hook it up to the Sony...
    12-27-2020, 10:17 AM
